Author Topic: Neg's cabinet finished :)  (Read 3166 times)
chucklepie
  • Last login:September 09, 2013, 08:56:54 am
« on: May 13, 2013, 06:43:40 pm »
Hello,
Back in September last year I had no woodworking or other building skills and started out with two bits of MDF (http://forum.arcadecontrols.com/index.php/topic,122792.0.html)
Tonight I put the smoked glass on and had a game of Metal Slug. I'd like to thank you all for your help and in a way I'm quite sad it's all over (well, some MaLa bugs to iron out still.....)
Here's the first four...
chucklepie
Re: Neg's cabinet finished :)
« Reply #1 on: May 13, 2013, 06:47:57 pm »
and a few more...
Fursphere
  • Last login:Yesterday at 11:42:16 pm
« Reply #2 on: May 13, 2013, 07:02:53 pm »
Nice job!  I used the same plans to build my cabinet.
chucklepie
« Reply #3 on: May 13, 2013, 07:25:21 pm »
What plans, http://www.koenigs.dk? I started out with that design then found all the dimensions were not to my needs (too small) and it didn't have enough curves. I'll post mine up when I finish everything up as I've got some detailed numbers and drawings. Either way, this is the best design I found as it's simple yet elegant so praise to them too :)
« Last Edit: May 13, 2013, 07:31:21 pm by chucklepie »
Fursphere
« Reply #4 on: May 13, 2013, 09:40:26 pm »
Yup, 2 player upright.  I made mine deeper, as the "shallow" look didn't look right to me.  Other than that, its the same.  My control panel is 24" wide for example.
This is mine:  http://hyperspin-themes.com/images/cabpics/cab1/Fursphere's%20Cabinet.jpg
I love your Metal Slug tank girl side art too btw.
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
« Reply #5 on: May 14, 2013, 02:09:17 am »
Well done sir, looks great :)
keilmillerjr
  • Web Developer.
« Reply #6 on: May 14, 2013, 02:14:43 am »
That would be awesome if you had some schematics as I really like the design of your cab! The theme is very cool too. Great job!
monkeychunkuk
« Reply #7 on: May 14, 2013, 09:18:54 am »
Great work, a lot of hard shows in every part of your build, i know that sad feeling as you do the final touches to a machines maybe thats why I'm on my 4th build ; )
Just wanted to say thanks for the build videos its thanks to your great T molding video that made me tackle my own cabs and add T molding
chucklepie
« Reply #8 on: May 14, 2013, 01:05:07 pm »
Other than to finish it off I think T-molding is essential because it just feels right when you put your hand on it to rest or hit the side flipper - clean, smooth and comfortable.
But yes, I couldn't believe how easy the t-molding was either. Literally took 30 seconds to get the perfect groove. My only problem is the t-molding I bought has a wider groove (3/32) so I'm unsure if the cutter will be too big for a standard sized one (1/16th) to fit for when I do my mate's cabinet........ I suppose there's always glue  ;D
  • Last login:Today at 01:53:38 am
« Reply #9 on: May 14, 2013, 01:19:37 pm »
Don't be a chucklehead, Chucklepie.   :whap
Get the right tool or have your mate get it since it's for his cab.
Locke141
  • Never grow up.
« Reply #10 on: May 14, 2013, 01:58:59 pm »
Looks great.
paigeoliver
  • Awesome face!
« Reply #11 on: May 14, 2013, 03:33:35 pm »
Looks wonderful. My only suggestion would be perhaps to add a coin door where that invader is just to balance the look out.
chucklepie
« Reply #12 on: May 15, 2013, 04:02:14 am »
I wanted one but they're so expensive. I couldn't justify £40 for a non-functioning cover. I'll possibly add more vinyl later.
« Reply #13 on: May 15, 2013, 06:05:11 pm »
How about this:  http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=308
And two of these:  http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=295
I believe garnerb350 did this in his setup:  http://forum.arcadecontrols.com/index.php/topic,90308.msg948180.html#msg948180
D
chucklepie
« Reply #14 on: May 16, 2013, 07:53:16 am »
Cheers, they do look ok, but not stocked in UK I think. The real front-doors are sold but the delivery is more than the cost of the door.
On a different note, I'm just getting sick of MaLa. The newer 1.75 beta crashes more than the 1.74 and my kids simply cannot navigate and play different games on different emulators without it falling over :(
I might move to another and I wish I never bothered with MaLa, especially as it's effectively dead - I tried to contact the developer and the current 'owners' on BYOAC to take it over but got no reply.
chopperthedog
  • Last login:Yesterday at 04:22:13 pm
« Reply #15 on: May 16, 2013, 08:32:04 am »
Heh, After 7 years and 5 machines I've never actually seen mala crash.  :dunno
good day.
chucklepie
« Reply #16 on: May 16, 2013, 11:11:35 am »
I'm using the treeview mode, that was a new addition, maybe that's causing the crashes.
I get 'mala suffered an internal fault and cannot continue'. Either way, it's not supported, not updated and at some point the website will not be funded....
