Author Topic: Heavy Victory Ikari Time Barrel Warrior Soldiers Road 'Cammo Edition'  (Read 81001 times)
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
Re: Heavy Ikari Barrel Warriors 'Camo Edition'
« Reply #120 on: July 25, 2013, 12:25:15 pm »
Griffin Maximus never saw a blank space he liked.  :cheers:
It's true, "you could put a cup holder there"
« Reply #121 on: July 25, 2013, 01:03:59 pm »
I will lose all respect for you if you don't post a photo of yourself playing this cab while wearing one of these 80s bad boys:
Maximus
    • Arcade Icons
« Reply #122 on: July 25, 2013, 01:06:15 pm »
while doing this...
Maximus
    • Arcade Icons
« Reply #123 on: July 25, 2013, 01:39:15 pm »
Time to turn a bug into a feature.
I accidentally put the P1 and P2 start buttons too close to the fire/grenade buttons on the CP and it's been bugging me ever since. But then when I got my multi-jamma board I saw that it had a little toggle switch to flick between the two game boards and that got me thinking.
So what I'm going to do is move the P1 and P2 buttons up to where they should be and then build a little plate, probably clear acrylic with graphics underneath that will cover the two holes where the P1 and P2 buttons were. In the middle of the plate will be the switch to toggle between games with each game logo set either side.
Now of course you don't want to accidentally hit that switch when button mashing in game, so what better reason could you need to put in  a good old military style covered toggle like this one...
This should bring some nice themed hardware, graphics and function to the CP while covering up my little oopsie.
Maximus
    • Arcade Icons
« Reply #124 on: July 25, 2013, 02:39:02 pm »
Switch panel design.
TopJimmyCooks
« Reply #125 on: July 25, 2013, 04:16:38 pm »
You know I love your work, and I don't give a crap about originality, but you've made a hash of your NOS CP overlay.   It's such a cool game cab, It rates reprinting the cp overlay with the switch logos and the right hole locations.
Choose carefully on the switch covers.  Every one I've seen moves the toggle bat switch back to the original position when closed.   IE if you switch it towards the cover, then push on top of the red cover or hit by accident, it goes back to the original position/game.  You could probably beat that by putting a latching small pushbutton switch under it instead of a toggle.
Maximus
    • Arcade Icons
« Reply #126 on: July 25, 2013, 04:23:57 pm »
Yeah the CP overlay was a NOS one that I got from Fizgig, the problem for me was finding the right Dynamo CP pattern to match it properly, there are so many damn hole patterns out there. I'll keep a look out as I go, hopefully one day I can find the proper Ikari CP hole layout and can redo it properly, but until then I'll just roll with what I already have.
I'll check out that switch cover when it arrives and see if it's an issue. Thanks for the heads up on that.
Dawgz Rule
« Reply #127 on: July 25, 2013, 04:31:05 pm »
Nice build.  If the CP upsets you too much, I can drive cross country to pick it up.  It would be nice to see my old stomping grounds (La Mesa).
Maximus
    • Arcade Icons
« Reply #128 on: July 25, 2013, 04:40:41 pm »
Nice, we are in Escrow on a house on the border of El Cajon and La Mesa right now, nice area.
  • Last login:Today at 05:01:03 pm
« Reply #129 on: July 25, 2013, 06:23:12 pm »
Love the switch idea!  :cheers:
Maximus
    • Arcade Icons
« Reply #130 on: July 27, 2013, 08:26:48 pm »
Tonight I'm going to try and make my own multi rotary harness out of all this stuff
Maximus
    • Arcade Icons
« Reply #131 on: July 28, 2013, 01:26:04 am »
Board built harnesses next.
Maximus
    • Arcade Icons
« Reply #132 on: July 28, 2013, 01:33:00 am »
Maximus
    • Arcade Icons
« Reply #133 on: July 28, 2013, 12:47:20 pm »
Well crap. This project seems to be a little cursed. The female pins I ordered seem to be too big for the connector blocks. When I try and push the pin into the block, the square housing at the back of the pin is just a bit too large for the opening in the block itself. Very frustrating.
« Reply #134 on: July 28, 2013, 02:33:34 pm »
Yup. NH series terminal pins won't fit in XH series connector housings. You need these pins for the housings you ordered: http://www.digikey.com/product-detail/en/SXH-001T-P0.6/455-1135-1-ND/527370
But turns out you ordered the wrong connector housings to begin with. Scott gave you this part number for the connector housings: http://www.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=H13P-SHF-AA
Which will work with the pins you already have.
« Last Edit: July 28, 2013, 02:36:26 pm by Nephasth »
  • Last login:Today at 02:45:09 pm
« Reply #135 on: July 28, 2013, 02:58:31 pm »
It's frustrating because the links I sent were for an NH series receptacle and pins.
Here's what I ended up buying
http://www.digikey.com/product-search/en?WT.z_header=search_go&lang=en&site=us&keywords=455-2214-ND&x=-1111&y=-51
and
http://www.digikey.com/product-detail/en/SHF-001T-0.8BS/455-1121-1-ND/527350
First link is for an XH series connector -- I believe the XH series pins you need for that are here if you want to use them for another project, but confirm on the datasheet before you order.
The good news is that the second link is for NH series pins that correspond with the P/N I posted.
The bad news is that I haven't found a source other than DigiKey here for the NH series receptacle -- minimum order is 500 pieces for $105.87.
Right now you have 2 joysticks = 2 harnesses = 4 connector ends.
You need 6 connector ends -- 2  for joysticks, 2 for Ikari Warriors, and 2 for Heavy Barrel.
As much as I hate to suggest hacking up perfectly good harnesses, if you could find one more, you can cut the three harnesses in half and splice in extensions that connect to the diode/splitter board.
« Reply #136 on: July 28, 2013, 03:01:03 pm »
Is your Google broken?
http://www.chip1stop.com/web/USA/en/dispDetail.do?partId=JST1-0002457&utm_medium=cpc&utm_campaign=aggregator&utm_source=fc&utm_term=JST1-0002457&cid=fc_JST1-0002457
« Reply #137 on: July 28, 2013, 03:13:38 pm »
Sometimes you can order free samples. It's worth a shot to find out if that's possible, if not from DigiKey, but from the manufacturer directly.  :cheers:
« Reply #138 on: July 28, 2013, 03:25:23 pm »
D'oh!  Missed that one.  Great catch.   ;D
Hope the shipping from Japan doesn't cost too much.   :o
EDIT:
As I suspected.
Region/Country   Order Amount         Shipping Fee (per shipment)
NORTH AMERICA  Any order amount   JPY5,000 or USD60
Any other sources?
« Last Edit: July 28, 2013, 03:33:10 pm by PL1 »
« Reply #139 on: July 28, 2013, 03:31:31 pm »
That's why I prefer Molex over JST. ;)
Maximus
    • Arcade Icons
« Reply #140 on: July 28, 2013, 04:10:13 pm »
This is all rather complicated to the uninitiated but I'll get there.  I do have spare harnesses laying around, one is already cut in two so I'll give that a go
Maximus
    • Arcade Icons
« Reply #141 on: July 28, 2013, 05:03:35 pm »
Something is still wrong. I took an existing harness and just rearranged the pins so it was a straight-thru configuration. I attached the original joystick harness to the newly made board with the jumper on pin one, then used the straight thru harness to go from the multi-rotary board to the game board. No matter what I did I couldn't get any rotation responses. I tried it in both directions through the diodes in case I had them the wrong way around but still nothing  :banghead:
mcseforsale
  • Creepy Mario Dude
« Reply #142 on: July 28, 2013, 06:12:03 pm »
Heh.  NOOB!
Subscribed.
AJ
« Reply #143 on: July 28, 2013, 06:57:19 pm »
You probably have all the diodes pointing the same direction, which means that either one diode was reverse biased or 12 were, depending on how they were pointing and whether the joystick was plugged into the green or yellow connector below.
Remember that the band on the diode looks like a minus sign.
Put the minus sign toward the lower voltage (ground) like below to forward bias the diode when ground is applied so current flows and the diode acts like a closed switch.
In this diagram, the voltage from the signal line comes in on the second signal line, connects to the center wiper and goes back to the board through the ground wire.
EDIT: Updated the diagram to include the joystick connector (yellow), the two game board connectors (green, blue), and the proper number/location/orientation of diodes.  Thanks for catching my earlier error, Neph.
« Last Edit: July 28, 2013, 07:52:49 pm by PL1 »
« Reply #144 on: July 28, 2013, 07:05:52 pm »
There is no diode on the ground, Scott.
Here's a straight on shot of one of the 2600 kits for reference:
Between each header (except the last one and the one above it) there are 25 traces. You sure you got your circuitry right?
« Last Edit: July 28, 2013, 07:17:40 pm by Nephasth »
« Reply #145 on: July 28, 2013, 07:22:18 pm »
D'oh!
Didn't notice the direct jumper on the ground line earlier.
Is ground line on the joystick connected to the direct jumpered line on the board and does that line then connect to the ground on the Ikari Warriors board?
Seems like it would be easy to twist a connector around the wrong way.   :dunno
Maximus
    • Arcade Icons
« Reply #146 on: July 28, 2013, 07:44:22 pm »
I'm going to do some multimeter testing on this and see what's up.  Either the diodes are messed up or the connector blocks are not mating with the pins on the board
Maximus
    • Arcade Icons
« Reply #147 on: July 28, 2013, 08:24:58 pm »
Something is seriously wrong with the board I made its conducting between all pins. On closer inspection it looks like there may be a inner rail across the contacts which means I just wasted 4 hours of going blind
See the fine light green rails under the surface?
« Reply #148 on: July 28, 2013, 09:50:24 pm »
...which means I just wasted 4 hours of going blind
That took 4 hours to solder? :dizzy:
Looks like there's 4 "sections" to the board. If you desolder everything and rotate the board 90 degrees, you could make it work.
Re: Re: Heavy Ikari Barrel Warriors 'Camo Edition'
« Reply #149 on: July 28, 2013, 09:56:17 pm »
Griff's fast. That would have taken me 6 hours.
mcseforsale
  • Creepy Mario Dude
« Reply #150 on: July 28, 2013, 10:19:32 pm »
Griff's fast. That would have taken me 6 BEERS.
There FIFY.  You're welcome.
AJ
« Reply #151 on: July 28, 2013, 10:22:19 pm »
You called it on the traces, Joel.
Looks like you may need to desolder, turn everything 90 degrees, do a few cuts (red) to the board, and resolder everything with the diodes and ground jumper bridging the cuts.
CoryBee
  • Bopity Boopy
« Reply #152 on: July 28, 2013, 11:38:29 pm »
Or take a razor blade to the traces to cut them......
Do it twice to make sure, score it next to each pin
Try it on one and check if it the multimeter still reads a connection between them
mcseforsale
  • Creepy Mario Dude
« Reply #153 on: July 28, 2013, 11:43:51 pm »
Yeah +1000.  Why kill it when you can do it cheap and dirty.  It's an obscure part, so noone will know.  Cept for us   :timebomb:
AJ
CoryBee
  • Bopity Boopy
« Reply #154 on: July 28, 2013, 11:52:57 pm »
Sometimes the "Schmart" boards.................Aren't so "Smart"
YEEEEEEEEEEEEEEEEEEAAAAAAAAAAAA!
« Reply #155 on: July 29, 2013, 12:05:08 am »
AJ
You guys did notice that the red cuts don't go all the way across the board, right.
In case I didn't state it clearly before, you're advocating doing the same thing I suggested -- cutting the traces to isolate the center section.
CoryBee
  • Bopity Boopy
« Reply #156 on: July 29, 2013, 12:08:50 am »
AJ
Oh.....Great minds and all??  :dunno
Maximus
    • Arcade Icons
« Reply #157 on: July 29, 2013, 12:34:45 am »
Either way I can't get under so I'd have to pull it all apart. Fortunately I ordered 100 diodes and only need 48 for the build so i have enough for another shot.  I just need to find the proper breadboard without any traces.
Good news is that I do have a very nice working Ikari Warriors at least lol
« Reply #158 on: July 29, 2013, 07:58:41 am »
AJ
Further proof nobody reads your posts that carefully unless Rush is involved.   :laugh:
Maximus
    • Arcade Icons
« Reply #159 on: July 29, 2013, 01:17:25 pm »
Ok ladies, glad you are all having fun  :angry:
Just to verify, I'm going to buy these pins to go with the connector blocks I already have...
http://www.digikey.com/product-detail/en/SXH-002T-P0.6/455-2261-1-ND/1651059
These new headers, because ---fudgesicle--- it I may as well start over...
http://www.digikey.com/scripts/DKSearch/dksus.dll?Detail&itemSeq=134141228&uq=635106966231654104
And this for the Perfboard (finally worked out the right term for this stuff)
http://www.digikey.com/scripts/DKSearch/dksus.dll?Detail&itemSeq=134142909&uq=635106981113818017
« Last Edit: July 29, 2013, 01:52:00 pm by Maximus »
