Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1063657 times)
0 Members and 14 Guests are viewing this topic.
Slippyblade
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2360 on: September 05, 2016, 01:26:44 pm »
Pics or there is no couch.
« Reply #2361 on: September 05, 2016, 08:25:23 pm »
I thought I had a picture of Malenko humping HaRuMaN's couch, but sadly it seems to have disappeared from my text messages.
« Reply #2362 on: September 05, 2016, 10:14:39 pm »
Ironically I dont think I ever even sat on his couch.
« Reply #2363 on: September 05, 2016, 10:15:25 pm »
I know I had a couch photo somewhere...
« Reply #2364 on: September 05, 2016, 10:19:57 pm »
« Reply #2365 on: September 05, 2016, 10:20:19 pm »
Oh, buy with confidence, folks!!!!
thomas_surles
« Reply #2366 on: September 05, 2016, 10:30:58 pm »
How much for the couch shipped?
« Reply #2367 on: September 05, 2016, 10:32:22 pm »
About tree fiddy
Sent from my SPH-L710T using Tapatalk
thomas_surles
« Reply #2368 on: September 05, 2016, 11:09:37 pm »
About tree fiddy
It was about that time I realized that HaRuMaN was about 8 stories tall...
« Reply #2369 on: September 05, 2016, 11:25:20 pm »
I could have sworn Malenko had more red hair...
raniel
  • Last login:March 23, 2018, 04:10:32 pm
« Reply #2370 on: October 05, 2016, 02:59:09 pm »
Hey Haruman. I got the widescreen bartop kit from you. Im planning to use a PC, what do you recommend with regards to the size of the motherboard? I'm planning to use itx or matx due to small form factor. If I use the standard size would that give me problems? thanks!
RetroGreg
« Reply #2371 on: October 07, 2016, 09:49:55 pm »
I finished this several weeks ago, but haven't posted pics yet. First time posting pics so if it goes horribly wrong I may need help lol.
Special thanks to Haruman and Malenko for the kit and the sweet ass artwork  :cheers:
Currently running a 412 in 1 which I don't recommend. I think it's worse than a 60 in 1. I'm going to replace it soon with either a PC or an ArcadeSD within the next couple of months.
Edit: More details - I used goldleaf buttons on the panel and a Sanwa JLW. The panel is kind of tight on the minitendo kit so I'd definitely recommend the goldleafs. They feel great in gameplay too. The JLW was a hard fit. I had to bend some of the switch pins to get it to work ok, but it's fine. I used a 15" Dell and that's really the best size to use in this kit. You can see everything ok even with the bezel art. It would be hard to see everything with a 17".
Thanks again guys  ;D. Now I want to see someone do a Donkey Kong 3. That would be rad. Now onto the widescreen kit I got at the same time. I want to finish all my projects before ZapCon!
« Last Edit: October 09, 2016, 11:39:06 pm by RetroGreg »
« Reply #2372 on: October 07, 2016, 10:09:33 pm »
Looks great!
« Reply #2373 on: October 07, 2016, 10:33:01 pm »
smexy.
Glad the art turned out well for you.
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #2374 on: October 15, 2016, 08:36:31 pm »
Did a pedestal ever make it into the mix here?
« Reply #2375 on: October 17, 2016, 10:54:58 am »
So there's been a few pedestals for the bartops... and then there have been a couple of actual pedestals.  I'm also currently working on a 4P player pedestal for a customer.
pti
  • Last login:November 22, 2016, 06:41:07 am
« Reply #2376 on: October 23, 2016, 11:17:51 am »
I've ordered all of the pieces for a Haruman Minitendo-based Pac-Man themed kit. I went with Ultimarc MagStick and Goldleafs, a 15" Dell E157FP, and an ArcadeSD board.
I am stuck on what to do for a speaker, though. It looks like I'll only have ~3.25" to work with. What did you use?
RetroGreg
« Reply #2377 on: October 24, 2016, 12:51:25 am »
I used a basic 2 inch speaker I got on amazon. You don't need anything great for the old games.
https://www.amazon.com/Mini-Hobby-Speaker-inch-Ohms/dp/B007P44Y4W/ref=sr_1_1?ie=UTF8&qid=1477284273&sr=8-1&keywords=2+inch+hobby+speaker
It fit pretty good. Drill holes to attach one side before you glue up the kit to make it easy to secure the speaker later. It's offset to one side of the grill but you can't see it from the outside.
booty900
  • Last login:January 22, 2017, 04:13:46 pm
« Reply #2378 on: October 29, 2016, 08:52:00 pm »
I'll be buying The Degenatron soon. I just have some questions. What buttons would work best for the control panel and the admin? Also if I got a switchable joy stick would I have enough room to reach under the control panel to switch it from 4 to 8 way? If not Id just get a happ joystick that is 8 way
« Reply #2379 on: October 29, 2016, 09:55:07 pm »
I got nothing to add, I just wanted to state I love the username booty900.
« Reply #2380 on: October 30, 2016, 05:59:01 pm »
Happ or IL style buttons.  For the admin, short buttons are best, like Ultimarc Gold Leafs.
You'd have to pull the panel up or go through the back to switch.  Going through the back would be difficult I would think.
booty900
« Reply #2381 on: October 31, 2016, 12:05:10 pm »
Now I have a different question. I just looked at The Offender bartop. I don't know much about control panels. But it looks like it is for 2 joysticks. So could I have a 4 way on the left and an 8 way on the right? And would a 17" monitor fit in the offender? And are happ controls for that one too?
« Reply #2382 on: October 31, 2016, 01:09:47 pm »
It's for a multi-williams setup but you could do that with the joysticks for sure.  And yes, 17" monitor will fit and it is made for Happ / IL buttons.
Jarozi
  • Last login:February 27, 2017, 06:44:40 am
« Reply #2383 on: January 03, 2017, 03:22:32 pm »
I ordered a Haruman Ultimate Widescreen kit and have started to build.  Can someone let me know what buttons and joysticks will fit?  I ordered the stock kit. Thanks!
« Reply #2384 on: January 03, 2017, 03:24:22 pm »
Hey there.  So you need 2 Sanwa JLF joysticks, 16 x Sanwa OBSN 30mm, and 6 x Sanwa OBSN 24mm.  (OBSN are the screw in type)
Jarozi
« Reply #2385 on: January 03, 2017, 10:05:34 pm »
Thanks! Are there any alternatives to the OBSN's?  I can't find a source for white 24mm's or black 30mm's.
« Last Edit: January 03, 2017, 10:09:18 pm by Jarozi »
« Reply #2386 on: January 03, 2017, 10:06:20 pm »
Seimitsu makes an equivalent button
wildbil52
  • Last login:June 24, 2020, 04:59:40 pm
« Reply #2387 on: January 24, 2017, 10:36:48 pm »
It's about time I posted some pics of my (nearly) completed Haruman Bartop.  I went with an NHL 94 theme.
« Reply #2388 on: January 25, 2017, 09:14:40 am »
That looks GREAT!  Nice work, and thanks for sharing the pics!   :cheers: :cheers:
jdevane
  • Last login:September 29, 2023, 09:27:07 pm
« Reply #2389 on: January 25, 2017, 05:37:39 pm »
Love the NHL 94 theme... beautiful...
alomar123
  • Last login:June 15, 2017, 01:36:25 pm
« Reply #2390 on: January 26, 2017, 10:33:02 am »
Has anyone tried putting in a 20" Dell 2007FP (vertical of course) in the Pretendo with Nintendo bezel artwork? It looks like it should fit per the dimensions but I am just not too sure.
« Reply #2391 on: January 26, 2017, 10:36:15 am »
It would be close but I think it would work.
gonzo90017
« Reply #2392 on: January 28, 2017, 02:39:29 pm »
Nice theme. Can you provide some info on the artwork and how it was printed?
wildbil52
« Reply #2393 on: January 31, 2017, 11:20:50 am »
Sure.  The designs are all mine but I did get a little photoshop/InDesign assistance from a few friends.  The logos on the bezel were pulled from the NHL 94 matchup screen and the images on the front and CP were screenshots pulled from a game of NHL 94 running on Fusion.  The art was printed by Bowman signs in Milford, CT (Lucian045 here on byoac).  Brad is awesome and does lots of arcade and pin printing.  The CP has a polycarbonate coat on it for protection.  Looks and feels amazing.  We reverse printed the bezel and marquee so we get that nice shiny look of the plexi.  Fits with the theme, reminds me of the glass above the boards in a hockey rink.
« Last Edit: January 31, 2017, 11:22:34 am by wildbil52 »
Jarozi
« Reply #2394 on: February 05, 2017, 04:02:25 pm »
Thanks again for all the help, getting nearly done with my Neo Geo themed Haruman Ultimate Widescreen can.
Can someone advise on a hinge solution for the back door?  I bought some little hinges but they aren't working.  I have the stock kit with the hinge tabs and door stops.
« Reply #2395 on: February 05, 2017, 04:07:25 pm »
I did mine like this with some fat hinges:
Jarozi
« Reply #2396 on: February 05, 2017, 09:30:04 pm »
What did you use on the latch mounts to keep the door closed?  Thanks!
« Reply #2397 on: February 05, 2017, 09:32:26 pm »
I used the same magnets as the control panel but they are way strong, I would probably use industrial Velcro next time.
Jarozi
« Reply #2398 on: February 05, 2017, 09:51:07 pm »
Ok, I picked up a pair of these that I'll try.
http://m.acehardware.com/product/index.jsp?productId=35265766
« Reply #2399 on: February 11, 2017, 11:58:46 am »
That should work
