Author Topic: R-Kaid-Revelation (2/12 Final photos and video!)  (Read 72623 times)
  • Last login:Yesterday at 04:34:18 pm
Re: R-Kaid-Revelation (18/9 new blind construction)
« Reply #160 on: September 18, 2013, 02:26:06 pm »
I have no idea what you're doing, but it looks damn sexy.
« Reply #161 on: September 18, 2013, 02:30:45 pm »
quizz_kid
  • Last login:January 01, 2016, 03:10:29 pm
  • In the year 20XX...
    • http://www.lovehulten.com
« Reply #162 on: September 20, 2013, 08:22:20 am »
You have no idea? Well me neither!! =)
quizz_kid
« Reply #163 on: September 21, 2013, 07:49:12 am »
Some more progress:
Made the upper axis shaft for the blind construction. Since it will be visible, I choose copper of course. I will try to test this new construction next week.
Here are close ups / Left=bearing / Right=motor
And here's the top piece mesh, repainted.
4x120mm fans mounted. You can see the fill port in the middle.
And here's a test fit with the keyboard/storage unit on top.
Another shot...
Here's a VGA cable for the projector which I had to mod some, due to some lack of space.
And here is my "lens-focus-dial-extender" Tech Lego and some distance pieces, all very DIY :D
Here's how it works, pretty simple...
Just use the lens protection/screwdriver...
... and adjust the focus by screwing. Quite proud of the solution :dremel:
Laterz
//Quizz :lol::lol::lol:
Re: R-Kaid-Revelation (21/9 more progress)
« Reply #164 on: September 21, 2013, 09:55:43 am »
*sigh*
It's getting to the point that I open the quizz_kid thread, and want to go all Deer Hunter. Who can compete with this??!
 :dizzy:
  • Last login:Today at 01:01:52 am
« Reply #165 on: September 21, 2013, 02:08:19 pm »
I didn't realize BYOAC was a competition. >:D
I enjoy the level of craftsmanship in everyone's builds.
« Reply #166 on: September 21, 2013, 02:31:01 pm »
I blame all those D-bags on the UCA panel. ;)
« Reply #167 on: September 21, 2013, 03:01:10 pm »
HAHAHA. Damn UCA panel!
What I meant was I hate hearing people get down on their own projects comparing then to others.
« Reply #168 on: September 21, 2013, 04:15:31 pm »
Nice focus "pot".  :cheers: Doesn't hand/knob obscure the picture of the lens while adjusting though?
quizz_kid
« Reply #169 on: September 24, 2013, 01:29:13 pm »
No, not really, unless you have fingers like chorizos :) But it's not the most ideal placement for a focus dial I guess.
quizz_kid
« Reply #170 on: September 28, 2013, 07:47:11 am »
More progress:
Intstalled the PSU today, the Be Quiet! 550w. Just realized I got lots of cables in this build. Got the PC setup, projector, speaker system, LCD, lighting modules, joystick pads etc... Can't believe I'm actually going to fit everything in there.
Here's a shot where you can see the two holes for cable management. The mess you see here are cables for some switches and the projector.
I installed the LEDs. Decided to have two strips for increased lighting, and then use the dim knob for reducing if needed.
Some strip soldering.
Here's a quick test using the remote. Red...
... and blue.
Then I continued on that new blind contruction. Here are some cover pieces in walnut...
Outer side panel. The small motor is mounted into the cover piece with epoxy, a perfect fit.
With everything installed, I attached two cords to the blind. This was actually very tricky, and took me about two days to get it right. First I had to find the right type of cord. Tried several, fishing line, boat rope, regular sewing cotton    etc. I realized I couldn't use any elastic cord, due to the weakness of motor I think. When using fishing line, I got sort of a springback from the tension. I finally got it right using this one, a natural string.
Getting the alignment right took me several tries, but here it is.
You can see the space I had to work with here. Between fans and shaft there's aprox 2mm of margins.
The transparent LCD need backlight to work, so I had to place the sprips with presicion. Here's the blind pulled out to its limit, and you can see the light strip sneaking up just in front of the canvas.
Last shot it with walnut bezel installed. I'm happy I managed to get the blind up as far as I did, covering almost the entire screen. The blind construction has been a real pain, but this is what you get when adding a new element this late in a process.
Now I have to find and install some limit switches for the blind... Then it's time for final assembly :lol::lol::lol:
Re: R-Kaid-Revelation (28/9 UPDATE)
« Reply #171 on: October 03, 2013, 08:34:51 pm »
Build quality aside (which is outstanding)  I love the radical thinking that goes into this project, both beautiful and functional, sure motivates me!
blueznl
« Reply #172 on: October 07, 2013, 12:06:56 pm »
This is soooo depressing...  :notworthy:
lcmgadgets
« Reply #173 on: October 10, 2013, 12:00:10 pm »
That the mighty Ond himself is impressed is...impressive.
Professor Hayashida
rablack97
« Reply #174 on: October 10, 2013, 01:38:34 pm »
 :puke It's just flat out sickening.....
quizz_kid
« Reply #175 on: October 10, 2013, 06:13:24 pm »
Thanx guys, really appreciate the feedback!
Got hose limit witches working. Still waiting on a smaller delivery, but should have an update real soon.
//Quizz
quizz_kid
« Reply #176 on: October 11, 2013, 09:28:10 am »
I have a question about UV. I just got my purple UV LED strip today, and it doesn't seem to react with the coolant, at all. The coolant I'm using is the "Feser One 1L UV Black". I've never worked with UV before, but shouldn't it react?
quizz_kid
Re: R-Kaid-Revelation (11/10 UV question)
« Reply #177 on: October 14, 2013, 01:18:30 pm »
Well, seems like the Feser Black UV is pretty sad when it comes to UV reaction. I thereby decided to ditch the UV idea. Well well...
But I have an update:
First, I made some minor adjustments in the loop layout. Removed one of the res mounts, moved the res a bit more to the right. This was to get the fillport centered.
Here's another shot. As you can see I've drained the loop. Will make a refill when everything assebled.
A 2mm sheet of glass...
And here's the transparent LCD, finally ready to be mounted inside the chassis.
A good fit I suppose. You can see the PCB of the LCD touching the blind construction. No margins, what so ever =)
Short flat cable, HDMI.
A pretty good fit there as well.
Then finally, I could put the two chassis segments together and see the resluts of 1000+ hrs.
The backside, well, need some serious cable management. There's cables EVERYWHERE, don't know where to start really =) Give me few more day...
Until then, here's some quick tests playing with the RGB strip.
Green
Purle
//Quizz
Brian74
  • Yep... I built that!!
Re: R-Kaid-Revelation (14/10 Transparent LCD)
« Reply #178 on: October 14, 2013, 02:28:36 pm »
 :woot  :notworthy:
rablack97
« Reply #179 on: October 14, 2013, 02:57:50 pm »
 :puke
« Reply #180 on: October 14, 2013, 03:36:27 pm »
Makalöst.  :notworthy:
« Reply #181 on: October 14, 2013, 03:59:52 pm »
quizz_kid
mcseforsale
  • Last login:Yesterday at 04:10:51 pm
  • Creepy Mario Dude
« Reply #183 on: October 15, 2013, 10:46:12 am »
Y'all talk funny.  A'int this a 'Merican forum? (in my best deep south twang)
Excellent work!  Oh, and that workshop is amazing.  Even the view of the area its in is the business.
AJ
quizz_kid
« Reply #184 on: October 22, 2013, 02:45:01 pm »
AJ
Thanks AJ
Update:
Been having some real issues with the transparent LCD. I don't know if the PCB is damaged or something. It worked a week ago, but now it will not operate. With the original 5v power supply, nothing happens. The LED on the supply lit when connected to the wall, but starts to blink as I plug it into the LCD. When I then tried using a 5v line from the PSU instead, the LCD works. But after a few seconds, I smell somethings burning, I see a little smoke coming from the LCDs PCB and I disconnect it. Did this 3 times, trying to locate the damage somehow.
Here's a close up of the PCB. It was hard to determine the source of the smoke, but it's one of the component inside the red circles.
Here's the original plug connected(used the same plug when using 5v line on PSU), and you can see that is does not go all the way in. I don't think it has anything to do with it, but I need all the help I can get here.
Any thoughts?  :sigh::sigh::sigh:
mcseforsale
  • Creepy Mario Dude
« Reply #185 on: October 22, 2013, 04:49:03 pm »
Has the center electrode INSIDE the jack been bent over?
AJ
quizz_kid
« Reply #186 on: October 22, 2013, 07:33:37 pm »
I can check tomorrow, but could that really be the issue?
Generic Eric
« Reply #187 on: October 22, 2013, 09:34:04 pm »
I've seen that be a problem on a CD player.
AGarv
« Reply #188 on: October 23, 2013, 01:42:21 pm »
Amazing as always - looking forward to seeing that transparent LCD fired up and displaying games!
mes83
  • Last login:January 14, 2019, 01:57:20 am
« Reply #189 on: October 24, 2013, 02:10:14 pm »
Absolutely amazing work. Love the craftmanship.
Your mouse almost resembles an old Amiga mouse. Just angle the sides a little and it will be perfect.
Cannot wait to see your next update.
quizz_kid
« Reply #190 on: November 10, 2013, 07:26:30 am »
Thanks guys. I've got a strange boot problem.
While working on Revelation, I have to keep it upside down due to the construction. Everything works fine upside down. But as soon as I flip it around, I cant get it to boot. I get the classic start up with everything's running for 5 secs, no display, then reboots, over and over again. What could be the issue here?
I have no ideas, at all. Something is triggered when I flip the computer around I guess, but what? So strange, because everything seems to be in place. I'm desperate, and open for any guesses right now.
a1pharm
Re: R-Kaid-Revelation (Strange boot behavior)
« Reply #191 on: November 10, 2013, 09:28:50 am »
Make sure you aren't somehow shorting the power button circuit.  If you are, it will do exactly what you describe.
quizz_kid
« Reply #192 on: November 10, 2013, 01:32:07 pm »
Yeah, I'm ggoing to look into it more tomorrow. But why would it short only when the chassis is turned upside down. There's no pressure on the power cable or anything. Well, will look into it tomorrow. Thanks!
quizz_kid
Re: R-Kaid-Revelation (Sorted out)
« Reply #193 on: November 26, 2013, 03:32:44 pm »
The issue is sorted out, finally. It was one of the RAM sticks actually. During first leak test I must've been sloppy, and a single drop of fluid got into the RAM connectors.
Got new sticks now, and I'm back on track. I can finally finish this beast...
I made a refill using the new fillport on top.
And then I made a backplate in stained ply for final touch.
Final pictures coming up next!!
Re: R-Kaid-Revelation (Time to finish this one!)
« Reply #194 on: November 26, 2013, 04:41:38 pm »
The magnificent machine!  I imagine archeologists uncovering this in a dig a thousand years from now interpreting its purpose.....
quizz_kid
« Reply #195 on: November 28, 2013, 06:36:10 pm »
 ;D Yeah, lets hope so. The people of earth will find true meaning... A greater, future arcade culture will rise, and cure the world, once and for all!!!
« Last Edit: November 28, 2013, 06:38:00 pm by quizz_kid »
quizz_kid
« Reply #196 on: December 01, 2013, 08:05:42 pm »
Over 1000 hrs went into this machine. Had a lot of setbacks in the end, but I guess it was worth it.
Well, here are finals... Hope you'll enjoy!
R-Kaid-Revelation
Video demonstration(Music credits: Turrican scores performed and supported by Chris Huelsbeck)
https://www.youtube.com/watch?v=Da8c2uauncA
Making of video
//Quizz
TopJimmyCooks
Re: R-Kaid-Revelation (2/12 Final photos and video!)
« Reply #197 on: December 01, 2013, 08:43:08 pm »
Really incredible - both the woodworking and the overall design are superlative.  I love the complications of the roller shade, the onboard controllers and the overall packaging.
« Reply #198 on: December 01, 2013, 10:11:53 pm »
Congratulations on a really original, interesting, and finely crafted project quizz_kid.  I've suggested it before, but you've managed to combine some highly talented wood and metal work with a kind of super geek design approach which fires the curiosity and imagination.  Much more than just an arcade machine, it’s also great art and I’m sure a talking piece for years to come.
« Last Edit: December 01, 2013, 10:15:11 pm by Ond »
mgb
  • North East, US
« Reply #199 on: December 01, 2013, 11:42:48 pm »
I kinda looked in on this one a couple of times and was like, yeah its nice. wood working is slick but whats the point.
tonight I took the time to look deeper and I watched the video.
Awesome. very off beat and nutty. Job very well done.
