Author Topic: Mame hacks that make driving games play better with mouse/spinner/360wheel  (Read 70271 times)
geecab
  • Last login:Yesterday at 03:02:24 am
Hi there!
Not sure if this is of interest to anyone, I hacked a ps2 mouse and built a mame driving cab recently. For games that used 360 wheels (pole position, change lanes, super sprint etc) it was great. For games that limited the turning circle of the wheel (outrun, wec le mans) it wasn't so good. I found that if I over steered, the wheel's central position would wander. I've kind of got used to it, but I notice when my friends have a go its takes them a while to adjust.
So I decided to see if I could hack the mame source code a bit. My hack works so that the position of the wheel when the game starts up will always be its central position (players car will travel in a straight forward direction). If you then spin the wheel, say, 3 spins clockwise (hard right), you'll be required to spin the wheel back anti-clockwise 3 times in order to get the car going straight again. Spinning your mouse/spinner/360wheel beyond the limits of what the actual arcade game wheel would allow just means the game's maximum left turn or right turn value is applied.
Hope that make sense, here's a youtube clip of me trying to show that working...
I'll post my mame source code changes shortly incase someone else is thinking of doing the same thing!
« Last Edit: March 10, 2013, 09:36:35 am by geecab »
Sounds good for those with 360 degree wheels.
Does each driver in MAME have to be modified, or will this work with with all the driving games?
On Hard Drivin', does the wheel do as many turns as the original arcade one before hitting the virtual end?
(it had a 10 turn pot, but IIRC the wheel turned 7+ times lock to lock)
FYI, years ago, bkenobi had a fix using glovepie.
http://forum.arcadecontrols.com/index.php/topic,92363.0.html
I hadn't thought about this before (since I don't have a 360 degree wheel), but this is an option it would be nice to see in the official MAME source along with proper shifter support.
If you have the skills to make it optional, and in a way that MAMEDev finds acceptable, consider submitting it.
geecab
Thanks for your replies Badmouth, really great 'Driving Cab Information' thread by the way. Really helped me out a lot when I was putting my cab together. I think I have read about that glovepie fix you mentioned, but I just fancied modifying the mame source rather than having other stuff running in the background. I think I will submit something to MAMEDev at some point, but to be honest, these are pretty nasty hacks at the moment, am just enjoying messing around with the source code. I haven't even made my modifications command line configurable either so while it will make outrun etc play better, it could well break other games.
Getting hard drivin' going was tricky, I don't think that multiple turning pot thing (with some strange latching bit when the wheel turns 360 degrees past the central point) has ever been emulated correctly. My hack for hard drivin is different to my outrun/hang-on/weclemans hack, I shall post the hack I made specifically for hard drivin in another post a little later on.
So regarding the outrun/hang-on/weclemans change, you don't have to change all the individual game driver files, just one file (found in src/emu/ioport.c). Also, I'm editing mame source version 0145. You are looking for a function called "apply_analog_min_max", below is what the function looked like originally (before my hack):-
INLINE INT32 apply_analog_min_max(const analog_field_state *analog, INT32 value)
/* take the analog minimum and maximum values and apply the inverse of the */
/* sensitivity so that we can clamp against them before applying sensitivity */
INT32 adjmin = APPLY_INVERSE_SENSITIVITY(analog->minimum, analog->sensitivity);
INT32 adjmax = APPLY_INVERSE_SENSITIVITY(analog->maximum, analog->sensitivity);
/* for absolute devices, clamp to the bounds absolutely */
if (!analog->wraps)
if (value > adjmax)
value = adjmax;
else if (value < adjmin)
value = adjmin;
/* for relative devices, wrap around when we go past the edge */
else
INT32 range = adjmax - adjmin;
/* rolls to other end when 1 position past end. */
value = (value - adjmin) % range;
if (value < 0)
value += range;
value += adjmin;
return value;
Now, outrun/hang-on/weclemans used an absolute device for steering. 'value' is passed into the function as the position of where your mouse x axis is. 'value' is limited to adjmax or adjmin if you moved your mouse further than the arcade game allowed.
So now onto my fix, basically, if 'value' is limited by adjmax or adjmin, I make a note of the difference (I called it "spin_history" for some reason). Then the next time I'm in the apply_analog_min_max, I add the spin_history (which maybe positive or negative depending on which way the wheel was turned) to the 'value' passed in, which then may be limited again, which I then save the spin_history again, etc.. etc...  Finally, I only want this to happen for the IPT_PADDLE type because that is the steering wheel device, other devices also go through this function too (IPT_PEDALS for example) which I don't want to alter:-
INT32 spin_history = 0;
if (!analog->wraps)
if(analog->field->type == IPT_PADDLE)
value = value + spin_history;
spin_history = 0;
if(value > adjmax)
spin_history = value - adjmax;
value = adjmax;
else if(value < adjmin)
spin_history = value - adjmin;
value = adjmin;
else
if (value > adjmax)
value = adjmax;
value = adjmin;
else
if (value < 0)
value += range;
value += adjmin;
return value;
There is an obvious bug with this, like if you span your wheel enough (moved you mouse in one direction enough) spin_history would get so large (or so small) that it too would wrap around. I could sort this out at some point though.
Anyways, I think that's it for now as I think I'm going on a bit, hope some of this made sense  ;)
« Last Edit: March 10, 2013, 09:31:15 am by geecab »
geecab
Here is my hard drivin' / race drivin hack. By the way, its the Compact British version of hard drivin' (harddrivcb) I am currently using (because it runs much faster than the cockpit version). Important to note though as the wheel does not use a Potentiometer in the compact version, so I'm not sure my hack would work on the cockpit version. I'm using the 0145 mame sources to build from. This has all been pretty much a case of trial an error but it does appear to work really nicely now. Be good to hear from anyone who knows anything about hard drivin's bit latching setting (set when the wheel passes 360 degrees) as I'm probably barking up the wrong tree!
Ok so first off, I modified the apply_analog_min_max function in src/emu/ioport.c agian. The big comment should hopefully explain what I'm up to...
if (!analog->wraps)
//Limit the turning circle so that you can not turn the wheel more than 270 degrees to
//the left or 270 degrees to the right. I limited the turning circle because things
//seemed to mess up if I turned more that 360 degress left or right. The values I've
//hardcoded adjmax/admin may need to be altered depending on your analogue PADDLE settings.
//Press the Left Shift key in game and a small debug window appears for a few seconds
//(one of the mame developers must have added this), it shows you what position mame thinks the
//arcade wheel is in. It should be the same value as reported by the game if you Press F2
//(invoke the service menu), then pressing 5/6, and turning key (1) on CONTROL SIGNALS.
//From what I can work out, the value 0x800 in the debug window should be
//dead center, 0xC00 is about 270 degress to the right of the central position, 0x400 is
//about 270 degrees to the left of the central position. If you use a different
//PADDLE SENSITIVITY, the values shown in the debug window may exceed the 0x400 to 0x800
//limit in which case you probably what to a adjust the hard coded limits of adjmax/adjmix
//(by trial and error, holding the left shift key down in game and see how things look/play).
//This is what worked for me with my analogue settings set to:
//    PADDLE DIGITAL SPEED = 0
//    PADDLE AUTOCENTER SPEED = 0
//    PADDLE SENSITIVITY = 25
adjmax = 150016; //Stop the steering going over 0x0C00, before the latch bit is set
//Central position seems to be 0x0800
adjmin = -150016; //Stops the steering going under 0x0400, before the latch bit is set
spin_history = 0;
if(value > adjmax)
value = adjmax;
value = adjmin;
else
if (value > adjmax)
value = adjmax;
value = adjmin;
else
if (value < 0)
value += range;
value += adjmin;
return value;
With the hack above, things worked quite well, but I found the steering would occasionally wander away from dead center after doing a few erratic turns. I guessed it might be something to do with the wheel edge/latching processing which I don't really understand. So I found in src/mame/machine/harddriv.c a function which appears to do something with this latching bit each time the wheel goes past its central position and I modified it and it fixed the wandering problem.
This is what the function originally looked like...
READ16_HANDLER( hdc68k_wheel_r )
harddriv_state *state = space->machine().driver_data<harddriv_state>();
/* grab the new wheel value and upconvert to 12 bits */
UINT16 new_wheel = input_port_read(space->machine(), "12BADC0") << 4;
/* hack to display the wheel position */
if (space->machine().input().code_pressed(KEYCODE_LSHIFT))
popmessage("%04X", new_wheel);
/* if we crossed the center line, latch the edge bit */
if ((state->m_hdc68k_last_wheel / 0xf0) != (new_wheel / 0xf0))
state->m_hdc68k_wheel_edge = 1;
/* remember the last value and return the low 8 bits */
state->m_hdc68k_last_wheel = new_wheel;
return (new_wheel << 8) | 0xff;
And this is what it looked like after my modification (Once again big comment should hopefully explain what I'm up to)...
UINT16 g_latchpoint = 0x860; //Ajust this g_latchpoint by trial and error. You want it so that
//when your wheel is dead center and you press left shift key in game, the value reported is 0x800.
//Setting the latchpoint as 0x860 was dead center for me (not sure why this is, I had calibrated
//everything correctly in the F2 service/configuration menu).
if(new_wheel == g_latchpoint)
if(state->m_hdc68k_last_wheel != g_latchpoint)
else
//I noticed after many harsh turns of the wheel, mame's perception of where
//the arcade wheel is (shows by pressing the left shift key in game) would
//wander from what was actually reported in the hard drivin' serivce menu
//(Pressing F2 in-game and view the CONTROL SIGNALS page). I guessed this was
//something to do with the edge/latching bit stuff that should get set when
//the wheel passes the central position. My modification is to make sure the
//m_hdc68k_wheel_edge thing is set when we pass the central position, even
//if we don't hit the value exactly.
if(new_wheel > g_latchpoint)
if(state->m_hdc68k_last_wheel < g_latchpoint)
else if (new_wheel < g_latchpoint)
if(state->m_hdc68k_last_wheel > g_latchpoint)
Finally, I only have a high/low shifter and wanted to use the 4 speed manual gear option. As I've got shift up and shift down firebuttons on my CP I decided to try and use them. So this is my shifter hack (I've done similar hacks for games like night driver, Sprint 1), let me know if you're interested in seeing them.
Once again, in src/mame/machine/harddriv.c I found the function that takes care of the gears, this is what it originally looked like...
READ16_HANDLER( hdc68k_port1_r )
UINT16 result = input_port_read(space->machine(), "a80000");
UINT16 diff = result ^ state->m_hdc68k_last_port1;
/* if a new shifter position is selected, use it */
/* if it's the same shifter position as last time, go back to neutral */
if ((diff & 0x0100) && !(result & 0x0100))
state->m_hdc68k_shifter_state = (state->m_hdc68k_shifter_state == 1) ? 0 : 1;
if ((diff & 0x0200) && !(result & 0x0200))
state->m_hdc68k_shifter_state = (state->m_hdc68k_shifter_state == 2) ? 0 : 2;
if ((diff & 0x0400) && !(result & 0x0400))
state->m_hdc68k_shifter_state = (state->m_hdc68k_shifter_state == 4) ? 0 : 4;
if ((diff & 0x0800) && !(result & 0x0800))
state->m_hdc68k_shifter_state = (state->m_hdc68k_shifter_state == 8) ? 0 : 8;
/* merge in the new shifter value */
result = (result | 0x0f00) ^ (state->m_hdc68k_shifter_state << 8);
/* merge in the wheel edge latch bit */
if (state->m_hdc68k_wheel_edge)
result ^= 0x4000;
state->m_hdc68k_last_port1 = result;
return result;
And this is what it looked like after my modification...
int g_gear = 1;
int g_have_seen_shift = 0;
int has_changed = 0;
if(!g_have_seen_shift)
if(result != 0xFFFF)
if (result & 0x0100) //SHIFT UP
//printf("shift up\n");
g_have_seen_shift = 1;
g_gear++;
if(g_gear > 4) g_gear = 4;
has_changed = 1;
if (result & 0x0200) //SHIFT DOWN
//printf("shift down\n");
g_gear--;
if(g_gear < 1) g_gear = 1;
has_changed = 1;
else
if ((result != 0xFEFF) && (result != 0xFDFF))
//printf("shift OFF result=0x%X\n", result);
else
//printf("shift STILL ON! result=0x%X\n", result);
if(has_changed)
if (g_gear == 1)
//printf("gear1\n");
state->m_hdc68k_shifter_state = 1;
if (g_gear == 2)
//printf("gear2\n");
state->m_hdc68k_shifter_state = 2;
if (g_gear == 3)
//printf("gear3\n");
state->m_hdc68k_shifter_state = 4;
if (g_gear == 4)
//printf("gear4\n");
state->m_hdc68k_shifter_state = 8;
result ^= 0x4000;
return result;
Then in mame the Key you define for '2nd gear' will act like a shift up, and the key that you define for '1st gear' will act like a shift down. Also, while your defining keys in mame, define the clutch key as the same keys as you chose for the '1st gear', '2nd gear' and 'turn key'. That way you should be able to make really quick smooth shift changes whilst automatically pressing the clutch down.
I think that is everything  :)
huwman
  • Last login:February 13, 2014, 08:32:48 am
Re: Mame hacks that make driving games play better with mouse/spinner/360wheel
« Reply #5 on: September 08, 2013, 04:20:42 am »
Hi, sorry to resurrect an old thread, but this is exactly what I'm after. I've got the same problem with the floating centre point on my mame'd chase HQ cab (which has a steering opto, connected to my pc via an optipac).
I've recompiled mame with your file as described, but am still getting the floating centre point issue. Are there any setup options I might have missed? Thanks for any further guidance.
geecab
« Reply #6 on: September 08, 2013, 05:31:06 am »
Hi! Cheers for giving my hacks a go :) I don't think you've missed any setup options. What version of mame are you compiling with and what game are you trying?
huwman
« Reply #7 on: September 08, 2013, 08:48:38 am »
Thanks, I'm using mame 145 as that's what you said you were using. It's the first time I've compiled mame, but it seemed to work. I simply copy and pasted your text into the file over the original text, so I think I did that right too.
The game I've tried it with so far is SCI. It seems better than without the hack, but I'm not sure. I've played around with the various analogue settings in mame.
Any chance you could post a compiled version with your hack, just so I could check it's not a problem with my version? Or just the hacked file, then I could use that when compiling? Thanks very much.
geecab
« Reply #8 on: September 08, 2013, 10:01:14 am »
Thanks, just wanted to make sure.
Yes that's all you should need to do.
I've just had a go with SCI and it doesn't work for me either. Not sure what SCI is doing differently to outrun/hangon/wecleman, but I'd have to debug it to find out.
How about running outrun, hang-on or wec le man to verify if the fix is working?
huwman
« Reply #9 on: September 08, 2013, 11:48:26 am »
good idea! i've just tried all three and unfortunately theyre not working. the steering wheel is configured to Paddle Analog and shows up as Mouse X. I must have compiled Mame correctly as it works, which maybe leaves my hacked ioport.c file as the culprit? i'll double check it, but if you've got one you can post that would be great! Thanks.
geecab
« Reply #10 on: September 08, 2013, 12:41:52 pm »
Should be fine.
OK, I've zipped up the exe I compiled and my ioport.c. The zipped file is called build_0145_outrun.zip and you can download it here:
http://www11.zippyshare.com/v/73958392/file.html
Hope this helps! :)
huwman
« Reply #11 on: September 08, 2013, 04:15:49 pm »
Thanks so much!! I've just been playing Outrun on my Chase HQ cab. Steering is perfect!
If you ever get a chance to look at SCI please let me know. I'll do whatever I can to help, but as you can probably gather, I'm a total novice! This really should be implemented in MAME as it improves the experience of playing these games so much.
Thanks again!
geecab
« Reply #12 on: September 09, 2013, 03:56:59 am »
Excellent stuff huwman, really glad you've got things going! I'll have a look at SCI next weekend as I quite intrigued as to what it does differently to the others.
Cool, I agree too :) I think I'll try and come up with the cleaner solution for it at some point, making it work in the latest version of mame too (ioport.c stuff changed quite significantly in v0147, which is why I've just stuck to editing the old v0145 source), then submit it to the mame team and see what they say.
huwman
« Reply #13 on: September 09, 2013, 03:52:01 pm »
Yes, it's great being able to play some other games properly, after all the money I've spent on Jpacs and optipacs etc!!
I've tried messing around with the dipswitches on SCI in MAME, as there are options for 360 or 270 wheels, but it doesnt seem to make a difference. I also tried Superchase Criminal Termination, as its part of the same series, and that has the same problem.
But Chase HQ works fine, and so does Power Drift!
Thanks again, and I'm looking forward to hearing if you can make any progress with SCI!
geecab
« Reply #14 on: September 09, 2013, 06:30:46 pm »
I think I've got SCI working now. Outrun etc uses IPT_PADDLE for the steering. SCI uses IPT_AD_STICK_X. So I hacked the apply_analog_min_max function in ioport.c some more. In the apply_analog_min_max function, I now check for both types of steering methods (IPT_PADDLE or IPT_AD_STICK_X), so you should be able to run Outrun or SCI with the same exe and the steering will work as expected.
Here what my apply_analog_min_max function looks like now (there just one line that is different from the original outrun hack):
if (!analog->wraps)
if((analog->field->type == IPT_PADDLE) || (analog->field->type == IPT_AD_STICK_X))
spin_history = 0;
if(value > adjmax)
value = adjmax;
value = adjmin;
else
if (value > adjmax)
value = adjmax;
value = adjmin;
else
if (value < 0)
value += range;
value += adjmin;
return value;
Anyways, I've zipped up the exe I compiled, and my ioport.c. The zipped file is called build_0145_sci.zip and you can download it here:
http://www7.zippyshare.com/v/18199545/file.html
Hope this helps!  :)
huwman
« Reply #15 on: September 10, 2013, 03:49:33 pm »
Thank you! I've played SCI several times with this revision. To begin with, it seems to be totally fixed, but the centre then starts to drift a bit by the end of the level.
This happened once after the car had spun out, but the other times started to happen towards the end of the level when  driving next to the train. It almost seemed like the appearance of the train triggered the centre to drift! I'll play it through several more times and see if any patterns emerge.
Thanks again!
huwman
« Reply #16 on: September 11, 2013, 09:54:41 am »
Interesting.....I tried it again this morning and SCI works fine now! must have been something to do with my setup. sorry!
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
« Reply #17 on: February 07, 2017, 05:26:04 am »
Hello!
Sorry if i resurrected this old 3D but i'm really interested to know if there are some news about it....or if with new mame version this kind of "issue" was solved or improved....
Actually i'm working on a Original Jamma Driving Upright cabinet to convert it on a mame cab.
Thant you for your work dude!
geecab
« Reply #18 on: February 09, 2017, 05:13:37 pm »
Hi! Thanks for the interest! I'm still running my mame cab with a 360 wheel with my hacked versions of mame - I am still happy with them.
To be honest, I got a bit side tracked with other projects and forgot about submitting anything to the mamedevs about this :p I shall post something to them soon I think (Will post a link on here to the thread when I do).
Out of interest, what sort of wheel are going to have in your mame cab (360 or limited turning circle)??
« Reply #19 on: February 09, 2017, 06:30:56 pm »
You know, something that I haven't really explored yet is the fact that with lua scripting, hacks shouldn't be necessary anymore.  As memory can be read and write, it should be possible to manipulate controls without changing drivers.  I'm just getting back into mame atm, but it looks promising.
Marcoqwerty
« Reply #20 on: February 19, 2017, 12:08:19 pm »
Ehiii thank you for reply me!
About your question, is a bit hard to answer....i had found this old "original cab" (maybe an italian remake of CISCO HEAT)with a WORLD RALLY (GAELCO) jamma board, and the pinout was set to ANALOG CONTROL (in this kind of jamma you could setup 3 way of control joy/analog/digital ).
My wheel are 360  suppose analog (see the image below), maybe in the beginning there is digital, with a pcb for convert the signal....
I love your project, and SEGA MONACO GP it's one of my first game i would play on this cab, SPY HUNTER is the other (i will change the original gear maybe to another with some button, the TURBO SWITCHER could be working.....)
At the moment i miss the monitor, so i cant make any hardware test, i plan soon to add a PC with MAME (arcadevga and other interface to old controls) without removing the original jamma harness.
I would use both....jamma original and pc!
baritonomarchetto
  • Last login:March 02, 2026, 07:09:37 am
« Reply #21 on: February 19, 2017, 04:15:03 pm »
That wheel is optical, not analog (potentiometer).
If the pcb was set to stick, would you suppose your wheel was a digital stick?
Marcoqwerty
« Reply #22 on: February 19, 2017, 05:26:59 pm »
mmm no i found the online the manual of WORD RALLY, the wheel is set to "360 steerling wheel optical"...no other clue  :dizzy: dip 4 and 5 on the game settings are ON
sorry for the mistake....
http://www.gamesdatabase.org/Media/SYSTEM/Arcade/Manual/formated/World_Rally_-_1993_-_Gaelco.pdf
geecab
« Reply #23 on: February 21, 2017, 06:54:07 pm »
Cool, thanks for the pics! Yes indeed you have a 360 optical wheel. By the looks of things, a few optical disk teeth are missing (Seen in your 2nd picture) so that's going to be a problem should you try and somehow get the sensor circuit working with mame...
Considering your cab's current condition, I think I'd just recommend quickly wiring/hacking up an old PS2 mouse to your steering mechanism and trying a load of games out and seeing how you get on (Though I probably would recommend this approach considering its what I did with my cab!   :P )
You be able to play all the driving games. Driving games such as Pole Position, SuperSprint, Buggy Boy, APB, World Rally, Turbo, My Monaco GP remake ;) - They will will all play really great. You'll also have the advantage of being able to play lots of non-driving games on it too (Cameltry, PuzzLoop, Arkanoid, Tempest, Warlords etc...).
Things like OutRun, Super Hang-On, Chase HQ, Wec-le-Mans, Daytona, Sega Rally will all still be very playable, but after a few games you'll probably get a little annoyed (as did I) with the way the steering centre position wanders (as described in this thread). If so, let me know, I'll fix my download links and you could give my modified versions of mame a try for yourself.
I see from another thread you want to play SpyHunter and considering what you should do about your current gear shifter (whether to add more fire buttons to the control panel). I also encountered the same dilemma when building my driving cab. In the end I just stuck with the Hi/Low shifter. By the side of the shifter I added 2 buttons, these buttons are 'Shift up' and 'Shift down' buttons, used for driving games that have more than 2 gears (E.g. Virtua Racing, Super Monaco GP). I also bought a bunch of cheap black push buttons on ebay that I concealed into the control panel that I use for things like the SpyHunter weapons, Daytona Car View point, Super Spint player 2 etc... Take a quick look at my "Pole Position II cab scratch build" thread as there are quite a few pictures of my control panel, it might help give you a few ideas.
Hope this helps  :)
  • Last login:Today at 12:18:48 pm
« Reply #24 on: February 21, 2017, 10:04:08 pm »
If you don't have a spare mouse but do have an Arduino, use StefanBurger's Illuminated Spinner firmware.
The hex firmware file is on the thingiverse page.
Load the hex on the board using ArduinoBuilder.
Four wires and an optional jumper connect to the Pro Micro board:
- Ground (2nd pin, top row, blue wire)
- 5v (4th pin, top row, red wire)
- Data A (1st pin, bottom row, green wire)
- Data B (2nd pin, bottom row, white wire)
- X-axis enable jumper (3rd to 8th pin, bottom row) *not shown*  Without this jumper it operates on the Y-axis.
baritonomarchetto
« Reply #25 on: February 22, 2017, 12:45:49 am »
With minimal-to-no tweaking you could successfully use the genuine arcade encoder on your cabinet as well, without the need for additional hardware other than arduino.
The mouse hack is obsolete nowadays
« Last Edit: February 22, 2017, 02:15:01 am by baritonomarchetto »
Marcoqwerty
« Reply #26 on: February 22, 2017, 05:31:39 am »
I  fixed it with a piece of plastic bottle and a bit of black paint... :P
I would to use an external controller looks like OPTI PAC, but made from an italian user (and friend) of arcadeitalia forum, the board name is SMARTASD. You can controls opti and analogs device and, with and easy external circuit, others 8 light buttons or simply game light trought mamehook.  http://www.arcadeitalia.net/viewtopic.php?f=43&t=20198
Hope this helps  :)
At the moment im in front of two working options (looking for better to play driving games and SPY HUNTER also) :
- remove my old steerling wheel and replace it with an original SPY HUNTER wheel (yes i found one), so i play definally fine SH but bad the other 360 gams (right?)
- leave the original 360 wheel and use the UP/DOWN shifter gear....with NOS butto (pic below) (for the fire on SH), and add some "view" buttons usefuls for both kind of games...
I'm totally noob for driving cab conversion....im on yours hands!  :notworthy:
PS: Yes...please reup your mame version hack....  :cheers:
baritonomarchetto
« Reply #27 on: February 22, 2017, 05:47:18 am »
I liked jammasd as much as i dislike smartasd: it's mainly a microcontroller board priced 10 times more than an arduino leonardo... a seller deal only.
geecab
« Reply #28 on: February 22, 2017, 05:54:07 pm »
I must admit, I don't really know much about smartasd boards so I can't really comment. But I can imagine it would be a cool project getting your existing sensor circuit working with an optipac/arduino/smartasd type board so go for it :) BTW. Well done repairing your optical disk using a plastic bottle, neat idea!
The NOS gear shift with the side button looks good, and its cool if you can get hold of a Spy Hunter controller too.
Unfortunately, it is fact that if you go for '360' style steering mechanism (PolePostion/SuperSprint/Arkanoid), then some 'Limited turning circle' style  games (SpyHunter/Daytona/OutRun) might not play so great. And similarly the opposite is true in that if you go for a 'Limited turning circle' style steering mechanism, then '360' style steering mechanism games won't play so great (or not at all).
The problem you are going to have is building a driving cab that suits all your needs, as there is not one solution that suits everything. Everyone who has built a driving cab has had a similar dilemma at some point. I guess only really you can decide what to go for based on what games are most important to you :)
No worries. I'll try and upload them this weekend.
Thorvald
  • Last login:April 15, 2022, 01:36:50 pm
Thanks for all the work on this!  I just finished my cabinet and have a pair of spinners with the 6 inch wheel attachment from Ultimarc.  Works great except for those games that hate 360's...
I'm running the latest 1.82 so I'll likely have to setup a dev environment and apply your changes to a newer build.  Then also look into possible LUA methods (assuming we can get to that low of a level).
Cheers
   Tim
geecab
Sorry for the delay!
Here's my mame steering hack build (Mame version v0.148 Windows 32bit).
mame_0148_geecab_hack_v1_0.zip
In the zip file there is a 'mame_0148_geecab_hack_v1_0.txt' file that reads:
Mame v0.148 Geecab Hack v1.0
In this build, if you run:
        mame.exe -showusage
You should see that I've added 2 new options in the CORE MISC OPTIONS section:-
 -hack_steering       Hack: Permanently associate the mouse's axis position at
                      rom start, with the game's central steering wheel
                      position.
 -hack_gears_semiauto Hack: Allows shiftup & shiftdown for racing games that
                      use more than 2 gears. '1st gear' key shifts you down,
                     '2nd gear' key shifts you up.
Example usage
To run Outrun, ChaseHQ, SCI, HangOn, SuperHangOn, PowerDrift, Harddrivin
(Compact version only), RaceDrivin (Compact version only), Wec Le Mans,
KonamiGT, etc... so that they're play better with mouse apply the following:
        mame.exe -mouse -hack_steering
For Harddrivin and RaceDrivin you can also apply the -hack_gears_semiauto
option:
        mame.exe -mouse -hack_steering -hack_gears_semiauto
Note. The -hack_gears_semiauto option currently only works for Harddrivin
(any version) and RaceDrivin (any version).
Source code changes
I modified the following 6 files (Included in the 'hacked_src_files'
directory. Search for //GEECAB comments to give you an idea where I made
my changes):
        mame0148s\mame\src\emu\emuopts.h
        mame0148s\mame\src\emu\emuopts.c
        mame0148s\mame\src\emu\ioport.c
        mame0148s\mame\src\emu\mame.c
        mame0148s\mame\src\emu\ui.c
        mame0148s\mame\src\mame\machine\harddriv.c
Other
You can still download the original mame v0148 source and binaries from:
        http://mamedev.org/oldrel.html
Please be a little prepared as you visit the mediafire site, you might get adverts for other software appear, encoraging you to download something else. Just make sure you only click on the big green 'Download' button near to top right of the page, and the file that you download to your computer is called "mame_0148_geecab_hack_v1_0.zip" (Its 20MB in size).
« Last Edit: March 08, 2017, 07:49:01 pm by geecab »
geecab
Cheers
   Tim
Hi Tim! A cabinet with 2 spinners sounds cool! I bet its great for things like super sprint, warlords etc :)  Unfortunately, I can't seem to build the latest version of mame anymore (I've done a bit of googling and I think its because mame's latest build environment doesn't support XP users anymore) otherwise I'd have put the steering hacks into the latest version for you. Hopefully the older version will be ok for now (Perhaps you can (like I have done) configure your cab's frontend to run different versions of mame depending on the game you select)?
Marcoqwerty
Ehiii!!  Thank you geecab! :notworthy: :notworthy: can i upload on ArcadeItalia (the most important arcade/coin-op italian forum) server your release to avoid missing file again? i provide here the link after upload it.
Yes a new release would be better, i follow on queue to the Thorvald request....
baritonomarchetto
The most important Arcade forum in Italy is arcademania.eu, as far as I know...
Marcoqwerty
The first (born in 2006)....and most old (11 years) ...and with the large amount of italians users!
PS: with a own wikifiles to store the arcade project and anything else useful for coin-ops and flippers
 :blah:
baritonomarchetto
With "most old" you mean "older", right? :D
Anyway, nothing you cited make a forum significant.
« Last Edit: March 09, 2017, 07:03:01 am by baritonomarchetto »
geecab
Ehiii!!  Thank you geecab! :notworthy: :notworthy: can i upload on ArcadeItalia (the most important arcade/coin-op italian forum) server you release to avoid missing file again? i provide here the link after upload it.
That's cool with me, post/upoad it whereever you like! :)
Ok I think the next step is that I shall post a message on the mame dev forum about this. See if I can encourage their developers that a mouse/steering option like this is a worthwhile addition. Its a long shot, but its worth a try. If the mamedevs do decide to add it, they'll probably make a much nicer/cleaner job of the implementation into the latest mame version than I would. I'll post my message to the mamedevs in the next couple of days, will post link on here when its posted :)
baritonomarchetto
Fingher crossed. Mamedevs are not open to this kind of "hacks" but it's worth a try
geecab
Marcoqwerty
Sorry Geecab for bother you again... i have a question about your modified version of mame, because i installed it on my driving cab.
Your version isnt a groovymame hack right? just a simple mame....because would be useful compile a groovymame version to use that on crt soft15Khz crt monitor as mine (image looks more "arcade" also the resolutions more close to real arcade)
I'm totally noob to recompiling mame, i tried a couple of windows software but no good results happens....(also i havent find any .diff on your package)
Can you have a bit of time to recompile a new version using the groovymame diff (maybe youve some dedicatd machine with all installaion stuff over it)?  https://drive.google.com/open?id=0B5iMjDor3P__Wnk4SkI3cXZkbXM  (183)
thank you for everything! youre my last chance to use this amazing hack, not all have an 360 original steerling wheen on a jamma coin-op....  :dunno
