Author Topic: Hacking Outrun 2006  (Read 636980 times)
buttersoft
  • Last login:Today at 05:35:04 pm
  • Is running at 15kHz
Re: Hacking Outrun 2006
« Reply #1160 on: March 21, 2022, 06:24:54 am »
Hey, pretty cool. May i ask where this is going? Higher res 2d or 3d assets/textures? Customising?
Frogbull
  • Last login:July 25, 2022, 08:26:16 am
  • DAYYYYYYYYTONA!!!
« Reply #1161 on: March 21, 2022, 01:11:57 pm »
Not precise, I like Modding for Modding so everything that can be done is great, the best exemple is what Howard_Casto did with OutRun 2006 and his Tracks Editor :notworthy:
Maybe AI Upscaling some Textures, export/import Xbox 360/PS3 HD textures into SP DX could also be cool for a better rendering :D
Now, if the goal is to go crazy, export/import 3D model will be a dream (get OutRun 2006 exclusive cars) and the best will be to be able to import the 80s symbol: a Lamborghini Countach :afro:
« Last Edit: March 21, 2022, 01:17:17 pm by Frogbull »
buttersoft
« Reply #1162 on: March 21, 2022, 06:32:12 pm »
OMG i must have blanked on that. A track editor / randomiser for the arcade version would be fricking awesome!
Frogbull
  • DAYYYYYYYYTONA!!!
« Reply #1163 on: April 05, 2022, 08:09:16 am »
I managed to extract and convert more data from OutRun 2 SP SDX
Here some verts (with a lot of garbage noise) on Blender of the F40 3D Model :droid
« Last Edit: April 05, 2022, 08:12:52 am by Frogbull »
SegaFan22
  • Last login:July 06, 2024, 04:02:23 am
  • Insert Coin
« Reply #1164 on: June 06, 2022, 09:29:46 am »
I think I've found more details on the missing backfire issue: it's a bug linked to the controls. If you play using the keyboard defaults the flames are still there when upshifting (Win 10 latest version, both original and FXT content). As soon as you switch to a controller (I'm using an Xbox 360 wireless joypad) they disappear.
Basically, the flames aren't shown on screen when the player is using anything other than a keyboard. You can even try playing with the keyboard, then switching to the controller, and see that they are "disabled" by the external device and come back when you accelerate with arrows.
Crazy, but it's probably a bug not even the devs knew existed. I don't know if it can be solved by "mixing" the control configs or in any other way, I just wanted to share this information.
EDIT
after playing a little more with the controls configuration, I'm 99% sure it's a Direct Input bug. If you assign the accelerator and brake to any face buttons (or if you play with the keyboard), the backfire/flame animation shows up when upshifting. Since Direct Input doesn't see the left and right triggers (or pedals) as two different axis, using them screws up the game's logic.
I don't think there's any solution unless someone's able to swap Direct Input for Xinput in the game controls but that would mean hacking the game code itself  :-\
EDIT 2
I found a workaround using Xinput Plus: swap controls between buttons and triggers. You get the flames but you lose analog input - not that I really care but hey...
« Last Edit: July 08, 2022, 01:42:22 am by SegaFan22 »
Jbulleit97
  • Last login:May 21, 2023, 12:32:16 pm
« Reply #1165 on: May 21, 2023, 12:29:00 pm »
Got an issue with running OR2:FXT. Whenever I try to start the game now, this error message keeps popping up. I'm pretty dumb when it comes to these things, and it's been over 2 years since I installed the game, so I could really use a hand.
SegaFan22
  • Insert Coin
« Reply #1166 on: May 27, 2023, 04:24:54 am »
Happens to me when I choose an unsupported resolution for the current display I'm using. Ex: FullHD on a old laptop that doesn't reach it. Try lowering its setting in the FXTconfig program. Or change something else in there.
MrThunderwing
  • Last login:January 17, 2026, 07:15:09 am
« Reply #1167 on: June 14, 2023, 07:19:03 pm »
Hey Howard - the latest issue of Retro Gamer magazine here in the UK has done a big feature on OutRun 2 for it's twentieth anniversary, and you get a mention in it!
isamu
  • Last login:January 14, 2026, 06:54:24 pm
« Reply #1168 on: June 14, 2023, 07:53:10 pm »
WOW that rocks!! Yeah we haven't seen Howard around here lately. Howard I hope you're feeling OK brother. I know you've mentioned some health issues in the past so hopefully you're feeling OK dude.
« Reply #1169 on: June 15, 2023, 09:00:12 pm »
I'm fine.   My new job keeps me busy is all.   I'm still lurking I just don't comment as much as I used to.
isamu
« Reply #1170 on: June 15, 2023, 11:53:06 pm »
MrThunderwing
« Reply #1171 on: June 16, 2023, 04:08:05 am »
Glad to hear you're OK Howard, your absence around these parts was conspicuous.
brad86
  • Last login:June 23, 2023, 06:53:01 pm
« Reply #1172 on: June 23, 2023, 10:56:14 am »
Hi guys. Lost my old login details (been many years), so signed up again.
Whilst messing with the game, did any of you talented folk by any chance find a way of extracting the .PS2 file format from the later Japanese PS2 OR2SP port ?
It seems every single port other than this version (including arcade Lindberg) does not loop audio at the right points, and the cut-off before restarting the track is really amateurish sounding. Not something you expect with such an otherwise polished game.
I want to replace these with the extracted fixed versions from OR2SP PS2, for use on Lindberg via Teknoparrot, and FXT on PC.
I've looked around the web on old sites, and then for a bms script, but haven't found anything, sadly.
« Last Edit: June 23, 2023, 10:58:22 am by brad86 »
MrThunderwing
« Reply #1173 on: August 26, 2023, 05:56:02 am »
I got to play on an Outrun 2 SP cabinet for the first ever time last weekend, at a new arcade bar that's just recently opened up in the centre of my home city. I was quite surprised to find out that the arcade version of OR2SP had a couple of extra features compared to the home versions, that I was previously unaware of, like the ability to play a special versus track, which mixes and matches some of the regular Outrun 2 courses with some of the ones from SP in a slightly different order. There's also some small animated representations of your cars in the top right of the screen that react to your position in a versus game. Also, your girlfriend Clarissa pops up from time-to-time at the bottom of the screen with little comments about how you're driving and what route you're taking, something that doesn't happen in the home version. Interesting that I'm still finding out new stuff about this game, all these years later....
« Last Edit: August 26, 2023, 06:20:50 am by MrThunderwing »
isamu
« Reply #1174 on: August 27, 2023, 08:26:01 pm »
That's awesome. Didn't know about those details. Another detail I'm not sure you're aware of, is that after playing a race, if you want to play another race you can press brake, view and shift together and it will put you right back in the race with the exact same configuration you had before. Pretty cool.
By the way I was playing a bunch yesterday and put up some new high scores on the continuous track via TP so if anyone wants to challenge my time/score go for it :)
Man what wouldn't give to have a hack that allowed us to edit the courses FXT style. It would be the best of both versions.
WingMantis
  • Last login:December 22, 2023, 02:55:41 am
« Reply #1175 on: December 06, 2023, 01:39:37 am »
Hi, any luck importing other car models into the arcade or OR2K6?
I just got I French copy of 2006 for cheap and was thinking it would be cool if someone modded in cars from other SEGA games like Crazy Taxi or Ryo Hazuki and his motorcycle from All Stars Racing.
SegaFan22
  • Insert Coin
« Reply #1176 on: December 08, 2023, 02:06:08 am »
You can't do that without proper tools and editors, all we have with FXT is the work of a single guy who found out how to modify the game  by himself. In fact, as soon as he stopped updating the mod, the project froze.
polybius22
  • Last login:March 17, 2024, 12:46:28 pm
« Reply #1177 on: March 07, 2024, 11:47:45 pm »
Hopefully more are like me that have used these tools to make an incredible build of what was already a classic racing game, despite never posting here before. I'd like to say thank you to all of you who contributed to enhancing the game so much, particularly Howard.
Mike
« Last Edit: March 08, 2024, 03:46:03 am by polybius22 »
SegaFan22
  • Insert Coin
« Reply #1178 on: March 13, 2024, 02:22:08 am »
I suppose this incredible build is secret or private, right?  :P
polybius22
« Reply #1179 on: March 13, 2024, 04:22:12 pm »
Personally I use the arcade intro video and Howard's overlay with HD HUD. I tweaked some images to remove the extra "REV" letters and flashing red light when driving with manual transmission. I also threw Clarissa's bra back on, except for on the AAA congrats screen, lol. Loading screen is custom and I'm using the normal song list for now. I also use a ShaderGlass application to add scanlines for a sharper look to the game and Xpadder to press "Keyboard Up" while shifting gears in order to see those exhaust flames.
SegaFan22
  • Insert Coin
« Reply #1180 on: March 14, 2024, 09:17:00 am »
Personally I use the arcade intro video [...]
Well those are just simple tweaks, there's nothing "incredible" there. I thought you had updated the mod itself or added new features.
polybius22
« Reply #1181 on: March 16, 2024, 01:04:49 pm »
It seems you've disappointed yourself by assuming things I never said. My post was just thanking those who have enhanced the game. FXT is the definitive way to play and makes a great game an incredible one tweaked exactly how we want. Whether or not that impresses trolls around here doesn't concern me a whole lot.
SegaFan22
  • Insert Coin
« Reply #1182 on: March 17, 2024, 04:56:25 am »
So I am a troll now  >:D
I was thinking (hoping) you had updated the mod and wanted to share it. I guess I was wrong and yeah, it's my problem. Sorry for wasting your time.
Lamaman1971
  • Last login:June 20, 2024, 01:44:56 pm
« Reply #1183 on: June 16, 2024, 09:16:35 am »
Hi Folks, its been a while since I looked at this - and wanted to get my cabinet up and running again. Does anyone have a link to the latest version of Howards FXT edition?
arquillos
  • Last login:January 19, 2026, 08:35:34 am
« Reply #1184 on: June 17, 2024, 04:45:06 am »
The page is avaiable (https://dragonking.arcadecontrols.com/static.php?page=AboutFXT) but the download is not working
Does anyone has a mirror link? Thanks  :dizzy:
« Last Edit: June 25, 2024, 09:12:18 am by arquillos »
insx
  • Last login:August 16, 2025, 06:17:23 pm
  • I dabble in Retropie and virtual pinball
« Reply #1185 on: June 20, 2024, 09:07:18 am »
The first thing I noticed was the animations when you reach the goal, which you don't get in the PC version. Such a shame, as these have always been a fun part of Outrun.
VirtuaIceMan
  • Last login:September 09, 2025, 07:52:27 am
« Reply #1186 on: June 25, 2024, 08:39:11 am »
The animations were large videos S0L of Sumo Digital said in the past. The Japanese PS2 version managed to have them included as it came out later (more dev time).
As for arcades, I noticed https://arcadeheroes.com/2024/06/04/location-watch-june-2024-new-arcade-venues-open-around-the-world/ saying Funbox (Gravity Max Westfield Stratford, UK) has a 4 car full SP SDX setup (pic on that link, just over halfway down the page).
Check out my racing game videos, including every PC F1 and Rally game ever, over here: https://www.youtube.com/user/VirtuaIceMan/
insx
« Reply #1187 on: June 27, 2024, 07:43:56 pm »
I've been selecting single player for so long that I'd forgotten about the SP arcade mode that does have the goal videos and credits.
I'm hoping to get to Gravity with some mates at some point. Until then, there's always the 2 car setup at Southend.
Habanero
  • Last login:October 01, 2024, 12:24:22 pm
« Reply #1188 on: July 12, 2024, 12:55:36 am »
Thanks for your work Howard. Has there been any progress from anyone on extracting 3D models? I wanted to try making some new livery textures for the cars.
sharkcheese
  • Last login:July 24, 2024, 07:45:03 pm
« Reply #1189 on: July 12, 2024, 12:39:34 pm »
Hello! I realize that it's not quite on-topic given this forum is more focused on replicating the arcade experience, but this thread has been a valuable resource for me and I figure there's probably some overlap in interest.OutRun2006Tweaks is a new mod for OR2006C2C that, among other fixes, allows for arbitrary replacement of textures. The game holds up great in 4K except for the UI and while there's been some trying to fill the gap with raw AI upscales, that was never going to be good enough for my tastes.
So I've been attempting to recreate the art from scratch in vector format, it's been going well but I've been tackling a lot of the low hanging fruit. There's a lot of art that are low resolution renders, ideally models from the game would be exported, posed and rendered in high resolution to match the original renders. There's a few assets from the press kit that can work, but not enough to cover everything. I'm pretty dumb when it comes to 3D so any help with this would be appreciated.
There's a thread for HD assets in the OutRun2006Tweaks github and a Discord link in that thread, if anyone is interested in contributing.
BigTinz
  • Last login:July 20, 2024, 12:26:01 am
« Reply #1190 on: July 14, 2024, 11:49:56 pm »
What's the best way to map the gear shift (up/down) to the right stick of my xbox 360 controller? It doesn't respond in the options menu.
The game feels great to control with OR2006Tweaks applied, but I haven't been able to replicate the gear stick like I have set up in TeknoParrot.
Gear drifting with a button press feels wrong...
« Reply #1191 on: August 16, 2025, 01:52:32 am »
So I recently bought a new racing seat so I thought I'd give the tweaks mod a try.   Most of it is excellent... except the force-feedback.....  so I guess fxt still has a purpose for now.   I fired up the wrapper and it's hanging at some stage, but according to my cheat engine table most (not all) of the memory locations I use to pull data from are still intact.  It should be possible to fix the wrapper, but I want to remove many features that are now redundant due to tweaks.  There are also unfinished features I need to complete and I would like to look into rolling some of my mods into tweaks as some of the stuff that requires graphical overlays would make more sense on it than my wrapper.
I'll have to try the texture packs to see what needs upscaled as I already had several textures ready to go for fxt.  I've had pretty good luck at taking the character textures (girlfriends, flag man, ect) and upscaling them with ai.   It looks like a lot of my content has been rolled into tweaks without me, which is fine, but it would have been nice if I was credited.
I am by no means working on fxt again, but I have a plan of attack now.
buttersoft
« Reply #1192 on: August 16, 2025, 07:31:28 am »
Nice to hear from you, Howard!
« Reply #1193 on: August 27, 2025, 12:17:37 am »
Likewise.
So I took an hour or so tonight to go ahead and see how badly outrun tweaks broke my fxt and to my surprise... not that much at all!   Xinput works, FF should work, all my control hacks should work and the overlay still works....
99% of the memory locations are also still in the same place, I think I found two or three that need changed.
The issue is window focus.... obviously the tweaks wrapper is doing hooking of its own and that is interfering with xinput rumble and controls provided by my wrapper.   If you click on any window generated by fxt (including the overlay) my stuff works.  The problem is outrun doesn't respond to controls unless it has focus, so it doesn't really work properly.   The good news is this is fixable... I'll just have to find the time to do it.   I also need to strip away features related to putting my own HD hud in place as well as a few redundant features like the horn.
Even though tweaks has xinput rumble I prefer my version.  Looking at the source it isn't mixing various sources like mine and is instead using the xbox rumble, which isn't exactly complete.  This is all stuff that could be added into tweaks though.   Assuming the author is ok with it the end goal should probably be to merge the two programs.  This is something I would be glad to work on but again, finding the time is the issue.
isamu
« Reply #1194 on: October 14, 2025, 09:36:26 am »
Great to see you're still around brother. Yes, those improvements and a way to enjoy a version of Tweaks that incorporates the best features of FXT would absolutely be welcomed. Keep us posted man  :cheers:
