Author Topic: Dual Arcade Controller project [FINISHED]  (Read 9061 times)
GeoMan
  • Last login:February 23, 2026, 09:18:53 am
« on: May 25, 2013, 04:45:02 pm »
I started this project almost a month ago. The goal was to build an Arcade Controller with dual joysticks and 6 buttons which was not too big to carry around.
For the project i used a TEKO 364.8 box: http://www.teko.it/en/prodotti/famiglia/PU/serie/103
The left joystick is an 8-way joystick, the right one is a Mag Stick Plus (switchable 8/4-way from the top)
I used a MiniPAC encoder: http://ultimarc.com/minipac.html
The red front button acts as a "shift" doubling the functions of the joysticks/buttons and used for actions like "Insert Coin", "Player 1 Start", "Save State", e.t.c.
AGarv
Re: Dual Arcade Controller project [FINISHED]
« Reply #1 on: May 25, 2013, 08:32:03 pm »
Looks great!  The enclosure is nifty, two questions i) where did you order it from (just saw specs at your link) and ii) are the corners "sharp" as they appear in the photos?
GeoMan
« Reply #2 on: May 25, 2013, 08:49:48 pm »
I am glad you like it.
Got the box from an electronics shop (in Greece): http://venieris.com/
The edges are sharp indeed! They pose no problem while playing as your hands rest on the panel (i used low profile rounded screws to mount the joysticks so your hand can rest on them without any problems)
TPA5
  • Last login:May 30, 2017, 10:25:16 pm
  • Wanting A Cab
« Reply #3 on: May 26, 2013, 12:46:43 am »
That's really neat! Cool usage of that enclosure, I like the artwork too. Looks as good, if not better, than some commercial fight sticks.
GeoMan
« Reply #4 on: May 26, 2013, 05:59:09 am »
Thanks! I would prefer a black box, but only the grey color boxes were available...
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #5 on: May 26, 2013, 01:49:53 pm »
That's one nifty little controller, Very nice my friend..:)  :applaud:
  • Last login:Today at 01:40:55 pm
« Reply #6 on: May 26, 2013, 08:27:14 pm »
If you still want it in black, you could use Rit Dye or spray paint for plastic.
lcmgadgets
« Reply #7 on: May 26, 2013, 09:46:51 pm »
Sweet!
Professor Hayashida
GeoMan
« Reply #8 on: May 27, 2013, 05:08:23 am »
An interesting idea with this box is that you can create replacement panels with different controls/layout/artwork.
The panel attaches to the box by 6 screws and i connected the cables on a removable pin header which clips on the encoder. So you can easily make a new panel (with a spinner for example) to replace the existing one as needed.
To make it even easier you can replace the 6 screws with 6 small magnets. You need to buy a new metal plate (besides the plexiglass & other arcade controls) for your new panel, but you will reuse the existing box and encoder (a cost of about 60€).
AGarv
« Reply #9 on: May 27, 2013, 12:34:39 pm »
Are the boxes available for purchase online?  Could only find specs at the link you posted.
kitvonsnookerz
  • Last login:June 23, 2013, 03:23:59 pm
  • Large, but not so much in charge.
« Reply #10 on: May 27, 2013, 12:40:17 pm »
Wicked sick i love it. Perfect size and nice art.  ;D
BLARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
AGarv
« Reply #12 on: May 27, 2013, 10:22:23 pm »
Thanks bud!
GeoMan
« Reply #13 on: May 28, 2013, 12:50:05 pm »
Some pictures of the project:
GeoMan
« Reply #14 on: June 04, 2013, 05:21:35 pm »
This is the first of 3 controllers i plan to make using the same size and type of box. The next one will be spinner + trigger stick and the last one buttons + trackball.
Pinball Controller: http://forum.arcadecontrols.com/index.php/topic,133067.0.html
Single Arcade Controller: http://forum.arcadecontrols.com/index.php/topic,134282.0.html
« Last Edit: August 31, 2013, 04:45:35 am by GeoMan »
