Author Topic: GroovyArcade live-CD 2020  (Read 675404 times)
  • Last login:Yesterday at 06:15:36 am
Re: GroovyArcade live-CD New Release 2013-02-24
« Reply #80 on: March 19, 2013, 08:50:11 pm »
Yeah this is the problem i dont have an installation of Linux, and its doesnt seem worth installing it just to copy the roms etc over the rom folder that GA creates. Plus ive never used Linux in my life
That's why the idea for Windows users is to install it on a pendrive so you can boot your Windows machine with it and access your roms directly without even having to type a word in a Linux console or copying files or anything.
I just thought if i did the partition in windows, i can skip this step in your installation guide thus not wiping the whole of the USB stick. I had to do this for my test run of installing GA, where i was getting the error message, "FATAL ERROR: Bad Primary Partition 1: Partition begins after end-of-disk. Press and key to exit cfdisk". To which you suggested just creating the partition in windows and skipping the step in your guide?
No. I just suggested that because the Linux partition tool couldn't figure out your partition in order to wipe it, probably because it came preformated in an odd way. Now that you deleted the partition in Windows you can quite probably use the Linux partition tool to wipe it again without problems. But the thing is, you really need to let Groovy Arcade autopartition your pendrive, that's the only easy way to get it installed for a novice user. You can do some fancy installation but you really need some knowledge on the Linux system, for instance I can't do such things that's why I'm recommending this way.
« Last Edit: March 19, 2013, 08:57:23 pm by Calamity »
lettuce
  • Make It So!
« Reply #81 on: March 20, 2013, 06:14:38 am »
I was under the impression that if you make 2 partitions on a storage device then its treats that device as 2 separate harddrives, so unless Linux sees this differently then surely when i run the installer and get to the partition step it will see the USB stick as 2 different drives and only wipe the partition (drive) that i tell it to the other partition (drive) will still be intact??
If this isnt so then im going to have to brush up on Linux, as thats the reason i got this 64GB USB stick so i could have everything on the USB stick
« Reply #82 on: March 20, 2013, 06:57:13 am »
Ok, I see your point, you're making the same assumptions that I did when I first tested this, but it doesn't work like that actually. The partition tool will "see" only one physical pendrive. Remind the installer script performs *autopartitioning*so the operation is easy enough for non-Linux users, and you don't have to learn the details. Of course you can skip the 'autopartitioning' and tell the installer to target specific partitions, so only the specified partitions will be wiped. But then you have to be ready to learn how grub works and things like that in case you run into issues (and you will). These issues are trivial for Linux users, but are much like a stone wall when you come from the Windows world.
That's why the automatic partitioning was created I believe. The problem with "automatic" features is that when you don't have them, people complain about things not being automatic enough, but when once you have them, people complain because they can't do things they way they'd like.
I'm telling you it's quite possible to do that, you only need to *copy* the roms once the system is installed. Once you boot your system from the pendrive, you could transfer the roms easily from a external usb HD or something like that, by using the windows-like environment built in Groovy. I'm thinking this might be easier than figuring out custom partitioning.
lettuce
  • Make It So!
« Reply #83 on: March 20, 2013, 07:50:03 am »
Ok, the transferring roms from a USB harddrive sounds like a plan. I'll let you know how i get on
lettuce
  • Make It So!
« Reply #84 on: March 20, 2013, 09:34:08 am »
Thank you guys!!!!
lettuce, GroovyArcade its possible to use as multisystem,hyperspin is not supported on Linux, its not necessary, AdvmenuPlus or Wahacade are really good.
Just looked at Wahcade on YT, and i like it over AdvmenuPlus, is there a way to move over to Wahcade??
jswagner
  • Last login:September 11, 2020, 03:09:00 am
« Reply #85 on: March 23, 2013, 07:56:07 pm »
BUG:  In Nestopia, A and B buttons are mapped in reverse.
Fix:  Edit ~/.nestopia/nstcontrols, change:
P1A _LCTRL
P1B _LALT
to
P1A _LALT
P1B _LCTRL
« Last Edit: March 24, 2013, 03:24:06 am by jswagner »
jswagner
« Reply #86 on: March 23, 2013, 08:03:33 pm »
PROBLEM:  My system can't run NES through Nestopia (default NES emulator) at full speed.
Fix:  Try Mednafen's NES core.
Open ~/.advance/advmenu.rc, change this:
emulator "NES" generic "switchres" "nes --emulator nestopia --rom %p"
to:
emulator "NES" generic "switchres" "nes --emulator mednafen --rom %p"
Open ~/.mednafen/mednafen-09x.cfg, change this:
Find the set of lines that start with ";nes, Port 1, Gamepad:", and replace with these:
;nes, Port 1, Gamepad: A
nes.input.port1.gamepad.a keyboard 308~keyboard 120
;nes, Port 1, Gamepad: B
nes.input.port1.gamepad.b keyboard 306~keyboard 122
;nes, Port 1, Gamepad: DOWN ↓
nes.input.port1.gamepad.down keyboard 274
;nes, Port 1, Gamepad: LEFT ←
nes.input.port1.gamepad.left keyboard 276
;nes, Port 1, Gamepad: Rapid A
nes.input.port1.gamepad.rapid_a keyboard 115
;nes, Port 1, Gamepad: Rapid B
nes.input.port1.gamepad.rapid_b keyboard 97
;nes, Port 1, Gamepad: RIGHT →
nes.input.port1.gamepad.right keyboard 275
;nes, Port 1, Gamepad: SELECT
nes.input.port1.gamepad.select keyboard 32~keyboard 91
;nes, Port 1, Gamepad: START
nes.input.port1.gamepad.start keyboard 49~keyboard 93
;nes, Port 1, Gamepad: UP ↑
nes.input.port1.gamepad.up keyboard 273
Replace:
;Full-screen horizontal resolution.
nes.xres 0
with:
nes.xres 256
And finally, replace:
;Full-screen vertical resolution.
nes.yres 0
nes.yres 240
« Last Edit: March 24, 2013, 03:24:41 am by jswagner »
jswagner
« Reply #87 on: March 23, 2013, 08:19:45 pm »
Mapping buttons in Mednafen:
If you intend to play with some of Mednafen's other emulation cores, you might have some difficulty remapping the keys:
Open ~/.mednafen/mednafen-09x.cfg, and then correct these lines:
;Configure buttons on virtual port 1
command.input_config1 keyboard 49+alt+shift
;Configure buttons on virtual port 2
command.input_config2 keyboard 50+alt+shift
That's ALT+Shift+1 for Controller Port 1 and ALT+Shift+2 for Controller Port 2.  This will be handy for users who want to add Mednafen's excellent PCE, Gameboy Advance and PlayStation cores to their GroovyArcade systems.
« Last Edit: March 24, 2013, 03:23:49 am by jswagner »
« Reply #88 on: March 25, 2013, 05:35:42 pm »
Sure, but you'll probably need to configure it yourself (I've no experience with Wahcade yet).
« Reply #89 on: March 25, 2013, 05:42:48 pm »
@jswagner,
Thanks a lot for the information. I really like Mednafen, we probably should set is as the first option for all supported systems. It works very well with Switchres too.
NightSprinter
  • Last login:June 17, 2018, 08:59:56 pm
« Reply #90 on: March 26, 2013, 03:46:10 pm »
Dumb question, but is it recommended to just install over an existing Groovy Arcade setup.. or..? *confused*
It doesn't matter how bad things are, it'll work out in the end.
« Reply #91 on: March 26, 2013, 03:58:19 pm »
In theory that's what it was designed for, so during the installation you can select the roms partitions that won't be modified, while the main partition will be formated.
NightSprinter
« Reply #92 on: March 26, 2013, 05:29:12 pm »
Ah, my roms collection is on an external drive.  I was curious as I have games and additional emulators set up on the install's root partition.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #93 on: March 27, 2013, 04:08:19 am »
Great Job!
Enviado desde mi iPad con Tapatalk HD
lettuce
  • Make It So!
« Reply #94 on: March 27, 2013, 12:44:24 pm »
can you tell me what option i need to select in grub to copy the rom folder from a USB HHD to my USB flash stick please?
Also have notice that the games are running too fast, like 250%, im guess throttling must be on, how do i disable it?
« Last Edit: March 27, 2013, 12:56:52 pm by lettuce »
« Reply #95 on: March 27, 2013, 01:16:37 pm »
Hi lettuce,
Are you running this on your target machine? I'm asking this because of the crazy speed. You can't expect a reliable sync from an Intel card or something like that.
To copy your roms you'll need to launch the desktop, it's named LXDE. In gasetup (not grub), go into Setup -> System setup -> Front-end / window manager, then select LXDE. Go back to the main menu and select "Start Front-End/ Window manager."
You'll see a windows-like desktop. Press Windows-E and it will launch a file explorer. Now it's a matter of copying a folder from a place to another one. Now make sure you understand this: in Linux you don't have drive letters like C:\, D:\, etc. Instead of that each drive is "mounted" as a folder in an unique tree that represents the whole system. Groovy Arcade mounts local and external drives inside a folder in the root path named "media". Inside /media you'll find your disks. Browse to the desired path to copy the files.
In order to paste them into your USB pendrive, go back to the root path, and enter /roms, then you'll see the default folders for each emulator. Notice that MAME roms folder is not /roms/mame as you would expect, but /roms/roms.
Make sure you place your MAME roms directly in /roms/roms, not in a subfolder inside /roms/roms (obvious but anyway).
Report back.
EDIT: Once you finish, logout and go back to gasetup, then you'll need to undo your previous steps and select AdvanceMenu back as your front-end, otherwise it will launch LXDE all the time.
« Last Edit: March 27, 2013, 01:20:15 pm by Calamity »
lettuce
  • Make It So!
« Reply #96 on: March 27, 2013, 01:36:09 pm »
Yeah im running on the PC that will eventually go into my cab. It has a 4000 series ATi card if i remember rightly and is using a brand new 15khz arcade monitor. The test i did with the World Rally as suggested in the setup of Groovyarcade ran at 100% fine, but not sure why all games are running way too fast now?
Also i have notice that on some games i sometime have about an inch border at the top of the screen, i have the V shift pot turned as far as it will go on the monitors control borded, is there anyway in grooyarcade to get the screen to shift up anymore?, as im unable to move it up anymore using the control board for the arcade monitor??
« Last Edit: March 27, 2013, 01:38:58 pm by lettuce »
« Reply #97 on: March 27, 2013, 01:47:12 pm »
If it worked before it should work now. Try pressing F10 to see if it makes any difference.
Once you have your system up and running you may define a custom crt_range for your monitor, reducing the vertical back porch. Probaby your monitor can work with a short back porch if it's a moder one. That will shift the picture up.
lettuce
  • Make It So!
« Reply #98 on: March 27, 2013, 01:50:08 pm »
Yeah i tried that but it didnt seem to change the speed. How do i disable the throttle option, as it has to be that that enabled for some reason?
Quote from: Calamity
can you remind me how to do that again please
« Reply #99 on: March 27, 2013, 01:56:32 pm »
Actually -throttle must be on. Unless you've manually disabled it in mame.ini it should be on.
When you're ready, open a new thread for this with your monitor type in its topic name.
lettuce
  • Make It So!
« Reply #100 on: March 27, 2013, 01:58:44 pm »
Are you saying that it has to be/should be enabled all the time?. As i havent altered any settings in mame.ini at all. I followed your guide, once it had all installed and the system rebooted and loaded into the FE the first game i selected i noticed it was going way too fast, upon freeing F11 i noticed it was going 250 odd %
« Last Edit: March 27, 2013, 02:03:02 pm by lettuce »
« Reply #101 on: March 27, 2013, 02:10:26 pm »
It must be on, it is on by default in mame.ini. It used to be like you say that you needed to turn it off but it's no longer like that since some versions of GroovyMAME, now it needs to be on, otherwise -syncrefresh is ignored and it would go full speed. Unfortunately it looks like sync events are not properly reported in your system and thus it goes full speed. But it's also strange that it worked first and now it doesn't. Try booting from the live-cd again to double check.
lettuce
  • Make It So!
« Reply #102 on: March 27, 2013, 02:33:14 pm »
Ok i will trying that, its copying over the roms to the USB stick atm and taking its sweet time
« Reply #103 on: March 27, 2013, 02:53:54 pm »
Ok, so you found your way through LXDE, that's good.
Once it finishes, try something: run the video setup again, select your monitor etc. Then try launching games again.
lettuce
  • Make It So!
« Reply #104 on: March 27, 2013, 03:31:57 pm »
Ok will do, one last thing, whats the correct location for the snaps file as theres a few?
« Reply #105 on: March 27, 2013, 03:50:02 pm »
I can't tell it from the top of my head, but it should be inside /roms too (?), possibly, look for a folder where the wrally, robby etc. png files are.
lettuce
  • Make It So!
« Reply #106 on: March 28, 2013, 02:50:54 pm »
Now that ive copied the roms and snaps to the USB stick do i have to go back into the grub menu and to "Setup (video, audio, network, etc.)" menu and change the rom and snap path, as i previously set it to my USB HHD, but now ive copied all those roms and snap files to the USB stick i no longer what groovyarcade to look there???
Also i noticed in  Setup -> System setup -> Front-end / window manager there is WahCade list as well, if i tell groovyarcade to load that instead of AdvmenuPlus, is that going to cause me any issues??
« Reply #107 on: March 28, 2013, 03:18:50 pm »
In the roms/snaps paths menus there are options to setup all paths to default. Use those.
Try AdvMenu first. If you prefer WahCade you have that option in gasetup, but I believe you'll need to launch LXDE and use the shortcuts on the desktop in order to complete setup (I haven't tested that).
lettuce
  • Make It So!
« Reply #108 on: March 28, 2013, 06:52:35 pm »
Ok, set the roms and snaps back to default after i copied all the roms and snaps to the USB stick, but it just shows the default few roms. I then even pointed GroovyArcade to the rom folder again (home/roms/roms) and it still only showed the default games. I know the roms are in that folder cos i looked with LXDE and there all in there!!, though they are .7z zip files not rar...but that shouldnt make a difference as when they were on the USB HHD it showed all the roms fine.
Regarding the super speed im getting i booted from the CD again and loaded World Rally and the speed was fine, any ideas whats happening here?
« Reply #109 on: March 28, 2013, 07:07:45 pm »
That's odd, try re-adding the default path as if it was a custom path, by means of "Add roms path", etc. but pointing to /home/roms/roms.
As for the video speed issue, repeat the video setup, and possibly disable the splash screen from the "video grub" menu, and restart. It's the only thing I can think of.
lettuce
  • Make It So!
« Reply #110 on: March 28, 2013, 07:14:48 pm »
Yeah thats what i did after setting the roms back to the default path setting didnt work. But it still only showed the default roms.
Im in the process of reinstalling GroovyArcade on the USB stick again and see what the out come is
« Reply #111 on: March 28, 2013, 07:16:56 pm »
Ok. Instead of copying all roms which takes time test copying a few to see if you get them shown.
lettuce
  • Make It So!
« Reply #112 on: March 28, 2013, 08:06:41 pm »
Ive had it a few times happy with the prviosu install and its just happened the first time ive rebooted from the USB stick on this fresh install now, where its doesnt boot into Advmenu, but hangs after the splash screen with about 2 lines of text on a black screen, which says something like:
systemd-fsck[113] GA: clean GA: clean 74154/3033856
Systemd GAboot was not cleanly unmounted
any ideas why this happens
lettuce
  • Make It So!
« Reply #113 on: March 28, 2013, 08:41:53 pm »
Ok, i finally managed to get the USB stick to boot into Advmenu after about 4 attempts (really not sure why it doesnt always boot??) , and select World Rally and it was still running at over 200%!!. I then disabled the splash screen as you suggested and now its is running at the correct speed!!  :applaud:. Any ideas whey the splash screen would cause the games to run too fast??
On to copying the roms over to the USB stick, it would appear as i downloaded the merged 0.148 rom set they are all in .7z file format and not .zip or.rar, looks like Advmenu cant display .7z roms??
Is there a program about that can rename all 148 roms from .7z to zip or rar?....as i dont really feel like going through all 4000+ roms manually  :P
« Reply #114 on: March 29, 2013, 06:38:39 am »
Ok, you'll need to edit advmenu.rc. The easy way: from gasetup, go into Setup menu -> system setup -> advancemenuplus manual settings
This will open advmenu.rc in text editor. Scroll down until you find the lines where the MAME emulator is defined, it will be like:
emulator "mame" sdlmame "groovymame ..... etc
emulator_roms "mame" "bla bla bla
Ok, so right below those lines, add this:
emulator_roms_filter "mame" "*.zip;*.7z;"
Then CTR+X to exit, and say yes to rewrite the file. Then launch AdvanceMenu to see if it recognizes the files now.
You've made me a happy man finding the issue with the badly synchronized games, I dread those problems and it's good that it's related to the splash screen as some other issues with Groovy Arcade. For some reason the splash screen seems to break the video driver in many systems, sometimes the system just hangs, but your case is more subtle. So as a rule I recommend to disable the splash screen right after installing.
lettuce
  • Make It So!
« Reply #115 on: March 29, 2013, 06:52:02 am »
Ok I'll give that a go, is that splash screen cause the failed boot attempts as well I was having?
I have notice in the boot process there are a few screens where the display seems to be scrolling vertically really really fast, why does the monitor do this?
« Reply #116 on: March 29, 2013, 06:58:22 am »
Maybe.
Some BIOS post screens are 70 Hz so the screen will scrolls for sure. This is before Groovy takes control.
lettuce
  • Make It So!
« Reply #117 on: March 29, 2013, 09:31:48 am »
When this happens is this causing damage to the monitor?
lettuce
  • Make It So!
« Reply #118 on: March 29, 2013, 10:58:17 am »
Ok i have done that, and saved the file, went to the rom folder and deleted uccops.zip BUT left uccops.7z. Loaded up Advancemenu plus and it still doesnt show undercover cops in the list. I check the  advmenu.rc  again to make sure that the line had been added and it has....
Any other suggestions?
« Reply #119 on: March 29, 2013, 11:15:35 am »
The option you wrote in advmenu.rc is right, so if it doesn't work I don't understand what's going on. So you're saying that if you rename the uccops.7z file as .zip then it's properly recognized?
You can rename all files running a single command in Windows, you get into the path from cmd.exe and run "ren *.7z *.zip"
Then you can copy the files to the pendrive in Linux. Of course there must be the equivalent command in Linux which I just don't know.
