Author Topic: scanlines Help with mane please  (Read 4951 times)
jim78b
  • Last login:March 03, 2013, 04:34:47 am
« on: February 24, 2013, 03:12:14 pm »
i have mala 1.71 i try mame config checkpoint scanlines but without any result why???mame is v 0.139b dos
chopperthedog
  • Last login:Today at 07:23:13 am
Re: scanlines Help with mane please
« Reply #1 on: February 24, 2013, 03:18:26 pm »
You probably need to edit the mame config manually. Mala hasn't been updated to reflect some of the newer mame config options.
good day.
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #2 on: February 24, 2013, 03:24:52 pm »
checkpoint mala config lines why mame, i know yes, 1.71 config scanlines true why? there is dos or dos not there are no scanlines, sorry i could not resist answer this  :badmood: oh no yes
Hit something hard enough it should work, if it dont the result can always be called art :)
Almighty
  • Last login:October 28, 2013, 04:42:59 pm
    • Mighty Cade
« Reply #3 on: February 24, 2013, 04:31:55 pm »
don't use them in mame ( they look horrible ), just use a slg with vga and run at 800/600.
my opinion ;)
jim78b
« Reply #4 on: February 24, 2013, 06:29:52 pm »
excuse me but what is slg? however in mala i see the option about scanlines but don't work .
CpCaveman
« Reply #5 on: February 24, 2013, 06:50:39 pm »
seriously though , correct me if i`m wrong (no doubt they will if i am :) ), mala is just a front end, it just starts the program/emulator with configured settings whether through mala or its own files, my advice would be to get your emulator (mame) to run as you want then get mala to start it, if making it look like an old arcade machine is a MAJOR priority buy an old crt, I read a post earlier where people were arguing over it not looking authentic enough, and it wasnt the mala forum, check out the main section and you`ll probably find the answer you`re looking for, mala wont make it look like i`m guessing you want it to. try posting the question again in the other forums (not saying to move it maybe someone here knows the answer)
jim78b
« Reply #6 on: February 24, 2013, 09:55:16 pm »
ok problem is mame. however option scanlines is in mala !
chopperthedog
« Reply #7 on: February 24, 2013, 10:00:13 pm »
As I said in my previous post. Mala hasn't been update to some of the newer mame config options. I use .105 on 2 machines and mala to mame options work fine. On a machine running .131 there's a couple mame configs I need to edit manualy via mame.config file.
good day.
jim78b
Re: scanlines
« Reply #8 on: February 25, 2013, 02:53:31 pm »
can you please Help me with config mame.ini ? i want only add decent scanlines ....
mike boss
« Reply #9 on: February 25, 2013, 02:59:03 pm »
I use a T-SLG (Toodles Scanline Generator). Honestly it's hardware, not software so one of the best things about this is it refeclts on anything shown on screen. So MaLa and any emulator I run on the system will have a consistant look.
Very happy with these, and they give a great effect. Well worth the money if you want a retro look on an LCD.
As Almighty said run at a lower resolution, and be sure to adjust the RGB knobs to really get a good effect. I will confess that out of the box I used these on two machines, a 60 in 1 Jamma board and my MAME system.
The 60 in 1 looked great out of the box, no adjustments needed.
The MAME syustem needed some adjustments to get it to look good, but now it does. Really pronounced effect.
Almighty
    • Mighty Cade
« Reply #10 on: February 25, 2013, 05:08:53 pm »
i also running Mala and i am using this device:
http://www.smallcab.net/product_info.php?products_id=307
setup, 800X600 VGA lcd (4:3) and they pictures are awesome, almost like the good old crt's.
Just google : scanline generator SLG3000.
gl! :)
mike boss
« Reply #11 on: February 26, 2013, 07:29:45 am »
I used the T-SLG by Toodles.
It's available @ Gold Like Controls.
Google it and you'll find it.
I think its cheaper than then SLG3000, and it ships from the USA.
All in all I'd say its a good product, worth the money and will do what you want FOR EVERYTHING YOU DISPLAY ! - Can't go wrong !
jim78b
« Reply #12 on: February 26, 2013, 11:08:20 am »
wonderful i Will buy it! can i setup scanlines to' 800x600 or other res?
ArcadeFan3
  • Last login:March 27, 2013, 03:08:39 pm
« Reply #13 on: March 27, 2013, 04:07:19 am »
The newer Mame versions support HLSL shader filters. They can be used to create the look of an old CRT on a modern full-HD LCD TV. The result looks pretty good. I use it myself. here is a link where you can see how to it up... http://www.aep-emu.de/PNphpBB2-file-viewtopic-t-18991.html I just stumbled across HLSL sharders recently myself, never heared about them before...
I ried to caputre it in a video. take a look at the video in this thread http://forum.arcadecontrols.com/index.php/topic,130958.0.html
Ignore the first part of the video, the HLSL filters are in the gameplay part at the end of the video. And it looks better in real life, due to loss of video compression.
So before you buy extra hardware, it is at least worth a try...
On the other hand, in a real cab I would recommend to use a real CRT with Soft15kHz drivers and CabMAME to get close to the real thing...
