Author Topic: Forstner  (Read 2671 times)
EssexMame
  • Last login:February 05, 2026, 08:12:04 am
  • Mame Weekender
Forstner
« on: March 05, 2013, 11:30:58 am »
A lot of talk here on the Forstner bit.
What is it used for (in Arcade Cabinets), and if you don't have one what's the alternative way of doing the same tasks?
spoot
  • Destroyer of electronics
Re: Forstner
« Reply #1 on: March 05, 2013, 12:04:42 pm »
Button holes mostly.   Otherwise, spade bit or hole saw.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Forstner
« Reply #2 on: March 05, 2013, 12:40:13 pm »
Pretty much what Spoot said.  Forstner are superior because they do really well "shaving" the wood away.  Hole saw's have trouble moving the wood particles away and can "burn" the wood.  Spade work but aren't always stable/good cuts.
Drnick
  • Plodding Through Life
Re: Forstner
« Reply #3 on: March 05, 2013, 01:34:57 pm »
http://www.ebay.co.uk/itm/Silverline-FORSTNER-DRILL-BITS-ALL-SIZES-Titanium-Coated-hinge-boring-hole-/150778417537?pt=UK_Home_Garden_PowerTools_SM&var=&hash=item231b181181
I just got the 1 a 30mm and have used it to cut all my button holes (Including the button holes in the perspex).
You can get cheaper sets, but as we should all know the cheapest option is not normally the best.
  • Last login:Today at 05:02:13 am
Re: Forstner
« Reply #4 on: March 05, 2013, 11:49:02 pm »
Another use for a forstner bit is for the inset/pocket (?) hinges like Mcseforsale used for the CP on The Blue Pill.
The hinge mounts in the flat-bottomed hole made by the forstner.
EssexMame
  • Mame Weekender
Re: Forstner
« Reply #5 on: March 06, 2013, 05:25:11 am »
Thanks (again!) all.
I've got a 28mm spade bit for the button holes, which I was happy with. It did "pop" out the bottom of the wood on my trial chipboard, but I'll get round that with a second scrap of wood clamped underneath next time.
I'd seen what features a Forstner bit had, but none seemed to relate to the cabinet except for holes which I was already happy I'd sorted :-) Still, if I get a router I may as well get a Forstner bit if they do holes easier/better.
yaksplat
    • Random Projects
Re: Forstner
« Reply #6 on: March 06, 2013, 10:21:22 am »
I use 1-1/8" for all button holes and 1-3/8" for the hinges.
I also use a 5/8" for predrilling plexi before routing.  My flush bit is 1/2" so I have 1/16"clearance for the bit.
http://yaksplat.wordpress.com
