Author Topic: star wars 14 tooth gear  (Read 1303 times)
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« on: August 17, 2013, 04:53:26 pm »
anyone know where i can get one?
northerngames
  • Trade Count: (+18)
Re: star wars 14 tooth gear
« Reply #1 on: August 17, 2013, 05:09:11 pm »
what pitch and what is the inner shaft diameter?
tony.silveira
    • my baby
« Reply #2 on: August 17, 2013, 05:31:56 pm »
oh boy, not sure.  let me see what I can find out.
is this maybe something you can make?  3d printer maybe?
northerngames
« Reply #3 on: August 17, 2013, 05:38:15 pm »
no but it depends on how thick the shaft or the inner diamer is.
if it is a match you will not have to worry about it wearing again.
possible to post a pic of it so I can get an idea of how big it actually is.
northerngames
« Reply #4 on: August 17, 2013, 05:44:03 pm »
I think I got ya covered lol.
check out the robinson racing products hardend 32p 14t steel pinion gear looks like a 5mm shaft but a bushing could be used to fill the gap if needed.
these are the #1 rc pinions and handle tens of thousands of rpm and never wear so unless you use the force your good to go forever lol.
it may be a mod gear type pitch too though but rrp also sells them and there all over ebay for cheap.
the inner diameter hole is the main thing though.
« Last Edit: August 17, 2013, 05:48:51 pm by northerngames »
tony.silveira
    • my baby
« Reply #5 on: August 17, 2013, 06:54:34 pm »
thanks man, i went ahead and ordered one, lets see if it'll fit!
northerngames
« Reply #6 on: August 17, 2013, 09:31:55 pm »
if it is too big in the shaft hole a sleeve may be able to be used but I looked into it and it looks like what I mentioned prior and if so it will last you forever as long as there is proper gear mesh.
tony.silveira
    • my baby
« Reply #7 on: August 23, 2013, 09:26:28 pm »
yikes!  way to small.  here is a pic showing them side by side.  thanks for the assist though.  anyone know where i can get a star wars 14 tooth gear?
northerngames
« Reply #8 on: August 24, 2013, 10:50:34 am »
yeah that was way off and too bad too becuase the rrp's last forever and would have solved that issue for SW owners.
bummer but was worth the shot I guess.
so it was not a total waste I would buy the rrp off you, I could use one for my current rc build.
« Last Edit: August 24, 2013, 10:52:36 am by northerngames »
« Reply #9 on: August 24, 2013, 11:24:10 am »
You can't put just one metal gear in there with the plastic gears.  It'll kill the others.
northerngames
« Reply #10 on: August 26, 2013, 10:24:13 pm »
no metal on metal is worse same with 100,000 rpm rc's.
we run that on the motor and a plastic spur a metal spur with a metal pinion last a half pack at best and turned to powder.
this is just a free spinning gear with no high rpm torque either so it would be fine..
