Author Topic: MAME on 2nd monitor in Windows 7  (Read 1485 times)
jimmer
« on: February 20, 2013, 10:11:21 am »
Can anyone help with this?
I'm trying to get MAME to run fullscreen on my 2nd monitor (So I can stand up to play instead of sitting down). I can drag the AME window up to the 2nd monitor but when I fullscreen it (Alt+Enter) it jumps back to monitor 1.
it jumps back to monitor1 even when I set monitor2 to be the main monitor in windows control panel. It's like it will never forget which monitor is it's home.
I could try a fresh install with monitor 2 set as main I suppose. But then I don't MAME to be confined to monitor2 only.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
Re: MAME on 2nd monitor in Windows 7
« Reply #1 on: February 20, 2013, 10:25:14 am »
Did you try toggling monitors with Windows Key + P?
jimmer
« Reply #2 on: February 20, 2013, 11:15:18 am »
thanks, Windows+P does the job  :)
Choosing projector only is a quick way to turn off monitors 1,3,4 and then everything is just on my high screen as I wanted. Well not quite what I was after, but it'll do.
Only problem now is my sound output is sent to the inbuilt speakers in monitors 3 and 4, and they go quiet when their input is cut (got rid of external speakers in a tidy up operation some time ago). Ah well, can sort that out with extra wire to top screen or to my boombox.
rCadeGaming
  • Just call me Rob!
« Reply #3 on: February 20, 2013, 10:59:02 pm »
Did you select the correct monitor in MAME's video options?
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« Reply #4 on: February 21, 2013, 03:20:10 am »
Check your ini file, there should be a setting 'number of monitors'. Set it to the number of screens you use. Within MAME you can then configure each screen individually (hit 'tab' in MAME).
