Author Topic: Possible MAME PC?  (Read 1792 times)
xads308
  • Last login:July 22, 2013, 04:46:12 pm
  • He's on the dance floor.
Possible MAME PC?
« on: July 22, 2013, 01:48:51 pm »
Not sure if this is the right place for this, but I need an opinion: http://pcpartpicker.com/p/1jqnv
How does that look for a MAME PC? I want something that's good for all the old games, as well as the new ones (I'd LOVE to be able to play Blitz on this thing, though from what I've heard it's a difficult process to get those 3D games to run on even top of the line machines). So, what do y'all think of this build? Will it work well for MAME? Also, I was thinking of getting an arcade VGA card instead of the card I've got selected...how would that affect performance
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
Re: Possible MAME PC?
« Reply #1 on: July 22, 2013, 02:04:53 pm »
I have a core 2 duo 3.0Ghz, it would not run Blitz as It was too choppy. I ditched the idea of running Blitz on it as well as Gauntlet Legends... that is until I can get something fancy enough to run them.
« Reply #2 on: July 22, 2013, 02:08:32 pm »
For Blitz, go into the service menu and disable Interlaced Video.
That and using the 64-bit version of MAME makes a pretty big difference on that particular game.
xads308
« Reply #3 on: July 22, 2013, 02:15:11 pm »
Are you talking about the MAME service menu, or the Blitz service menu?
« Reply #4 on: July 22, 2013, 02:18:23 pm »
Blitz service menu.
EDIT:  and 2.83Ghz probably isn't going to cut it.  The 3.0Ghz just might if it has a 64-bit OS & there aren't any other processes running in the background.  With a little overclock, I'm pretty sure it could.
« Last Edit: July 22, 2013, 02:22:30 pm by BadMouth »
« Reply #5 on: July 22, 2013, 02:34:14 pm »
run the PSX or DC version of Blitz and the DC version of Gauntlet Legends.
xads308
« Reply #6 on: July 22, 2013, 02:56:39 pm »
I've got a 2 player 6 button/player set up, is there enough buttons to define all the controls for the PSX version?
As for my CPU, if I did want to try emulating Blitz thru MAME instead of PSX, would an i3 or an i5 processor cut it?
« Reply #7 on: July 22, 2013, 03:13:23 pm »
Depends on the speed.  Saying i3 or i5 means nothing.  You really need to get up in the 3.5-3.8Ghz range to run the more demanding 3D games.
Keep in mind though that you're spending hundreds of dollars more to add a half dozen games in MAME.  If you have an OS newer than XP and decent video card, you can run Demul which would add a dozen or two more (which actually work right).  If you're interested in PS2 emulation, then it may be more worth your while.
« Reply #8 on: July 22, 2013, 03:15:36 pm »
PSX version uses 3 action buttons and start.
xads308
« Reply #9 on: July 22, 2013, 04:46:12 pm »
Thanks for all of the information! I'll probably stick to using the PSX/Dreamcast emulators as opposed to MAME. As faithful as I'd like to be to the classics, I still have to stay rational about it.
