Author Topic: "A Barrel of Kong" - A Bar Height themed Cocktail Cab [FINISHED]  (Read 289698 times)
Maximus
  • Last login:May 26, 2017, 05:32:05 pm
  • Plans are for fools!!!!
    • Arcade Icons
Re: "A Barrel of Kong" - A Bar Height themed Cocktail Cab
« Reply #160 on: May 25, 2013, 01:54:43 pm »
The nice thing about working with a barrel is that nobody expects them to look perfect so in that respect they are easy to make look good
Maximus
    • Arcade Icons
« Reply #161 on: May 25, 2013, 04:38:03 pm »
Testes testes
Maximus
    • Arcade Icons
« Reply #162 on: May 26, 2013, 01:09:27 pm »
Everything plumbed into the inner chassis
« Last Edit: May 26, 2013, 01:28:06 pm by Maximus »
Maximus
    • Arcade Icons
« Reply #163 on: May 26, 2013, 01:27:06 pm »
Everything is contained in the chassis for easy removal and service
« Last Edit: May 26, 2013, 01:47:55 pm by Maximus »
mike boss
« Reply #164 on: May 26, 2013, 01:57:13 pm »
Amazing progress.
Love looking at this thread.
Perhaps stupid question, why use the audio amplifier ?
Maximus
    • Arcade Icons
Re: Re: "A Barrel of Kong" - A Bar Height themed Cocktail Cab
« Reply #165 on: May 26, 2013, 02:11:19 pm »
Amazing progress.
Thanks Mike.  The audio amp on the board is kinda crappy so this gives you better sound and easier control although in this case the volume dial will sit below the bezel so it won't be an adjust as you go option the way it was in little Ms Pac man
mike boss
« Reply #166 on: May 26, 2013, 04:52:20 pm »
Oh, ok.
I follow, I assume your using one of the typical 48/60-in-1 Jamma boards?
If so I know what your taking about, adjusting the volume is a real b**ch!
I have several boards like this.
I don't know if I missed it in the thread, did you post links to where you got the parts ?
I never thought of that audio solution, but I like it.
Lastly if I may ask, how do you wire it ?
Richie_jones
  • Last login:February 20, 2025, 01:55:28 pm
« Reply #167 on: May 26, 2013, 05:01:26 pm »
Great build...
Id find the lack of a volume control a bit of a pain, or is there going to be a software solution...
  • Last login:Today at 07:09:41 am
« Reply #168 on: May 26, 2013, 10:27:39 pm »
Quote from: Maximus link=topic=131202.msg1#msg
Is that for the menu music?  Please tell me that you disable that on your builds?  ;-)
Great work so far!
DeLuSioNaL29
  • Online Online
  • Last login:Today at 12:38:26 pm
« Reply #169 on: May 26, 2013, 10:37:05 pm »
If you want a mechanical solution, you could use a pulley system to connect to an external wheel like this.
Three supports (green) hold the external volume wheel (yellow) so it sticks out the side of the barrel through a notch in the top lip of the barrel.
« Last Edit: May 26, 2013, 10:41:40 pm by PL1 »
Maximus
    • Arcade Icons
« Reply #170 on: May 26, 2013, 10:59:17 pm »
Yeah you can disable the menu music. The amp is wired simply with a 3.5mm jack cable that runs from the board to the amp, speakers wire with standard clamp connections.
It's pretty easy to desolder the volume control pot from the amp board then extend it on wires to put it where you want, I did that on little Ms Pac man with the same model.
« Last Edit: May 26, 2013, 11:01:38 pm by Maximus »
rablack97
« Reply #171 on: May 27, 2013, 12:07:28 am »
love those amps........
« Reply #172 on: May 27, 2013, 12:28:51 am »
Yup, I have one of those amps myself.  :-)
Maximus
    • Arcade Icons
« Reply #173 on: May 27, 2013, 11:33:15 am »
Wiring up the power strip to the fused socket
Socket installed at the bottom of the barrel
Strip mounted.  This is the only wiring the barrel itself needs, everything else is on the game chassis
mike boss
« Reply #174 on: May 27, 2013, 11:53:21 am »
Thanks for the info on the amp, I'll need to look into these for future builds.
Never even thought of the headphone jack !
BTW LOVE powerstrips ! Another thing I found out because of the good folks @ BYOAC.
What an amazing solution they are.
Maximus
    • Arcade Icons
« Reply #175 on: May 27, 2013, 12:19:23 pm »
Drop the chassis in place and plug in to the strip
ERRMERGERD DERNKEY KERNG ERN A BURL!
« Reply #176 on: May 27, 2013, 04:26:29 pm »
Can't wait to see the glass installed. Are you going to order more than one to save money and use the other one on a clone?
Also, how do you plan to do the bezel? (If any)
LeedsFan
« Reply #177 on: May 27, 2013, 04:28:07 pm »
Really loving this project!!!  I'm not a fan of those 60-in-1 type boards, but I can see why you went that route. Love how that barrel looks now after your TLC. Nice simple control panels to play the classics. I'd have gone with the Ultimarc Versa stiks to have powered switching between 4 and 8 way games. Nevertheless... this is an impressive build and the idea itself is kinda unique as DK is my all time fave game.
Maximus
    • Arcade Icons
« Reply #178 on: May 28, 2013, 12:42:26 am »
Bezel art
For the glass I may see if I can score a used round table on Craigs list.  Or ikea also sells a coffee table with two glass 24" round surfaces for about $50 so that may be an option
mike boss
« Reply #179 on: May 28, 2013, 05:26:04 pm »
I can't keep saying enuff how fantastic this project is.
Jigenjuke
« Reply #180 on: May 28, 2013, 06:46:52 pm »
Bezel art
If that falls through you might even look into buying the glass yourself and cutting it to size.  Recently cut glass for my mini cocktail cabinets and the glass "cutting" went suprisingly well.  Lookin' great man! :cheers:
Jigenjuke
Maximus
    • Arcade Icons
« Reply #181 on: May 28, 2013, 07:00:21 pm »
Yeah best price I have seen is 24" tempered clear 1/2" with 1" beveled finish delivered for $48, the bevel seems to add about $5 to the price but I like it for tables.
rCadeGaming
  • Just call me Rob!
« Reply #182 on: May 28, 2013, 07:16:33 pm »
I'm guessing that little black thing the VGA cable's coming out of is one of those SLG's you see often, what kind of scaler is it attached to though?
Maximus
    • Arcade Icons
« Reply #183 on: May 28, 2013, 07:18:34 pm »
It's a Craftymech SLG converter, plug n play
« Reply #184 on: May 28, 2013, 07:21:05 pm »
You don't need a scaler for the 60-in-1 boards...they have VGA out.
TheShaner
« Reply #185 on: May 29, 2013, 01:56:22 pm »
Im curious what made you decide on going Jamma for this guy?  I can think of several good reasons, but am curious what your drive was on it.  Also, how do you like it?  I am about to build a cocktail and am debating the jamma approach.
Do you know what the difference is between Jelly and Jam?
Maximus
    • Arcade Icons
« Reply #186 on: May 29, 2013, 02:01:31 pm »
I'm scared to answer this.
I went with Jamma because it worked out well on the Little Ms. Pac-Man build and I think of these cocktail builds as very casual gaming cabs. I like the cheap virtually zero-config nature of the boards, that you can just flick on the power and leave it for people to use on their own. It plays the games well enough that your every day person wouldn't notice any shortcomings in performance.
mcseforsale
  • Last login:Today at 10:21:52 am
  • Creepy Mario Dude
« Reply #187 on: May 29, 2013, 02:16:26 pm »
Do you buy the kit?
Where do you get them?
I'm wanting desperately to start building wee cades for some curious customers and I want a zero-touch solution that cuts down on support issues.
AJ
Maximus
    • Arcade Icons
« Reply #188 on: May 29, 2013, 02:18:05 pm »
Do you buy the kit?
AJ
You'll have to Googlize that stuff before you get my thread sent to thread hell for talking about things not sanctioned here.
TheShaner
« Reply #189 on: May 29, 2013, 02:28:57 pm »
Cool, that is about what I figured.  I like the idea of no moving parts inside the machine.  (fans, etc.)
Answer to the riddle:  I can't Jelly it in your ass!
TheShaner
« Reply #190 on: May 29, 2013, 02:39:52 pm »
The only hangup I think I would have, other than the finite game list, would be the actual menu system.  How is that?  I havent found a good video of the interface, but I hear it is craptacular.
« Reply #191 on: May 29, 2013, 02:39:58 pm »
I am a fan of wiring cabinets, including mame cabs to the JAMMA standard. It's a clean, self-contained solution of getting your wiring hooked up through-out the cab. Keeps it neat.
Also gives you the option of potentially putting original PCB's in your cabinet.  The only downside for that is that you'd need a scaler to connect original PCB's to that LCD.
Either way, it's a clean organized solution and not very hard to hook up. Bob Roberts has a really good write-up tutorial of hooking up JAMMA from scratch.
« Reply #192 on: May 29, 2013, 03:06:34 pm »
:) Also a good method to mame a commercial cab without needing to gut it.
Maximus
    • Arcade Icons
« Reply #193 on: May 29, 2013, 03:59:15 pm »
Ordered the glass today. this was a difficult choice, I could either go cheap and snag an Ikea coffee table off Craigslist for $30 which would give me a perfectly good 29.5" 1/4" thick tempered glass top, or I could get all anal about the specific look and diameter of the build and pay $84 inc tax n ship for a new 27" diameter 1/2" thick piece with a nice 1" bevel polished edge.
Truth be told I'm sure either option would be just fine, but I have a feeling this cab may end up staying in the house after all, the wife really likes it, as do many friends and the fact it doubles as a nice piece of bar furniture raises the odds of it staying.
So needless to say I took the picky route and got the more expensive solution.
« Last Edit: May 29, 2013, 04:05:59 pm by Maximus »
  • Last login:November 22, 2025, 08:32:45 pm
« Reply #194 on: May 29, 2013, 04:28:18 pm »
How's the stability on that thing? A wild game of Pac-Man won't tip it, will it?
Maximus
    • Arcade Icons
« Reply #195 on: May 29, 2013, 04:31:42 pm »
Solid as a rock, you'd snap the joystick before that
TheShaner
« Reply #196 on: May 29, 2013, 04:40:45 pm »
Im still really curious about that built in menu ... how is it?  Smelly?
Maximus
    • Arcade Icons
« Reply #197 on: May 29, 2013, 04:42:07 pm »
super basic, just 6 tiles on each screen, each one a screen capture of the game, does it's job. Look at the video of bench testing a few posts back.
TheShaner
« Reply #198 on: May 29, 2013, 04:42:59 pm »
ok, thanks.  I did see a video of that interface.
« Reply #199 on: May 29, 2013, 04:43:57 pm »
Truth be told I'm sure either option would be just fine, but I have a feeling this cab may end up staying in the house after all, the wife really likes it.
Franzia and Kong, what woman could resist?  ;)
hope the custom glass pays off for ya.
