Author Topic: GroovyArcade live-CD 2020  (Read 665897 times)
golvellius
  • Last login:January 08, 2021, 09:02:48 am
Re: GroovyArcade live-CD New Release 2019
« Reply #1000 on: April 08, 2020, 10:27:53 am »
Hi ..
My testting conf :
- Original intervideo chassis vp250.
- Original CRT 25" videocolor.
What i have tested is that it is only working with 320x240eS. If i am using 320x240S then i get bios boot and when boot linux i get no image ..
Now i checked. 640x480eS . but no luck :'( :'(
I have attached my atom1.5 BIOS modification...
Thanks ..
« Last Edit: April 08, 2020, 10:37:21 am by golvellius »
golvellius
« Reply #1001 on: April 08, 2020, 10:35:33 am »
Hi Substring .  Sorry for my repeating question .
My config :
Original chassis intervideo vp 250. CRT controller.
Original CRT videocolor 25¨.
PC Intel core DUO 2,6 GHZ 2GB RAM and HD4450 modified by ATOM v1.5. My vga to crt cable it is a selfmade cable with 2x 1k resistors for the H/V sync. This cable works with other CRT TV that i have tested.
The only working resolusion for me it's 320x240Se. I have tested 640x480Si and Se .. And others..
Maybe it is a problem of my chassis .. but this chassis works with other original arcades ( snow bros and pang.).
I can play mame at 320x240 .. but frontend looks uggly...
Thanks for all ..
« Last Edit: April 08, 2020, 10:38:29 am by golvellius »
Substring
  • Last login:January 22, 2026, 05:27:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #1002 on: April 08, 2020, 11:11:07 am »
It ma
Hi..
I have the same problem .. if i use in the syslinux.cfg the parameter video=VGA-1:320x240eS , my monitor intervideo does not work.. I have used also 640x400Se, but i get triple image ... also 640x480Se does not work ... What others resolution can i try .. ?
So when i used my 14 '' TV i can use 640x480iS in my intervideo i can not ...
Thanks ..
then
I'm lost  :o
golvellius
« Reply #1003 on: April 08, 2020, 02:20:18 pm »
Sorry i made a mistake ..
if i use in the syslinux.cfg the parameter video=VGA-1:320x240eS , my monitor intervideo WORKS .. Only with this resolution.
Meanwhile i have installed version GroovyArcade-Arch2018.03.04-x86_64. All works ..
Maybe some problem in kernel and my graphic card ...
Also i have tested groovymame  2019 latest version .. It get stuxks when start x11 ... But this problem i have before also when using small tv's..
Thanks ..
« Last Edit: April 08, 2020, 03:03:46 pm by golvellius »
Substring
« Reply #1004 on: April 08, 2020, 04:02:42 pm »
Why bother with another video mode if 320x240 works ?
golvellius
« Reply #1005 on: April 09, 2020, 02:33:46 am »
Hi Substring ..
First of all would like to thank you :applaud: for your great patiente  .. I am new with this of the arcade world ...
The problem that i have with 320x240 resolution it's that i see the letters of the commandline and gasetup like in a zoom mode .. very big letters (aprox size letter 25) so i can only read part of the commandline and gasetup .. and attrack mode menus are without definition(uggly).
After a lot of testing , i decided to use your latest distro , i am going to explain the whole precess that i used:
a) I have boot with a usb pen with distro groovyarcade-2020.04-x86_64.iso
b) In boot menu i have selected VGA-1_15khz.
c) Everything it is ok , but screen gets black. Suddenly message appears ( if i can see the image or something similar , and  press ok) and starts the voice guidance .. when system switched on the vga i see a screen  message and press ok.
d) Then it automatically selects VGA-1. Later i selected monitor generic 15khz. the first option.
e) Install the distro to my hardisk.
f) Reboots the system.
g) Now letters are super big. but i can see something.
h) In gasetup i enter to change resolution .. now i can select 6 types of resolution-- 320x240, 320x388 640x4xx. etc .. i SELECT 640x480 Interlaced.. and restarted.
i) Now works .. i can see the letters and images in gasetup correctly .. screen are perfect.
Looking at the sysconfig.cfg now i have this mode .. video=VGA-1:640x480iSe ...  :applaud:
Now i have a good resolution in attrack mode and command liine.
Thanks Substring for your great help .. and continue with your great work of porting this linux arcade system ...  :applaud: :applaud:
Bye
« Last Edit: April 09, 2020, 02:39:40 am by golvellius »
Substring
« Reply #1006 on: April 09, 2020, 04:07:14 am »
So the menu to select the video boot mode works ^^ i've rewritten it a week ago, didn't want to let you test that ... But great ;)
paaar
  • Last login:February 11, 2021, 08:06:23 am
« Reply #1007 on: April 09, 2020, 07:49:21 am »
Good new here too =) It's easter and all so the easter bunny must have delivered.
Thanks for all the help!
Anyway, I also got it to work when I added the  video=VGA-1:320x240eS in syslinux.cfg.
This forced an output on the vga.
So to recap what I did:
Using the groovyarcade 2020.03 iso.
HW: intel i5 computer with AMD HD4550(with atom15).
During install using an Lcd monitor connected to the vga port.
But later on using an arcade crt monitor 15khz 320x240 resolution.
1. Install as instructed.
2. After reboot ,ssh into the machine, generate a new EDID that works with 320x240 to get the right resolution after reboot.
sudo switchres 320 240 60 --edid --monitor "generic_15"
sudo mv generic_15.bin /usr/lib/firmware/edid/generic_15p.bin
sudo nano /etc/mkinitcpio.conf
Added the in the end of FILES= on row 19, /usr/lib/firmware/edid/generic_15p.bin
 This will give a build error, later on, if there is something wrong here, which I experienced.
sudo nano /boot/syslinux/syslinux.cfg fixed the drm.edid_firmware=VGA-1:edid/generic_15p.bin monitor=generic_15
 sudo mkinitcpio -p linux-15khz
3. Also add video=VGA-1:320x240eS in the end of the syslinux.cfg
4. Reboot.
To note that the switchres may need a new version
You may also enable groovyarcade testing repo (edit /etc/pacman.d/groovy-ux-repo.conf and remove # on the 3 first lines), run sudo pacman -Sy switchres, confirm you want to upgrade.You now have a good version of switchres that can build a 320x240 edid like explained earlier.
Also, correct me if I'm wrong here, Substring, but the new version of switchres will be included in the next release or ?
Substring
« Reply #1008 on: April 09, 2020, 08:24:51 am »
New switchres will of course be un the coming release. But the package has been pushed in the stable repo, so it's easy to update, no need of editing any file
ves
  • Last login:April 11, 2020, 02:57:49 am
Re: GroovyArcade live-CD New Release 2020
« Reply #1009 on: April 11, 2020, 02:49:59 am »
GroovyArcade live-CD Release 2020
This is still the stable version with classic settings, before the big changes.
New AdvmenuPlus 2.9
New galaxian bdf font for texts in GM menu.
Fixed littelt issue etc...
golvellius
« Reply #1010 on: April 11, 2020, 10:23:10 am »
Hi .. to all ..
Finally i have this supperb emulation machine GroovyArcade 2020 working with MAME and  my jamma usb conversor model 3H Dual Arcade. If you want to use it , you need to add in the syslinux.cfg file the next line at the end of the kernel parameter line beginning with append ...  usbhid.quirks=0x16c0:0x75e1:0x40 .
Then you can use the double player option for this jamma usb conversor ...  :) . If not it is detected as only one player.
Also, how can upgrade my distro to the latest one without reinstalling ?
And if i wanted to add snes , msx , amiga , etc ... emulation it is there a tutorial .. or a recommended guide ?
Thanks for all .. And GREAT JOB..
« Last Edit: April 11, 2020, 10:24:56 am by golvellius »
Substring
« Reply #1011 on: April 11, 2020, 12:07:46 pm »
USB quirks, yeah, I could make this a little more plug'n'play (I have a bunch of quirks from past retrogaming projects). They can't be all added, but it's good if you've found out that by yourself.
For upgrades: run sudo pacman -Syu. Most of times, it's safe. I just noticed otoday that an update breaks the GA boot logo ... More work to do to make this normally integrated ...
Now for consoles : I've simply removed anything linked to consoles for a BIG list of reasons and tbh, at the moment, I can't make any support for them, I have way too much to do for GA and other things related to GroovyMAME. You may try your luck with RetroArch that is 15kHz capable, but haven't had time to try it yet.
keilmillerjr
  • Web Developer.
« Reply #1012 on: April 11, 2020, 04:10:35 pm »
@golvellius mame supports amiga, msx and snes. Try it. Many people forget that mame and mess merged.
Beaps
  • Last login:July 09, 2020, 10:46:40 am
« Reply #1013 on: April 15, 2020, 06:15:50 am »
How do you dissable interlaced mode in attract mode to stop it crashing please. Also what mame rom set are you using. I'm trying the classics and the seem to not load (Rainbow Island, SF Hyper Fighting etc)
« Last Edit: April 16, 2020, 06:06:49 am by Beaps »
gambaman
  • Last login:May 19, 2024, 10:56:28 am
  • SCART VADER
    • hackaday.io/gambaman
« Reply #1014 on: April 16, 2020, 10:19:13 pm »
Thank you. I installed it in a laptop with an Intel mobile GM965/GL960. The standart VGA modes of the front-end are correctly displayed, but when it tries to execute an emulator at 15KHz the VGA output is disabled. Any suggestion?
RVZ
  • Last login:November 07, 2025, 03:28:50 pm
    • Metal Slug!
« Reply #1015 on: April 19, 2020, 04:50:48 am »
I want to try out GroovyArcade before wiping my drive and installing it.  I should be able to run the frontend from a usb stick right?  I go through the video setup, but then get an error "server terminated with error (1)" when trying to start the frontend.  Also doesn't matter which frontend I choose.
*fixed*  Downloaded the latest version and it's working now.
« Last Edit: April 19, 2020, 06:48:00 am by RVZ »
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
« Reply #1016 on: April 23, 2020, 10:07:30 pm »
Hi All,
I did a fresh install of 2020 and I am having trouble with advmenu. I am unable to load custom layouts using emulator_file_custom or emulator_layout keywords. Please note earlier GroovyArcade CDs worked fine.
What is the correct method for loading external .amp layouts now?
Cheers,
Matt
golvellius
« Reply #1017 on: April 24, 2020, 03:47:43 am »
Hi to all..
I am enjoying a lot this distro. I am using it in mame environment ... ALL PERFECT.
Now i have been playing with retroarch ... I have installed it with pacman app,  and i have some questions .. if someone can help me ...
a) When playing games, snes games as example, i think i am playing 640x480 to the CRT and it is not changing to correct resolution .. I have been reading forums and faqs but there is not too much info .. After touching parameters, sometimes the output of monitor is black, sometimes it is small ... etc .. also coredumps ...  :embarassed:
b) Is possible to use switchres like in  Mame in Retroarch? HOW?
Thanks a lot ...
Beaps
« Reply #1018 on: April 25, 2020, 11:03:41 am »
I've got one of them mr.spinner spinners and I'm trying to use it with GA. I've enabled mouse support but nothing. The spinner works ok in windows, anyone got any ideas to get it running please.
meestermole
  • Last login:November 16, 2023, 01:04:35 pm
« Reply #1019 on: April 26, 2020, 07:00:31 pm »
Is there a changelog for each version of GroovyArcade, or would it be at all possible to update the main post in this thread with the versions in the current release?
gg339
  • Last login:May 20, 2020, 07:11:35 am
« Reply #1020 on: May 18, 2020, 06:03:50 pm »
Hello,
I noted Ves's post earlier which pointed to the 'latest classic release of GroovyArcade-Arch2020.04.08', and I also read Substrings comment in this thread
[url]http://forum.arcadecontrols.com/index.php/topic,161125.40.html]
http://forum.arcadecontrols.com/index.php/topic,161125.40.html querying which version of GA was the poster using.
Can I ask therefore if there are different (parallel) versions of the latest GroovyArcade from both Ves and Substring?
Apologies if this is confusing...
Substring
« Reply #1021 on: May 19, 2020, 12:59:00 pm »
I could answer, but I'd sound harsh and mean.
Let's just say I've forked VeS' GA and continuously update it following the Arch linux philosophy: continuous kernel updates, ditto groovymame. And all if this is normally updated using the official Arch package manager: pacman.
gg339
« Reply #1022 on: May 19, 2020, 02:58:49 pm »
Substring,
Thanks for your reply.
I actually downloaded and ran with your fork, and so far so good for my setup. While I'm not totally green to linux, the finer points and workings of it still elude me. I have tried and mostly successfully have had GA running for the last few years, albeit with some issues relating to groovyarcade speeds, sound, monitors etc.
I have your GA fork up and running on my setup (ArcadeVGA5000, WG 25K171, and ipac) in under 10 minutes from start to finish, and it looks pretty damn good, and I'm very happy. Thank you for your, and others' contributions here that has allowed this to be possible.
As it is something I've always wanted to learn more about, I'm going to run up a virtual system, and look at least at getting to grips with linux, compiling sources etc, and generally try to expand my knowledge somewhat.
As regards your current fork, how do I ssh to console - I've tried putty but it cannot agree on encryption algorithms (although I've uploaded ROMS fine through WinSCP)?
Thanks again - looks like this will sort my arcade machine out for a long time to come!
Substring
« Reply #1023 on: May 19, 2020, 04:47:06 pm »
Just ssh to the IP, the encryption is negotiated by the client abd server, you don't need to configure anything.
I'm glad you got GA installed that fast, windows can't beat that ! A fully configured CRT Arcade OS in 10mins ^^
gg339
« Reply #1024 on: May 19, 2020, 05:23:30 pm »
yep - I expected the same - however putty is refusing, saying cannot negotiate a common set of encryption algorithms.
In any case, I did what I needed to do via the console (getting name resolution up and running via my local nameserver), so everything is fine in any case.
Thank you again
roostaar
  • Last login:January 22, 2026, 12:17:19 pm
« Reply #1025 on: June 15, 2020, 05:55:03 pm »
Hi guys
I have installed GA2019 on a few machines and got it setup perfectly.
I thought I would try the GA2020 on a new machine, and while it's installed OK, I cannot SSH into it with Cyberduck.
I can SSH via terminal on OS X.
Any ideas? I want to copy my files and settings from old to new...
Also is there an easy way to update the GA2019 machines with GA2020?
Thank you
EDIT: I had a hideously outdated version of Cyberduck on my laptop. Yuk!!!!! I hadn't realsised as it had always worked whenever I used it. I copied the newer version from my iMac and now can SSG. There's an evening wasted...
If anyone knows if GA2019 can be updated to GA2020 without a clean install, please let me know how! Thank you!
« Last Edit: June 15, 2020, 07:22:40 pm by roostaar »
keilmillerjr
  • Web Developer.
« Reply #1026 on: June 17, 2020, 04:36:10 pm »
Last I knew, the update features were incomplete/broken. Check out the collaboration version of GroovyArcade. Updates in that are working and constantly being updated.
meestermole
Intel sound issues? alsamixer wont run - worked previously
« Reply #1027 on: July 03, 2020, 05:59:40 pm »
Hello there wonderful arcade enthusiast folks!
I have been using GroovyArcade pretty much since the beginning, or at least before AM got added as a frontend option.
I'm generally pretty handy with my Linux-fu, especially within the confines of the GroovyArcade release cycle.
I generally don't have troubles upgrading the binaries, or diving into the configs and tweaking.
I even managed to get Daphne working a while back, but I have a hard time playing those games.
I seemed to find the best success with the 2018 iso - and I've been using that for a while, but it runs GM0.195
I decided to get my sets up to date and current and whatnot, and also noticed that there was a newer release from April of this year.
Anyhow, I went through the typical install - Ive been using surplus Dell Optiplex 755s for years without issue.
With this latest release, I have no (perceptible) sound. I am unable to run alsamixer - I get an error "cannot open mixer: Invalid argument"
So i hooked everything up to an LCD screen in an area with a network connection (alas, no cat5 runs to my cabinets in the garage)
and tried reinstalling alsa-utils, alsa-libs, alsa-drivers - to no avail.
I messed with the .asoundrc file and didnt really yield any results.
So i decided i would update the system by running pacman -Syu
Well, it seems that worked and i had sound quite clearly and was able to run games......on LCD
However, when putting the Atom-15 flashed card in there, i get a blank screen (i see the bios,no OS)
So i restarted the entire install (many times at this point) in my cabinet, and ran a CAT5 to it so i run the update on the system as it will be in the cabinet (It's a DigDug, btw)
Same results - after the update and reboot, I see the BIOS screen, then no OS loads - i just get a blank screen.
Could it be that the kernel updated and blew out the 15Khz patches?
Then i stumbled across a few of these threads, regarding issues of no sound after updating to kernel 5.6.2...
https://bbs.archlinux.org/viewtopic.php?id=254408
And another this time with 5.6.14 i think
https://bbs.archlinux.org/viewtopic.php?id=256070
So i used uname to get the installed kernel version and it is 5.6.2
It seems like this issue has been resolved in a newer kernel, but i am not sure how to make the Groovy-ness persist.
Should i just wait for the next release, or is there something that i may be overlooking(thinking) that i could do?
Any insight would be greatly appreciated. If I can provide any additional info, i can oblige.
 :banghead:
Substring
« Reply #1028 on: July 04, 2020, 11:12:21 am »
I shouldn't be saying that, but .... https://github.com/substring/os/releases/latest is a much more up to date distro ... Made by someone else (well ... me heh). Give a try as a livecd, no need to install even.
meestermole
« Reply #1029 on: July 04, 2020, 11:38:31 am »
Much appreciated. I will give it a go. Whatever works, you know?
DreyMIX
  • Last login:May 10, 2024, 01:28:11 pm
« Reply #1030 on: July 17, 2020, 03:37:55 pm »
Hi, since I am using a J-PAC with the default keys. When I am in the Attract-Mode front-end or inside a game and accidentally press the button 1 + the button 2 + the right or left direction, I go into desktop selection mode. I also checked with the keyboard and pressing CTRL + ALT + arrow does the same thing. Is it possible to disable this function? I am using the Substring release.
I don't want to configure the keys differently, I prefer to leave the default ones of MAME.
Thx!
Substring
« Reply #1031 on: July 17, 2020, 05:04:18 pm »
Ah yeah, i was told about that.something to do with openbox, which xml file contains some key combos. Don't have more information at hand, do you need some more help ?
DreyMIX
« Reply #1032 on: July 17, 2020, 07:07:35 pm »
What information do you need?
I'll show you a photo of the control panel, so maybe it's easier to understand. Practically the J-PAC interface associates keyboard keys with each buttons or stick. I wanted to leave the default ones, so that they match MAME. Without changing anything.
When I press the right or left stick + button 1 + button 2, a small window appears in graphics with the possibility of switching the desktop windows 1, 2, 3 and 4.
if you try on the keyboard (CTRL + ALT + right or left arrow), you will see that window will appear.
Substring
« Reply #1033 on: July 18, 2020, 03:02:28 am »
By information I meant which file you need to edit, and what to remove ;)
DreyMIX
« Reply #1034 on: July 18, 2020, 04:55:12 am »
I did some internet research about Openbox. I found this guide:
http://xahlee.info/linux/linux_lxde_add_key_shortcuts.html
If you scroll to the end, there is a section called "Remove Keys":
To remove keys, just delete the proper section.
For example, i want to remove Ctrl+Alt+→ (because i need it for emacs). I delete the following:
<keybind key="C-A-Left">
  <action name="DesktopLeft">
    <dialog>no</dialog>
    <wrap>no</wrap>
  </action>
</keybind>
<keybind key="C-A-Right">
  <action name="DesktopRight">
    <dialog>no</dialog>
    <wrap>no</wrap>
  </action>
</keybind>
<keybind key="C-A-Up">
  <action name="DesktopUp">
    <dialog>no</dialog>
    <wrap>no</wrap>
  </action>
</keybind>
<keybind key="C-A-Down">
  <action name="DesktopDown">
    <dialog>no</dialog>
    <wrap>no</wrap>
  </action>
</keybind>
I have to go edit the file "~/.config/openbox/lxde-rc.xml"?
Substring
« Reply #1035 on: July 18, 2020, 05:43:26 am »
I was told about ~/.config/openbox/rc.xml rather
Are you tsarting AM from.lxde ?
DreyMIX
« Reply #1036 on: July 18, 2020, 05:54:43 am »
ok, as soon as I have a moment check that file.
No. I set AM as the default boot on GAsetup.
DreyMIX
« Reply #1037 on: July 18, 2020, 01:39:55 pm »
Problem solved! The correct file is "/etc/xdg/openbox/rc.xml"
I commented on this whole part:
<!-- Keybindings for desktop switching -->
    <action name="GoToDesktop"><to>left</to><wrap>no</wrap></action>
  </keybind>
    <action name="GoToDesktop"><to>right</to><wrap>no</wrap></action>
  </keybind>
I quit from AM with ALT+F4 and restarted it immediately. The key combination was no longer active!
Abducido
  • Last login:August 03, 2020, 06:57:27 pm
« Reply #1038 on: August 03, 2020, 06:20:36 pm »
I updated from a 2014 version and now my controls are not working in parallel before I had openppjoy I think there are some changes to make, try ecp epp
dell optiplex 755
« Last Edit: August 03, 2020, 06:28:39 pm by Abducido »
Josh128
  • Last login:January 09, 2021, 11:32:25 am
« Reply #1039 on: September 21, 2020, 08:56:27 am »
Hey guys, got a sweet i56500 HP machine that I'd like to try this on-- question though-- is there the Linux equivalent of CRTEmuDriver / ArcadeOSD on the GroovyArcade CD?  In other words, the drivers needed to get the 15/25KHz resolutions working on an AMD HD5450 GPU?
