Author Topic: Star screw with dot in the middle  (Read 7730 times)
fluentd
  • Last login:October 20, 2014, 07:30:41 pm
« on: June 22, 2013, 09:37:15 pm »
Where can I find the tool to unscrew this? I came across it on ebay but cant find it.
  • Last login:Yesterday at 11:28:34 am
    • GroovyGameGear.com
Re: Star screw with dot in the middle
« Reply #1 on: June 22, 2013, 09:51:43 pm »
It's a "security torx".  The easiest is to pick up one of these.  Handy for all kinds of things.  Just make sure it has the size you need.
fluentd
« Reply #2 on: June 23, 2013, 02:59:48 pm »
ok great, I have a HF a few miles from my house.  Thanks a lot.
kane916
  • Last login:January 25, 2026, 12:30:36 am
« Reply #3 on: June 24, 2013, 01:20:07 am »
Sometimes a small flat head screwdriver can also be used to break the dot in the middle so a normal star bit or sometimes even a allen key can be used. That's only if you are really impatient like I am sometimes.
CoryBee
  • Bopity Boopy
« Reply #4 on: June 24, 2013, 03:55:33 am »
I admit, I do this.
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #5 on: June 24, 2013, 04:29:51 am »
I heavily dislike security screws. I had to fix one of my sons Thomas trains. Thought it would be a quick fix but then I found the triangle head screws. Took me a week to find a place locally that carried the right bit.
Plus side is that I now have a set that can handle any security screw.
Sent from a pineapple under the sea
« Reply #6 on: June 24, 2013, 06:42:02 am »
Home Depot carries a security torx driver with a bunch of bits that fit in the handle.  It was $10 or so, one of my most used tools.  I do need to pick up the triangle bits, but I just use a small flat head on those most of the time.
knave
« Reply #7 on: June 26, 2013, 05:22:30 pm »
I picked one of those up a few years back, works great, you never know when you'll need it.
jdbailey1206
« Reply #8 on: June 27, 2013, 07:07:56 am »
These screws seem to be more common anymore.  I picked up one of these http://www.homedepot.com/p/Klein-Tools-Magnetic-Screwdriver-with-32-Bit-Set-32510/100648026#.UcwbJPl9CSo at Home Depot.  I can't say how many times I have relied on this set.  I have used the Mor Torq screwdriver heads the most for regular stubborn Phillips head screws.  Plus being the go to iPod fixer in my family the smaller torq or security screw driver heads come in handy as they are becoming more frequent in the newer generation iPods.  Hell I even found a torq head screw yesterday when I had to exchange the heating element in my stove for a new one.
If nothing else I would buy just the bit set without the screwdriver to be safe.
