Author Topic: Pressing two buttons to get third input  (Read 3258 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: March 22, 2013, 09:37:00 am »
Hey folks, is there a simple way to have two buttons pressed together act as a third?
Seith
Re: Pressing two buttons to get third input
« Reply #1 on: March 22, 2013, 09:38:20 am »
Yes, but more information is needed to properly answer that question.  There are many ways to skin a cat.  Start with answering this:
What encoder are you using?
« Reply #2 on: March 22, 2013, 09:41:33 am »
Are you just talking about in mame? Then Yes, easily. When you map a control, you just press both buttons you want. The control settings will say something like "Q + W". and while in game, pressing Q and W at the same time will work as that input.
keilmillerjr
  • Web Developer.
« Reply #3 on: March 22, 2013, 11:10:11 am »
The iPac has a shift function where you hold one button down and press another, and it acts like a different keystroke. I'll be using that function to have a "secret" way of dropping coins without inserting an actual coin.
    • GroovyGameGear.com
« Reply #4 on: March 22, 2013, 11:55:33 am »
In MAME, they are all "secret" unless you can get into the admin section.   :)
keilmillerjr
  • Web Developer.
« Reply #5 on: March 22, 2013, 12:07:08 pm »
By secret I just meant that there will not be a dedicated button for it. Unless I told some one how to do it, they would never know. That's all. Trying to keep it as authentic as possible.
« Reply #6 on: March 22, 2013, 12:28:10 pm »
The MAME method does this as well.  In fact, MAME doesn't care how many buttons you use in a combo.  It could be two, three or more.  But obviously, you would want to assign them to combinations which wouldn't be pressed in the course of normal use.
« Reply #7 on: March 22, 2013, 12:37:44 pm »
Yeah, I agree. It is a really handy feature for people who don't want admin buttons....and for people with children. For my kid's machine, I use 3 button combos quite a bit for the admin functions to keep him from accidentally changing the settings or quitting the game when he slams around on games.
brad808
« Reply #8 on: March 22, 2013, 12:49:35 pm »
This reminds me I need to change the combination I use for pause on my candy cab. Currently I use start + button 3 but lots of shmup games use button 3 as bomb and when I un pause it wastes a bomb on me. Simple solution just to move it to start + button 6 but I haven't remembered around the machine yet.
Sent from my Galaxy Nexus
« Reply #9 on: March 22, 2013, 01:02:31 pm »
I personally use start + Right on joystick for pause. Just throwing that out as an option because I know it can be a stretch to hit start + button 6 with one hand. :)
brad808
« Reply #10 on: March 22, 2013, 01:20:11 pm »
Good call, I always forget about the joystick for stuff like that. On my two player cab that a lot of guests play I tried to avoid it because I figured chances of someone having one hand on the joystick and one on start would be a lot higher than one on the buttons and one on start. Just to try and avoid accidental pauses and such.
I think I also had implanted in my mind long ago (probably wrongfully so) that I would need to use the joystick and start buttons for "secret" unlocks at the beginning of games. Things like alternate costumes for fighting games and stupid things. I can't think of a single game where I do that and it's been a few years now so it's probably safe to use the joystick on my 1 player cab haha.
paigeoliver
  • Awesome face!
« Reply #11 on: March 23, 2013, 12:13:33 pm »
And if you let a couple of grade school kids on your cabinet they will find every single key press combination in a matter of minutes. Usually resulting in them getting into the mame menu and messing up the default control configurations. I only combo insert coin now. For exit game and the tab menu I ended up installing a couple of buttons underneath the control panel where no one knows where they are.
iscariot
« Reply #12 on: March 27, 2013, 01:03:11 pm »
Actually this is for a real arcade machine.  I was just hoping to have the third button utilized when I pressed two other buttons together.
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #13 on: March 27, 2013, 02:27:28 pm »
MAME defaults Player 1 buttons to include Left CTRL & Left ALT. I assigned one of the Player 4  buttons to DEL.
This was fine until the first time I invite over people & 4 of us were playing Gauntlet & the Task Manager popped up! =O
I changed that immediately.
Now, when I have company over & want to protect my cab & keep people out of the MaLa settings menu, I turn off the right-mouse-click option on MaLa & assign DEL to pull up the MaLa context-sensitive menu, as I know that DEL is a key found only in the setup keyboard inside the cab, & not assigned to any switch on the outside of the cab.
-Jason
PS--I also made it difficult to exit to Windows from MaLa: right-mouse-click (Player 2 button 2), then "X" for the keyboard shortcut for "Exit" in the pop-up menu (Player 1 button 6), & then the AutoHotKey script requires that I immediately press & hold F10 (throttle, a dedicated button on the front face of my cab, under the panel's top face overhang) until the Windows desktop appears. If the 1st 2 keypresses occur w/out the 3rd, MaLa will exit & then immediately restart.
