Author Topic: LED BUTTONS  (Read 15512 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #40 on: August 16, 2013, 03:27:16 am »
You need to add an ipac to your jpac to allow the inputs for players 3 and 4 along with adding all the buttons and joysticks to you panel.
i think im going to do the shift option...
Re: LED BUTTONS
« Reply #41 on: August 16, 2013, 08:00:52 am »
I think he's trying to use the P3 and P4 harnesses for his buttons and not actually have a set up for 4 players. I think he's missing the basics of
1) You dont need to use the existing harnesses
2) All buttons share a common ground
3) You just need to run a wire from the terminals on the JPac to a button (and share a ground) for the button to work
4) Read before trying things
5) researching a little before asking what can be considered very easy questions that are easy to find answers to
6) 120v AC isnt the same as 12v DC
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #42 on: August 16, 2013, 09:25:45 am »
Thanks for the clarification Malenko.   I do not understand exactly what he is trying to accomplish with all the questions that do not seem to have a common goal.   I thought it would be a stretch trying to turn a 2 player panel into a 4 but I don't judge, I just try to provide info on the process.
Thanks Bob
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #43 on: August 16, 2013, 11:49:29 am »
Well sorry for my bad English there's no spanglish forums arround. What I'm trying to do is connect some of  the 3th or 4th player cable buttons in to the Jamma harness .can't connect more on j-Pac already using all terminals. In few words I'm trying to go from Jamma to j-Pac....
Re: LED BUTTONS
« Reply #44 on: August 16, 2013, 11:56:39 am »
Caparo-
Not a native speaker? Where are you located?
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #45 on: August 16, 2013, 12:06:57 pm »
If you are already using all the extra terminals on the jpac for buttons you have to add another interface to add more buttons.   I now see you don't want player 3 and 4 to use just more buttons.  An additonal ipac or other keyboard interface would have to be added since all the jpac is used.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #46 on: August 16, 2013, 12:13:31 pm »
Caparo-
Re: LED BUTTONS
« Reply #47 on: August 16, 2013, 12:22:05 pm »
Caparo-
Jorale! /me throws grito in your direction
Just wondering. I'm Mexican-American living in AZ.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #48 on: August 18, 2013, 02:19:24 pm »
 :cheers: Thanks Boba I ordered 20 led buttons and 18 awg cable  now need to find 12v from computer or arcade amp... Cross my fingers.   :notworthy: btw can I ground LED with ground from button?
« Last Edit: August 18, 2013, 02:22:25 pm by Caparo8bit »
Re: LED BUTTONS
« Reply #49 on: August 18, 2013, 03:18:55 pm »
get a Molex (4 pin power 8189 series) splitter, put it in your computer, tap the yellow for 12v and the black for ground. Dont wire in the grounds with the buttons, its usually best for beginners to keep wiring sets isolated from one another.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #50 on: August 18, 2013, 09:51:42 pm »
got ya ...my control panel is litle far since i have the showcase and i have to run the 12v and ground from pc to control panel 1 line of each will b enough for all buttons i just splice from one to other i think they calle that daysi somthing daisy duck????
Re: LED BUTTONS
« Reply #51 on: August 19, 2013, 09:00:43 am »
Daisy Chain.
You can run 2 wires (+12v and ground) from your power supply to your control panel, then splice/chain from there
  • Last login:Today at 01:11:00 pm
Re: LED BUTTONS
« Reply #52 on: August 19, 2013, 09:28:07 am »
Daisy Chain.
Not to be confused with Daisy Duck . . .
. . . or Daisy Duke.
« Last Edit: August 19, 2013, 09:31:03 am by PL1 »
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #53 on: August 19, 2013, 08:16:35 pm »
 :laugh2:  " DAISY CHAIN"   hey running one 12v per player will make diference on brightness?
Re: LED BUTTONS
« Reply #54 on: August 19, 2013, 09:49:47 pm »
not likely.
