Author Topic: How to fasten Cp top down?  (Read 2089 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: August 14, 2013, 10:21:47 am »
How are you guys keeping the top of your control panel in place?
I've tried using these but they're not very good at all.
  • Last login:November 22, 2025, 08:32:45 pm
Re: How to fasten Cp top down?
« Reply #1 on: August 14, 2013, 10:36:46 am »
In before the Scott!
I use these - actual control panel latches:
http://www.twistedquarter.com/index.php?main_page=product_info&cPath=219_225&products_id=934
Connorsdad
« Reply #2 on: August 14, 2013, 10:44:22 am »
$56 when posted to the uk :(
Just looking for somewhere in the uk that sells these.
« Reply #3 on: August 14, 2013, 10:53:14 am »
I tried to use those on a 3/4 scale cab that I built for my nephew and they released way too easy.
In that cab, the CP was open to the inside of the cab, so I just used L-brackets and screwed them in.
You can probably find something similar to the real clamps at the hardware store.
The CP top on my current build isn't fastened down yet and can't be accessed from inside.
I'd originally planned to put a hinge on the front edge and a latch on the back.
But since I love tinkering and fine tuning things, I'm leaning toward some type of slot system that allows it to be removed completely.
(It would have to be lifted straight up several inches to be removed.)
« Reply #4 on: August 14, 2013, 11:17:18 am »
industrial velcro on my bartops.
  • Last login:Today at 08:35:16 pm
« Reply #5 on: August 14, 2013, 12:38:08 pm »
Don't see any UK sources offhand.
Maybe a German source?
Arcadeshop.de has several latch options like this, this, and this.
What are the specific measurements/configuration of your panel?
« Last Edit: August 14, 2013, 12:49:21 pm by PL1 »
Connorsdad
« Reply #6 on: August 14, 2013, 01:01:32 pm »
It's the same as Griffindodds revolution cab here
http://forum.arcadecontrols.com/index.php?topic=121570.0
Same shape and angle, I don't have a hinge on mine. Also I don't have access to the inside when closed.
Sent from Amstrad CPC464
Dawgz Rule
« Reply #7 on: August 14, 2013, 01:34:45 pm »
I went the simple route and simply glued a block of wood so I can screw into it from the side of the CP.  The screw head is black and really can't be seen.  With the cabinet built and configured, I have had to go into the guts of the CP twice.
« Reply #8 on: August 14, 2013, 02:16:08 pm »
Then latches might not be the way to go.
How would you engage/disengage them?
Connorsdad
« Reply #9 on: August 14, 2013, 02:30:15 pm »
I couldn't tell from the small photo on the twisted quarter site how the latches work.
« Reply #10 on: August 14, 2013, 02:46:52 pm »
They're supposed to go on the inside, but I'm sure I've seen people here use then on the outside, provided there is enough lip on the top panel.
« Reply #11 on: August 14, 2013, 02:48:19 pm »
EMDB
  • Project RetroCade
« Reply #12 on: August 14, 2013, 04:11:44 pm »
I use these clamps from arcadeshop.de:
severdhed
  • Last login:Yesterday at 06:01:44 pm
  • RIP Dinosaur Hippo
« Reply #13 on: August 14, 2013, 04:40:42 pm »
Hinges and gravity.  Three are two hinges at the back edge, and weather stripping foam around the top edge of the box to keep it from rattling, feels very solid
Sent from my SCH-I535 using Tapatalk 4
