Author Topic: Too case or not too case  (Read 1599 times)
monkeychunkuk
« on: February 22, 2013, 12:54:52 pm »
So whilst building cabs i cant decide to keep them in their pc cases or not
Heres one in its case
One out of its case
The problem i have is mounting the psu and keeping the video card in place
Whats the general thinking
Re: Too case or not too case
« Reply #1 on: February 22, 2013, 12:58:56 pm »
I cannibalize old PC cases for mobo trays and I/O panels, this way there is no problem with mounting video and pci cards.
« Reply #2 on: February 22, 2013, 03:15:53 pm »
What he said.
The video card is the only real issue with going caseless.  You don't want the thing snapping off or falling out.
« Reply #3 on: February 22, 2013, 06:05:46 pm »
Use something better than a jigsaw to cut it or you'll end up with edges like this.
Angle grinder or dremel with heavy duty cut-off wheel would have been much better.
« Reply #4 on: February 22, 2013, 06:19:35 pm »
You sure you used a jigsaw? Looks like you used your teeth! :lol
Some mobo trays you may not have to cut either. This one I just ground off the rivets to remove the sides of the case.
Depends if you have space issues or not...
mahkeymike
  • Last login:Yesterday at 04:57:54 pm
« Reply #5 on: February 22, 2013, 06:51:06 pm »
Harbor Frieght....
There called Nibblers
THIS
OR THIS
« Reply #6 on: February 22, 2013, 07:17:29 pm »
Actually, I've had really good luck with jiggsaws for cutting cases, back in my "modding" days that's what I used.  Every now and again you'll need to smooth things out, but the edge is fairly clean.
You just have to use the right blade.  Man, I dunno what BadMouth did, but you've got to work really hard to screw it up that bad.  ;)
monkeychunkuk
« Reply #7 on: February 22, 2013, 07:49:43 pm »
Apart from the look what Are the draw backs on leaving them inside a stripped down cab?
danny_galaga
  • Last login:Yesterday at 05:34:58 am
    • dans cocktail lounge
« Reply #8 on: February 22, 2013, 07:50:33 pm »
I don't think it's too case at all, seems to be just the right amount of case...
Generic Eric
« Reply #9 on: February 22, 2013, 10:01:43 pm »
I can't add much to what has been said.  I like the exposed PCB though.
SithMaster
« Reply #10 on: February 22, 2013, 10:52:44 pm »
If you have a dell dimension series case you want to scrap you could easily drill out the rivets and just have the one side to mount a mobo, psu, optical drive, and hd depending on model of the case.
I'm somewhat positive that trying to cut a pc case somewhat fast with a jigsaw will cause edges like that.  Best to go slow and let the blade do its thing.
Drnick
  • Plodding Through Life
« Reply #11 on: February 23, 2013, 03:11:51 am »
There are only a few things I have noticed. Noise from fans sounds louder with no case. Then there is Dust and Fluff in the fans.  To deal with that you can just put a filter over your cabinet fans.
« Reply #12 on: February 23, 2013, 08:14:39 am »
Honestly it's better to leave the pc cased.  That way when (not if) the pc dies, you can just swap it out instead of unmounting a pcb tray, power supply and ect.  Sometimes you have to de-case though.... there just isn't enough room in the machine.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #13 on: February 28, 2013, 09:26:55 pm »
Board and clamps make a handy fence.
-Banned-
edekoning
« Reply #14 on: March 01, 2013, 06:38:35 am »
If you already have the case and the space for it, than use it. If you still need to buy all the computer parts, than you can save a few bucks by not buying a case.
