Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1054618 times)
0 Members and 10 Guests are viewing this topic.
imJGott
  • Last login:September 15, 2017, 09:10:01 pm
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2440 on: July 06, 2017, 10:16:58 pm »
going to place my order tomorrow but i have one more question. is it possible to cut out a 230mm hole in the back to accept a 230mm fan for exhaust us in the back? i would like to go into some detail to the position of the fan due the reason i want to install a motherboard on the back door. once i make the order we can go into some details there unless this forum is ok. (i do have a smaller 140mm fan i could use if the 230mm is considered to be to large.)
« Reply #2441 on: July 06, 2017, 10:36:10 pm »
230mm is probably too big if you're going to have a motherboard on there as well...
Sent from my SPH-L710T using Tapatalk
imJGott
« Reply #2442 on: July 07, 2017, 08:51:41 pm »
thanks for the reply. ill use the 140mm fan instead and list that in the notes while im placing my order.
honkbahh
  • Last login:July 28, 2017, 11:14:31 pm
« Reply #2443 on: July 22, 2017, 04:18:48 am »
Finished! Big thanks to everyone on the forum, as well as other forums on the web, and haruman of course! Ran through metal slug 2 (literally) cause I finally had a few minutes to give the arcade a somewhat lengthy test run. 32 continues, but it was for science! By far the biggest challenge was rocket launcher and hyper spin. Thanks all!
05SRT4
  • Check out my Pow Pow
« Reply #2444 on: July 22, 2017, 08:13:48 pm »
That collection though.
Bartop came out really nice, well done.
imJGott
« Reply #2445 on: July 24, 2017, 10:21:43 pm »
HaRuMaN:
do you have a file where i can add vinyl to the cabinet?
« Reply #2446 on: July 24, 2017, 10:29:07 pm »
HaRuMaN:
Are you asking for templates?
imJGott
« Reply #2447 on: July 25, 2017, 01:29:13 am »
HaRuMaN:
yes sir
« Last Edit: July 25, 2017, 04:58:04 pm by imJGott »
imJGott
« Reply #2448 on: July 26, 2017, 11:53:55 am »
HaRuMaN:
yes sir
can i have that file so i can add a vinyl image? not sure where it is located on your site. unless you have a vendor that does the vinyl prints i can work with
« Reply #2449 on: July 26, 2017, 11:56:06 am »
HaRuMaN:
yes sir
Hey sorry about that, I'll send them when I get home today (they're on my home PC).   :cheers:
imJGott
« Reply #2450 on: July 27, 2017, 06:48:52 pm »
thanks for the file, i got in my email. what buttons do you recommend to use with your cabinets? i havent decided if im going with sanwa or another in terms of joysticks but i assume ill need a screw type of push button. suggestions?
« Reply #2451 on: July 28, 2017, 11:26:15 am »
Personally, can't go wrong with the Sanwa OSBN (screw type).  Keep in mind your kit has been cut for 30mm buttons X 16, and 24mm buttons X 6, all screw type.  Joystick hole mounting pattern is the typical Sanwa JLF (another great all around stick, IMO).
imJGott
« Reply #2452 on: July 28, 2017, 04:44:58 pm »
thanks for the advice! i was looking into the IL push buttons since they have a wider color selection that i have seen. but from my 8bitdo fightstick experience im a little hesitate on sanwa parts. i believe my fight stick doesnt have real sanwa parts but if they are legit then im just disappointed on how they have been performing for me.
oh yeah, package has been delivered! still ironing out on which cpu to go with for my build on this cabinet.
« Reply #2453 on: July 28, 2017, 04:54:32 pm »
Personally I love the real Sanwa stuff, but for sure, the knock offs can really not feel right.
imJGott
« Reply #2454 on: August 06, 2017, 11:29:15 pm »
i finally started to assemble this cabinet but i havent ordered my buttons, joystick or control board. will these buttons work?
https://www.focusattack.com/pushbuttons/popular-brands/industrias-lorenzo/
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
« Reply #2455 on: August 09, 2017, 01:58:45 am »
They will work as long as you use shortened buttons for the admin CP. Otherwise, they will bang into each other.
« Reply #2456 on: August 09, 2017, 10:15:48 am »
He has the Ultimate Widescreen.  No buttons on the admin.
« Reply #2457 on: August 09, 2017, 10:16:53 am »
While those buttons will fit, they are a little small (~28mm) for the holes (30mm).
imJGott
« Reply #2458 on: August 10, 2017, 11:28:07 pm »
the drawing on the right shows the width of the outer most ring at 33mm unless im reading it incorrectly.
as for the admin buttons, wouldnt the 3 buttons above the 1st and 2nd player be considered admin buttons if i set them that way?
JDFan
« Reply #2459 on: August 11, 2017, 12:52:51 am »
Yes - what they were talking about is on some models the admin buttons are on the front panel under the Control panel and are put in place sideways from the front of the system - and the longer buttons wind up hitting the Joystick/other buttons - so for those you need to use shorter length buttons.
for example the 6 buttons on the normal widescreen model
« Last Edit: August 11, 2017, 12:57:15 am by JDFan »
Quattro
  • Last login:September 21, 2021, 02:00:40 pm
« Reply #2460 on: August 12, 2017, 03:58:07 pm »
Hey Haruman, I can't PM you as my account is new. I have quite a few questions about the Ultimate Widescreen kit. What would be the best way to contact you? I tried your phone number but no luck.
  • Last login:Today at 01:53:38 am
« Reply #2461 on: August 12, 2017, 06:21:56 pm »
Welcome aboard, Quattro.   ;D
Your PMs should work now.   :cheers:
« Reply #2462 on: August 12, 2017, 06:23:53 pm »
Sorry we've been cleaning house today with the radio turned wayyyyy up.  Email works best, haruman@gmail.com
dluusional
  • Last login:February 09, 2019, 06:13:28 pm
« Reply #2463 on: August 13, 2017, 01:52:05 pm »
honkbahh, where did you get the artwork from?
SNAAKE
  • Trade Count: (+29)
« Reply #2464 on: August 15, 2017, 01:25:55 pm »
and which monitor did you use? look like a super exact fit lol
rflores2323
  • Last login:November 26, 2021, 07:37:12 pm
« Reply #2465 on: September 04, 2017, 09:24:44 pm »
I was wondering if the bartops can be mounted to the wall?  I wanted to buy a 2 player bar top box and then put a  jamma pandora 4s fighter stickbox..  can this be done as I see you have cut outs already but I rather get one of these bozlxes that already come with all the hardware and games.
Sent from my SM-G950U using Tapatalk
« Reply #2466 on: September 05, 2017, 10:06:23 am »
You could probably mount to the wall.  I wouldn't do that with the melamine / mdf version though, I would only do that with the birch plywood one.
« Reply #2467 on: October 31, 2017, 09:47:02 am »
I'm back! Thumb has healed up enough for me to start working kits again and to celebrate I've set up a coupon for 10% off all orders.
Use coupon code ALLTHUMBS to receive your discount!
I also want to take this opportunity to thank my customers for their patience while I heal up. I'll be working hard over the next few weeks to get caught back up.
Thanks again!
  • Last login:Yesterday at 05:43:19 am
« Reply #2468 on: October 31, 2017, 09:51:28 am »
Shouldn't it be "NOTHUMBS"? ;)
Glad you healed up okay.
« Reply #2469 on: October 31, 2017, 09:53:11 am »
Or maybe ONEGOODTHUMB, lol.
And me too, scariest accident I've had with a power tool for sure.
NIVO
« Reply #2470 on: November 03, 2017, 02:18:56 am »
thumbs up to a great seller and friend. you cant go wrong folks. I shall have mine done very very soon!
SNAAKE
« Reply #2471 on: November 06, 2017, 03:09:03 pm »
too soon for "thumbs up"  :police:
« Reply #2472 on: November 06, 2017, 03:16:01 pm »
Haha!   :cheers:  Maybe 0.5 thumbs up :P
busbeepbeep
  • Last login:December 18, 2024, 09:10:03 pm
  • Just trying not to break anything
« Reply #2473 on: November 28, 2017, 10:45:43 pm »
Decided to try to tackle one of the Haruman bartop kits.   Trying to decide between the Ultimate Widescreen or the WIDESCREEN EVO XR 2.  Hoping for something that can accommodate 2 adults playing Street Fighter 2 comfortably.  Plan on using a 24" 16:9 monitor or a 23" 16:10.
Think I've decided to go with IL Eurostick and iL concave buttons.
TheGreatRedDragon
  • Last login:January 02, 2026, 03:47:53 am
« Reply #2474 on: November 30, 2017, 08:32:30 am »
There's a widescreen Evo XR?
busbeepbeep
« Reply #2475 on: November 30, 2017, 08:43:59 am »
Yeah, looks to just been added in the last week.
https://www.harumancustoms.com/products/bartop-kits/widescreen-evo-xr-2
Ultimate Widescreen: 26.25" H, 21.5" D, 24" W
Regular Widescreen: 21.45" H, 18.6" D, 23.0"  W
Evo XR2 Widescreen: 27.5" H,  21" D, Width (Main Cabinet - 24") (Control Panel - 27.65")
Regular EVO XR2: 27.5" H x 21" D,  Width (Main Cabinet - 20.85") (Control Panel - 24.5")
« Reply #2476 on: November 30, 2017, 09:03:12 am »
Yes, I just have to get the render pic done and posted.
Here is what it looks like, dry fit before I shipped it out:
TheGreatRedDragon
« Reply #2477 on: November 30, 2017, 09:40:39 am »
She's a beaut.
After almost two years of deliberation I finally settled on the Evo XR as my kit of choice and I'm 90% done with the art package but now I might have to bump up to the widescreen version. That extra wide CP looks super comfy.
« Last Edit: November 30, 2017, 11:16:24 am by TheGreatRedDragon »
« Reply #2478 on: November 30, 2017, 09:43:19 am »
Thanks!  It's even wide enough to do 2 player 6 buttons each & a 3" trackball (Utrak).
TheGreatRedDragon
« Reply #2479 on: December 01, 2017, 03:36:53 am »
Is the internal roomy enough for an ATX motherboard or is that too big?
