Author Topic: First arcade cabinet project - Newbie  (Read 3441 times)
Terr1
  • Last login:September 19, 2016, 04:06:57 pm
  • Building my first cabinet
« on: July 12, 2013, 12:51:49 pm »
Hey
I always wanted a MAME cabinet, and last year I bought a DIY 2 player full size kit from a fellow arcade builder, since I have ZERO tools / woodsworking skills :)
His model looks like this:
 (Pictures taken from bsam.dk)
I will make mine black instead of white, and some aluminium or red T-mold, and when the time comes, I will create my own control board decal. I will use the same top/screen decal for now though.
So after a year I thought I might use my vacation for something useful and started to work on my future arcade. The DIY kit I bought had the large cabinet sides pre-cut as well with CNC cut holes for the different fronts/shelves needed.
The first side completed:
The second side being prepared:
The rest of the items waiting to be put together:
My prototype control board, it seems to work fine:
I’m using cheap Zippy sticks and IPAC-2 and cable shoes, haven’t done any soldering yet, since it’s a prototype. I got the PC and all the software running (hyperspin + emulators).
I think I want two 4” car speakers at the top, instead of some default pc speakers, it looks better imo., esp. with front grills.
I have zero experience using car speakers, I saw some post here recommended this cheap amplifier:
http://www.ebay.com/itm/Brand-New-2CH-Mini-Audio-Digital-Power-Stereo-Amplifier-AMP-/360668006787
Then I need to find out which speakers would work with this. It seems the amplifier outputs 2x20W, most speakers I have seen is 80W+, will these work with 20W? Or do I need to find some with less watt?
wordsworth
  • Last login:March 01, 2026, 03:05:28 am
  • ...was severely wounded, but the soul still burns
Re: First arcade cabinet project - Newbie
« Reply #1 on: July 12, 2013, 05:59:15 pm »
It's fine and actually preferred if the speakers have a higher wattage rating than the amp. The amp can exceed the rating in bursts and having speakers that can handle those spikes is a good idea.
Terr1
« Reply #2 on: July 17, 2013, 07:19:55 am »
Now I got my cabinet up and standing at least..
Still needs paint job and artwork stuff..
Falk3r
  • Last login:February 26, 2017, 02:55:28 pm
  • Building First Cab Now (2013)
« Reply #3 on: July 17, 2013, 08:36:36 am »
Lookin' good, man. Can you provide any details on pricing for the kit and who you bought it through? (assuming they have an online store) Sometimes I just like to see how foolish I was to go the "from scratch" route.
Any chance I can talk you into sourcing a larger monitor to pop in there? When that starts pushing out the vertical games, it's going to feel like a tight fit.
Terr1
« Reply #4 on: July 17, 2013, 09:47:59 am »
It was pretty expensive, but not many choices in Denmark, and since it was my first build and I never touched tools before, I went for the safer route.. My next build will be the utilmate cabinet style, because its larger and I can get a bigger control panel. It was about 500$ with marquee and artwork except sides.. Ive spend the same on tools though :)
Power drill
Clamps
Router
Round saw
Jigsaw
Spadedrills, frostner drills, holesaw...
At least I got the tools to manually make the next one if I want to :)
What screen size would be recommended.. I guess 4:3 is prefered? The current is 19" 4:3.
My 19" 4:3 have more vertical screen size than my alianware 23" 16:9.
« Last Edit: July 17, 2013, 10:06:02 am by Terr1 »
Falk3r
« Reply #5 on: July 17, 2013, 10:05:28 am »
Hmm... yeah... on second thought, if you've got the 19" ready to go, it's probably not worth the trouble of finding something larger. For a few reasons:
1. It doesn't look like a big old CRT would fit in there
2. 20~21" 4:3 LCD monitors are about as big as they come -- and get very expensive very quickly
So, it's probably not worth another $500 for another 1~2" of diagonal screen size.
$500 for the kit doesn't sound bad at all... I probably spent $200 on MDF, $250 on laminate (expensive mistakes), $50 on screws and glue... and I don't want to add up all the new tools I've bought for my build.
CaptainMarvel
  • Last login:May 03, 2020, 04:49:55 pm
« Reply #6 on: October 02, 2013, 04:55:35 pm »
Wow ... That seems like a lot.  Is it because of the geographical location in which you live?
TOM
Understanding that you may not see success instantly, but that all your good decisions add up to a cumulative success over time is what separates those who "get there" and those who don't. Every day you either get further away from your goals, or closer to them . . . Its up to YOU."
