Author Topic: XArcade Dual Joystick Pedestal Plans  (Read 41139 times)
Sionsays
  • Last login:July 03, 2013, 09:59:38 pm
« on: April 18, 2013, 12:59:34 pm »
I'm looking for some pedestal plans to accommodate the x arcade dual joystick. I tried googling it but I'm coming up empty. I want to recess the dual joystick in the pedestal then I'm going to mount a flat screen on the wall. Any plans would be great!
P-chan
  • Last login:April 13, 2022, 12:39:40 am
Arowana
  • Newbie
  • Last login:June 11, 2017, 07:25:17 pm
Re: XArcade Dual Joystick Pedestal Plans
« Reply #2 on: June 09, 2015, 08:20:00 pm »
Hi.  Have either of you got plans for this?  I'm also interested in this.  Thanks and please let me know!
  • Last login:Yesterday at 07:33:48 am
« Reply #3 on: June 09, 2015, 09:26:29 pm »
Drill a hole in the middle of this and run a carriage bolt through your X-Arcade:
Slippyblade
« Reply #4 on: June 09, 2015, 09:42:15 pm »
I don't know.  The build quality of that stool might be a little overkill for an X-arcade.
« Reply #5 on: June 09, 2015, 09:44:14 pm »
Meh, I own one and it's not too shabby.  Haters gonna hate.
Drnick
  • Plodding Through Life
« Reply #6 on: July 03, 2015, 11:54:41 am »
I presume you're talking about the Stool   >:D >:D
Moksi
  • Last login:December 07, 2025, 10:21:53 am
« Reply #7 on: November 18, 2016, 06:07:10 am »
I recently started building this xtension pedestal but i will make the entire cabinet with the top part.
What i did i search & found measurements on Ebay
Moksi
« Reply #8 on: December 29, 2016, 07:37:48 am »
latest update
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
« Reply #9 on: December 29, 2016, 09:27:30 am »
Personally,  I think the x-arcade needs to be "de-boxed", retaining the CP part and mounting that on the cabinet.  That's what I did using a variation of these plans:
http://www.lightscamerahome.com/lcd_mame_cabinet_1.html
I revised the plans to make the cab even slimmer.  I suppose if you intend to remove the x-arcade later then a typical extension type cab would work, but to me it looks wonky.  By removing the box part you achieve a more integrated look.  If you go the extra mile to cover the cp with new art, it looks even better. :)
Big Jeff
  • Last login:July 30, 2020, 12:51:37 am
« Reply #10 on: February 22, 2017, 10:42:13 pm »
latest update
That looks great. What plans did you ultimately go with?
Moksi
« Reply #11 on: March 05, 2017, 03:01:00 am »
They have a video how they assemble the cabinet which materials they use etc.
I found the measurements of the cabinet on ebay , & from there i just attempt to make it the same as a Arcadextension 27 inch cabinet
Because i wanted to buy one but they dont send overseas itll cost much with the weight.
glad i made it myself so i can adjust it to my height i made it 184 cm long
never thought i made a arcade cabinet, now im just  starting to laminate it
Moksi
« Reply #12 on: May 10, 2017, 11:20:56 am »
getting close to finish
« Last Edit: September 04, 2017, 05:29:55 am by Moksi »
ND4SPD
  • Last login:April 21, 2020, 04:03:25 pm
« Reply #13 on: March 04, 2019, 06:29:01 pm »
Do you still have the measurement/plans you used?  They don't sell these on eBay anymore.
Moksi
« Reply #14 on: September 26, 2021, 11:03:21 am »
Ok im planning to put in a Bang & Olufsen instead of the Ben Q LCD i put in ,
luckily the TV just fits right in height , 3 parts of the Top part are not needed only need to adjust 1 part in height
and probably just spray paint the bezel plexiglas to cover the space around the tv.
Moksi
« Reply #15 on: October 03, 2021, 03:20:26 pm »
Did a little job on the bezel, i am planning to cut out some laminate to cover the sides behind the plexi
Moksi
« Reply #16 on: October 11, 2021, 02:48:43 pm »
used some laminate cut to cover the sides of the tv
Moksi
« Reply #17 on: October 11, 2021, 02:51:05 pm »
final result with the plexiglass in front of the laminate
Moksi
« Reply #18 on: October 11, 2021, 02:57:04 pm »
another look from the side , so the space around the tv is well covered, im basically done with it.
only behind the top part i need to fit a piece of wood to replace the large part that was there before i used it to cover it with the LCD in it.
will post some stuff again when i place it over at my place
