March 15, 2026, 01:58:06 am
Foil will help some by reflecting more light.You'll probably also want a diffusion layer of some sort.Scott
Move it back as far as possible. Also, can't believe you're not using LEDs.
Quote from: kiwasabi on August 18, 2013, 03:21:52 amMove it back as far as possible. Also, can't believe you're not using LEDs. LED will b nice but I'm not good finding the right voltage for stuuf already burn a 12v fan and two fingers by holding the Soldering iron thingy from the wrong side
Quote from: Caparo8bit on August 18, 2013, 02:11:56 pmQuote from: kiwasabi on August 18, 2013, 03:21:52 amMove it back as far as possible. Also, can't believe you're not using LEDs. LED will b nice but I'm not good finding the right voltage for stuuf already burn a 12v fan and two fingers by holding the Soldering iron thingy from the wrong side its easy to find 12v. You can tap the yellow on a molex connector use use the 12v from your arcade power supply. Also, the animated Caparo in your sig is super annoying, congrats!
I agree. Annoying. Make it stop!Also, I always hated that floating mouse thing to try and trick me. Lose that too, please.Thanks for posting those DeLuSioNal29, I am going to go with those from now on. Cheers!
He already has the florescent light going to why not just diffuse the light with something behind the marquee like bit of translucent plastic panel or even white paper. The spot can also be reduced by covering the sides and back of the marquee light area with crinkled tinfoil that will help scatter the light. I use metal aluminum tape on the inside of the marquee area. It is real tape for ducts not the plastic duct tape that people buy that does not stick and does almost no good.
That'll work... now ditch the LED's and just use the fluorescent bulb that tis in there already!
