Author Topic: Marquee mounting  (Read 1736 times)
mattfl
  • Last login:October 31, 2019, 05:08:11 pm
Marquee mounting
« on: November 12, 2003, 09:23:55 am »
Does anyone have any suggestions on howto mount my marquee without using the happs marquee mounting brackets??
Radical
  • Last login:March 12, 2022, 03:39:21 pm
  • Yes
Re:Marquee mounting
« Reply #1 on: November 12, 2003, 09:47:41 am »
I used 1/2" aluminum angle from Lowes.
Here's a picture (I left the dust on so you can see it better):
It was cheaper per foot than real marquee retainer.   If you have an extreme angle then it might not work as good as the real stuff but it worked great in my case.
Make sure you use an etching primer before painting aluminum or the paint won't stick.  Another less effective technique if you can't etch the surface is to sand the aluminum with fine sandpaper (like 600 or 1200 sandpaper).
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:Marquee mounting
« Reply #2 on: November 12, 2003, 01:19:09 pm »
I used the "L-bracket" used for ceiling tiles (look at figure 3 on this link  http://www.popularmechanics.com/home_improvement/home_improvement/1996/7/suspended_ceiling/index2.phtml
They come in multiple length but I think the shortest is 6 feet for 2 bucks or something like that. They paint easily (although I primed first), they drill easily so you can secure them with a couple of screws at the top, and becasue they're relatively thin, you can adjust the angle if your cab requires something that's not 90 degrees. Also because they're "folded over" they hace a nice round edge that won't scratch your plexy.
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:Marquee mounting
« Reply #3 on: November 12, 2003, 02:12:59 pm »
I'm using a U shaped bit of acrylic to hold the marquee graphic, and velcro to attach it to the cab.
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
Re:Marquee mounting
« Reply #4 on: November 14, 2003, 12:06:06 am »
I found some J shaped stuff they use in those white wire type closet organizers at my local hardware store.  It came in an 8 foot length, it's pretty heavy duty stuff.  I used a hacksaw to cut down two pieces and painted them black.  Got myself some black screws and BAM! instant marquee holder :-) If I had a picture of the stuff I would but I don't have a digital camera.
