Author Topic: The Super Supercapacitor  (Read 1246 times)
  • Last login:Today at 10:27:16 pm
« on: February 24, 2013, 05:35:13 am »
While looking for better ways to produce Graphene article here, scientists accidently discover that they can replace batteries that use toxic substances with the non-toxic, rapid-charging, high energy density carbon polymer.
Kaner Lab researcher Maher El-Kady found a way to create sheets of graphene a single carbon atom thick by covering a plastic surface with graphite oxide solution and bombarding it with precisely controlled laser light.
Translation:
He painted a DVD with a liquid carbon solution and stuck it into a standard-issue DVD burner.
« Last Edit: February 24, 2013, 05:37:17 am by PL1 »
Re: The Super Supercapacitor
« Reply #1 on: February 24, 2013, 06:36:47 am »
Interesting.
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #2 on: February 24, 2013, 08:49:30 am »
I can see the potential.
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
    • GroovyGameGear.com
« Reply #3 on: February 24, 2013, 01:52:58 pm »
I like the parts where he calls an LED a "light bulb" and they throw a plastic substrate in the compost bin  :lol
Seriously, though, Supercapicitors are a time bomb compared to a standard battery.  Perhaps not much more so than Lithium Ion technology, but certainly more than a device which produces energy "on-demand" through a chemical reaction.  Capacitors are a holding device for the entire amount of energy capable of being delivered, which, in the case of malfunction, can be let go all at once with disastrous results.  If you have ever seen a stun gun, or watched small capacitors explode with the ferocity of a firecracker, you know what capacitors are capable of.
This does have some advantage over Lithium Ion as far as environmental, speed of charging and perhaps cost concerns, but I'm not sure it's safer.  I think just the opposite, actually.
« Last Edit: February 24, 2013, 01:56:19 pm by RandyT »
