Author Topic: Cocktail control panel from wood. Any ideas?  (Read 3225 times)
bmo
  • Last login:October 24, 2013, 11:25:19 am
« on: May 14, 2013, 08:16:53 pm »
I'm in the process of building a new cocktail can but this time I'm not going to be using metal parts but rather want to build it from wood. I've built several standup cabinets but this is a new challenge and I'm not sure the best way to go about doing it.
If I run the top of the panel where buttons joysticks sit, I'll have to run t-molding horizontally across the front because of the end piece sticking out or on top (top is not an option.. looks horrible). Anyways, hoping you guys have some tips/advice for creating a fairly seamless controller. Any thoughts on 45deg angles for the wood? might be able to pull that off.
DLinkOZ
  • Last login:March 22, 2017, 08:12:46 am
    • The DaveCade
Re: Cocktail control panel from wood. Any ideas?
« Reply #1 on: May 14, 2013, 11:39:12 pm »
Could you not reproduce the angle of a metal cp?  That would make it look the same, and remove the need for t-molding.
___
That sort of angle (if it comes out in the post like it looks now while I type it).
« Reply #2 on: May 14, 2013, 11:50:50 pm »
Just sand the butt joint to the same angle as the metal panel and bondo for a seamless piece.  Just from looks nobody will be able to tell the difference.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #3 on: May 15, 2013, 09:29:09 am »
Pretty much this, but experiment several times before you touch the wood you want to use.  Sanding/Routing and Bondo should get you exactly what you're looking for.
bmo
« Reply #4 on: May 15, 2013, 10:21:25 am »
That's a great but I plan on using 1/4" plexi glass on top of the panel. Rounding it will leave that 1/4" step. Wonder if it'd be too much work to plane out the rest of the control panel down a 1/4". Rather not have to go that far tho.
« Reply #5 on: May 15, 2013, 12:16:09 pm »
Bend the plexi to the wood. It's supa easy. Lots of tutorials on here. Problemo solved.
bmo
« Reply #6 on: May 16, 2013, 02:00:34 pm »
excellent. i've decided on that now. bending the plexi over a 1/2 dowel should work great. gonna need to find a heat gun but should be cheap enough
« Reply #7 on: May 16, 2013, 08:10:57 pm »
Heat gun or butane torch, or you can even set the oven to 450 then crack the door and heat the bend area like that...but that technique is ghetto-fabu
kahlid74
    • GamersAnon
« Reply #8 on: May 17, 2013, 11:00:09 am »
Ghetto-Fabulous and a cheap ass way to Vaccum Mold plastics!
  • Last login:Today at 12:18:48 pm
« Reply #9 on: May 17, 2013, 04:20:22 pm »
Harbor Freight has this one with 12 settings from 430 - 1160 degrees.
They also have an accessory kit here.
