Author Topic: LG Flatron IPS234 Help with fixing rotation bearing  (Read 7189 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: March 27, 2013, 07:56:51 am »
Lovely shiny new monitor arrived today yay :applaud:
Then I saw how the wires are connected to it:
 :angry:
I was hoping to set up a rotation system like Griffindodd did with his revolution cab but not going to be possible with those connections there, any ideas?
« Last Edit: March 29, 2013, 02:02:56 pm by Connorsdad »
  • Last login:September 20, 2025, 07:17:24 am
Re: LG Flatron IPS234 Help with fixing rotation bearing
« Reply #1 on: March 27, 2013, 06:12:08 pm »
You might see if you can find some right angle connectors to replace those straight ones.
That would get the profile of the cords quite a bit lower.
Here is a vga adapter, but it may be too short to fit your monitor:
LINK
« Last Edit: March 27, 2013, 06:17:04 pm by DaOld Man »
« Reply #2 on: March 27, 2013, 06:18:31 pm »
And here is a power cable, but Im not sure if this power cable will fit your monitor, but it should give you an idea of what im thinking:
LINK2
Connorsdad
« Reply #3 on: March 28, 2013, 01:17:37 am »
Thanks for the advice, seems an inexpensive solution so worth a try.
Another thing I could try is cutting a slot that follows the path of the circumference for the duration of the rotation and feed the wires through there.
Love the viewing angles of this thing so either way I have to make it work.
« Reply #4 on: March 28, 2013, 09:52:51 pm »
Yes that could work too.
