Author Topic: hole sizes (electric ice-t TB, Ultralux button, Slikstik tornado spinner)  (Read 3276 times)
Jeromebechaz
  • Last login:April 05, 2017, 06:16:20 am
i looked around for these sizes but couldnt find anything, so thought it would be easier to come here.
help out if you can :) cheers
Jeromebechaz
happyfunball
  • Last login:December 11, 2015, 07:49:39 pm
i believe the diameter is about 1.25 inches. I have a bit on my drill press that will core out that size and its worked for all the buttons I have and the spinner and such.
  • Last login:Yesterday at 06:16:59 pm
Pretty sure the buttons are actually 1.125" or 1-1/8" -- standard arcade button size.
Jeromebechaz
Haha yeah I want to find out for sure!
Jeromebechaz
I have heard the spinner is smaller
Then you'd better learn to feed yourself, baby bird.   >:D
Reading the product info helps.
From the Ultimarc Ultralux page:
Standard 28-30mm mounting hole
Non-metric translation = 1-1/8"
Hint 1: Happyfunball probably answered the way he did because he didn't realize that you are getting a Tornado instead of a TT2 -- that can happen when the relevant info in the post title isn't also in the post.  ::)
Hint 2: Most spinner knobs, like the ones for Ultimarc's Spintrak, fit a 1/4" (6mm) shaft, but you may need to measure where the LEDs are if you got the illuminated Atari knob version.
Alternate method -- measure after you get it.
[/worm puking]
happyfunball
true I didn't notice that on the title. easy enough to measure everything when you get it though and work from there.
Drnick
  • Plodding Through Life
Grrrrrrr,  I even put in the thread with the Template that buttons/sticks use 28-30mm holes  :dunno :dunno :dunno
Bambam1963
  • Last login:March 09, 2024, 11:46:07 pm
  • I love this stuff man!-
Re: hole sizes (electric ice-t TB, Ultralux button, Slikstik tornado spinner)
« Reply #9 on: November 01, 2013, 10:36:27 pm »
I just got my SpinTrak from Ultrimarc this week and it fits a 1 1/8" hole, which is identical to the standard buttons.  My old SlikStik Tornado was an under-mount and I believe the shaft went through a 1/4" hole (not absolutely sure).
BamBam
I am an oldie, who used to troll here years ago.  Now I am back to tweak my machine and help a friend build his.
rocomat
  • Last login:November 25, 2019, 12:10:13 pm
« Reply #10 on: February 28, 2017, 02:16:40 pm »
[/quote]
This Atari spinner from Happ is out of production, but available at Arcadeworld UK.
It is also sold as Tornado Spinner.
Note that the led PCB at the sales pictures is mounted wrong. The leds must be shine down, not up.
That's why the knob tube is clear pastic.
And Only then you can use a about 12 mm hole for the Spinner axle.
!! Looking for After Burner Deluxe cabinet plastic parts !!
