Author Topic: Good mini ITX motherboard for bar-top mini arcade  (Read 4092 times)
swearmanc
  • Last login:May 01, 2014, 10:11:11 pm
« on: August 15, 2013, 07:23:51 pm »
Hi Guys,
Came across this on ebay whilst looking for an old cheap mobo and cpu to build a bartop out of, whadya all think?  should run most all MAME games good, (don't know about hyperspin though)  but for 30$ shipped I may just try one...
http://www.ebay.com/itm/220593733143?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
not my listing, not trying to promote anything, just passing along a good find.
  • Last login:November 13, 2025, 01:36:49 am
Re: Good mini ITX motherboard for bar-top mini arcade
« Reply #1 on: August 15, 2013, 07:32:52 pm »
Not bad. I just picked up an Intel one with 1GB ram included for $30.
ark_ader
  • I glow in the dark.
« Reply #2 on: August 15, 2013, 07:37:26 pm »
They are crap.  Better off with a 1.4 celly for $20.
Or go android mk808.
« Reply #3 on: August 15, 2013, 08:21:51 pm »
I run one that's basically running the same games as a 60-in-1, but with an AtomicFE menu and controling a GP+Wiz for LED buttons. It's fine for that.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #4 on: August 17, 2013, 10:50:04 am »
try craigslist for used dells like that. i'm in bay area, ca and I can find complete used systems for less than 50-100 bucks.
You still need a power supply, so figure 40 dollars for a decent one.
Many people are upgrading from P4s and Dualcores and are unloaded their old desktops now.
404
« Reply #5 on: August 17, 2013, 12:13:18 pm »
If you are dead set on an itx board and are lloking for slightly more power, consider looking at some boards that support socket 479 core2 mobile processors. There are also lots of itx units that can accept standard desktop cpus
Another option would be to use an AMD based itx board that has a built in APU. You can get one for as little as 50 dollars and they have a processor and graphics core built in. Most of them also support the latest sata and ddr3 standards so that's another sizable boost to your emulation rig.
BobA
  • What Me Worry?
« Reply #6 on: August 17, 2013, 08:14:13 pm »
I used to use atom dual processor mini itx boards but they have become harder to find so I switched to a newer motherboard with dual new generation celeron processors that have much better performance and still use very little power.  Memory is cheaper because it is DDR3 but they are not passively cooled as they have a very low noise fan on the cpu.
Gigabyte GA-C847N-D
