Author Topic: Securing PCI / Graphics in De-cased PC  (Read 6684 times)
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« on: July 30, 2013, 12:50:55 pm »
Hi All,
I've decided to de-case my PC, and although there are plenty of threads about this, the lack of images (that have been removed / deleted / no longer there) makes some of the descriptions hard to follow.
Does anyone have any old build pictures of how they secured PCI / AGP cards to the mobo so they don't just flap about in the wind?
Thanks chaps
EssJay
jk40001
  • Last login:August 24, 2013, 04:13:54 pm
Re: Securing PCI / Graphics in De-cased PC
« Reply #1 on: July 30, 2013, 01:25:33 pm »
I will have to solve that for my very first build cab soon too. I was thinking to simply buy one of those PCI ribbon extension cables:
http://www.ebay.com/itm/PCI-Express-PCI-E-16X-Riser-Card-Flex-Flexible-Ribbon-Extender-Extension-Cable-/400504001453?pt=LH_DefaultDomain_0&hash=item5d3fe613ad
and put it on jamma feets:
http://www.ebay.com/itm/25ea-PCB-feet-mounting-holder-JAMMA-Arcade-Cherry-Master-60-in1-multicade-game-/221260573791?pt=LH_DefaultDomain_0&hash=item3384286c5f
just like the motheboard to keep things organised and neat. Any thoughts about this idea?
MastarArcade
  • Last login:May 20, 2014, 02:42:08 pm
« Reply #2 on: July 30, 2013, 04:12:28 pm »
Keep in mind that adding that ribbon cable like that to a PCIe bus will likely introduce significant degradation in signal quality and the PCIe card may only run at Gen 1 data rates (2.5GT/s).
You may be able to squeak Gen 2 (5.0GT/s) out of it, but certainly don't hold your breath for Gen 3 (8.0GT/s)
I too have been wondering what my best option would be for an "open" PC design. I'm thinking that the following "Bench case" might work out nicely (and it does seem to have some retention rods for PCIe cards), but is a few more bucks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353001
UFO
« Reply #3 on: July 30, 2013, 04:32:25 pm »
@jk - I had thought about that too, but then I would be faced with a graphics / sound / whatever card that needs securing again somehow. The PCI cards are obviously not build to be outside a case, the only other thing I can think of doing in some kind of brace. I'll try and mock one up and add it later.
@MasterArcade - I will have to take your word for that my friend! Looks like you know a little more than me about transfer rated etc., although I do appreciate the dropoff you mentioned in signal quality. I'd looked into the bench too, but I don't know if this will enable things to be secure as it is just a testing rig.
Thanks chaps -- any more thoughts?
« Reply #4 on: July 30, 2013, 04:38:20 pm »
Cannibalize a case.
UFO
« Reply #5 on: July 30, 2013, 05:22:15 pm »
Thanks for that Nephasth,
If you don't mind, I will add another couple of images from your build to this thread from the YouTube video, as I think they may help too...
Great build BTW...  :cheers:
« Reply #6 on: July 30, 2013, 05:41:52 pm »
You're welcome, and thank you! :cheers:
MastarArcade
« Reply #7 on: July 31, 2013, 10:54:26 am »
You'll most likely need to drill out a few rivets in your PC case. All you'll really need is a power drill and the right size bit.
brained
  • Last login:February 11, 2026, 10:56:20 am
  • Raised by Atari
    • Nux
« Reply #8 on: July 31, 2013, 11:50:56 am »
Cannibalize a case.
Cannibalize, its so death metal!! :P
severdhed
  • RIP Dinosaur Hippo
« Reply #9 on: July 31, 2013, 11:59:13 am »
i cut up a bic pen into small pieces and used them to mount the motherboard to a piece of wood, then i bent the bracket on the video card, drilled a hole and mounted it like this:
it worked pretty well and was cheap and easy.
MastarArcade
« Reply #10 on: July 31, 2013, 12:35:23 pm »
Wow - nice ;)  ;D
..that's creativity for ya!
Minwah
    • MAMEWAH
« Reply #11 on: July 31, 2013, 01:07:23 pm »
I did this recently. It's a weird Dell arrangement so I made use of the 'CPU' fan housing to add a bracket to secure the cards.
(excuse the long bolts...they are all I had and are stainless so I can't cut them down)
« Reply #12 on: July 31, 2013, 02:49:14 pm »
Um, what? ???
I cut stainless screws/bolts all the time. Thread a nut on past the point you want to make your cut. Cut do desired length (I use a cutoff wheel, but a hack saw works too). Unthread the nut, and your threads are saved.
jdbailey1206
« Reply #13 on: July 31, 2013, 02:56:44 pm »
Um, what? ???
+1.  If you don't like moving saws next to your assembled PC just buy a good set of Klein cutters from Home Depot.  They are a little more expensive but they are my go to for cutting anything without dulling or getting the bolt to put a nick in your cutters.
eds1275
  • Rock and Roll!
« Reply #14 on: August 01, 2013, 04:00:47 am »
I just used some 14 gauge wire I had laying around from wiring up some outlets, and supported the far side.
charlieram
  • Last login:June 03, 2024, 03:42:30 pm
    • TTA Games
« Reply #15 on: August 01, 2013, 06:13:35 am »
You could just do what i did and get some of the brass standoffs and screw/glue them into your cab for the motherboard and a good old bit of meccano to secure the top of the Gfx card
Minwah
    • MAMEWAH
« Reply #16 on: August 01, 2013, 06:19:40 am »
Ok thanks, I thought a saw (I only have a junior hacksaw) would have a hard time cutting stainless steel - I will give it a try.
TopJimmyCooks
  • Last login:Yesterday at 03:28:53 pm
« Reply #17 on: August 01, 2013, 09:19:50 am »
i've seen hot glue used as well- right at the corner of the board and the socket.
UFO
« Reply #18 on: August 01, 2013, 03:12:46 pm »
I love all these ideas, and the creative thought process that went into them!
Plenty to think about here - cheers guys...
rockyrocket
« Reply #19 on: August 02, 2013, 12:03:33 pm »
+1 Hot glue works wonders.
UFO
« Reply #20 on: August 05, 2013, 05:50:28 am »
Ok... here was my solution with the inspiration from Severdhed...
I had loads of those mb risers lying around, so decided to put them to good use...
I also used them for the motherboard and hard drive incase it needed swapping in future... its all good and secure!
MastarArcade
« Reply #21 on: August 05, 2013, 11:33:36 am »
One more alternative that I stumbled upon during my searches...
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=130_210_750_753
Lian Li (PC Case manufacturer) makes some replacement ATX trays, which have the PCIe card retention mechanisms.
Looks like both standard ATX and Micro ATX trays are available for $30-$40. So if you're looking for an easy way out, this may be it.
UFO
Re: Re: Securing PCI / Graphics in De-cased PC
« Reply #22 on: August 05, 2013, 07:12:42 pm »
Thanks MA...
« Reply #23 on: August 25, 2013, 08:53:50 pm »
Credit goes to CoreyBee on this one:
"http://www.ebay.com/itm/PCI-Express-PCI-E-16X-Riser-Card-Flex-Flexible-Ribbon-Extender-Extension-Cable-/400504001453?pt=LH_DefaultDomain_0&hash=item5d3fe613ad
Then mount the card flat onto the side of the cabinet or something with screws through the holes in the PCB"
DeLuSioNaL29
Fursphere
  • Last login:February 27, 2026, 10:42:20 pm
« Reply #24 on: August 25, 2013, 09:11:28 pm »
DeLuSioNaL29
In another thread somewhere - the comment was made that these cables will not handle the bus speeds of today's high end video cards.
I have no idea if that comment was accurate or not.  I've never tried it.
CoryBee
  • Bopity Boopy
« Reply #25 on: August 26, 2013, 12:32:41 am »
Someone better tell Quiz_Kid cause he is using one with a pretty nice video card....
CoryBee
  • Bopity Boopy
« Reply #26 on: August 26, 2013, 12:37:32 am »
Oh I forgot to mention, no....no it does not effect the performance of your video card. It would if it was much, much longer.
But if you want you can test it for yourself using benchmarking software. With and without the riser to see if there are any changes.
Fursphere
« Reply #27 on: August 26, 2013, 05:59:32 pm »
In that picture the ribbon cable isn't plugged in... :)
Thanks for the info.
CoryBee
  • Bopity Boopy
« Reply #28 on: August 26, 2013, 06:58:14 pm »
I noticed that too, but it looks like he has a slot cut out for it so all is well.
