Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1027650 times)
stoopid2001
  • Last login:February 12, 2019, 09:12:05 pm
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #1320 on: March 01, 2014, 08:54:18 pm »
I have a two player Haruman I'm about to assemble.  Is there anything you guys recommend doing before I glue it together?  I was thinking mounting the speakers would be easier before I glue
Yes, that might make it a bit easier.
I had a little trouble mounting the marquee light after assembly too.
« Reply #1321 on: March 02, 2014, 01:55:25 pm »
I used cold cathode lights with the included velcro for mine, worked pretty well (installed after assembly).
« Reply #1322 on: March 02, 2014, 02:34:29 pm »
Pro tip, right here. ^^ Unless you're going with the retro "yellowed" look, there's no reason not to go with these little babies. Inexpensive, light, and oh so bright.
:D
« Last Edit: March 29, 2014, 01:21:28 pm by Rick »
Baezl
  • Last login:August 24, 2024, 07:11:26 am
« Reply #1323 on: March 10, 2014, 04:27:54 pm »
Hey guys or HaRuMaN, does anyone have the widescreen bartop (2 player) cnc plans or templates?  I want to attempt this.  I suck at cutting wood so was going to print the CNC plans to scale and use it.  I did download the sides that were posted at the beginging of the thread but was looking for inside measurments etc.  Any help is highly appreciated.  Damn HaRuMaN does great work!  Very creative!!!
Thank you
Luis
« Last Edit: March 10, 2014, 04:30:06 pm by Baezl »
« Reply #1324 on: March 10, 2014, 04:43:21 pm »
Thank you
Luis
The widescreen is simply the weecade (standard) bartop with the internal panels stretched to 22".  The sides are the same.
I can still host them somewhere if you need them.
Baezl
« Reply #1325 on: March 10, 2014, 05:02:16 pm »
Thanks .  I emailed you on your site about buying 3-5 units.  Do you do a discount?  If you have the CNC plans yes, then I will take them if its not too much trouble.  Either way, if you send them, we still want to buy some units, I just want to build one with my son for fun.
Your the man!!
Thank you
Luis
InfraredMonkey
  • Last login:August 08, 2023, 02:03:16 pm
« Reply #1326 on: March 11, 2014, 12:01:49 pm »
Hey guys!  Long time lurker on this post.  In fact, I went through page by page for the last day or so.  I gotta say HaRuMaN's designs and CNC production is amazing!  I really think you all collectively improve on the interest on bartop arcades.  It's incredible!  :applaud:  :notworthy:
Now that the gushfest is done.  I wanted to get down to some business.  Oh yes, I want one.  I wanted to know a few things.  I've scanned back in the last 2 pages of this post and I gotta say, I love that Nintendo design.  It's really awesome.  I am for sure interested in getting one that will fit a 19" vertically.  Has anyone tried this?  If so, do we have any real pictures of this?
HaRuMaN - If I intend to get the Nintendo version, I wanted to know how the plexiglass situation goes.  How does it mount?  Also were you able to experiment with Nintendo buttons?  Will they clear?  Forgive me on my ignorance here, I just didn't see much detail on this.  We could move this over to a PM if needed.
Thanks,
Spencer
« Reply #1327 on: March 11, 2014, 12:06:51 pm »
I am pretty certain a 19" will mount vertically, I have one at home I can measure to double check.
The marquee is held on at the top with a piece of L-channel, and at the bottom with a piece of H-channel.  The top of the bezel fits into the bottom of the H-chanel, and I have a mounting slot at the bottom for the bezel.
Got a drawing or pictures of Nintendo buttons?  I don't see what would cause them not to clear, but I would need to see some to be sure.
-Lee :cheers:
InfraredMonkey
« Reply #1328 on: March 11, 2014, 01:10:11 pm »
-Lee :cheers:
Right on, Lee.  I appreciate the response.  Here is what I can dig up (attached below).  I imagine it would be okay, I figured I would ask.
Is the h-channel and t-channel included in the price for the marquee and monitor plexi?  I saw a few folks were showing off cabarets.  Have you thoughts about getting these done through a CNC guy?  If so, do you have an idea of cost to do it (maybe a ball park on shipping?)?  It's not for me, but I have a friend whom I was telling him about all the work and success you had on these bartops.  Then I started showing him some of the testimonials.   ;D
-- Spencer
« Reply #1329 on: March 11, 2014, 01:13:34 pm »
-- Spencer
Yeah, that button should fine.  H & L channel are available for an additional $15.  I custom cut them to size to fit each cab.
I have drawn plans up for a cabaret, I think I got an estimate from my CNC guy, let me take a look.
InfraredMonkey
« Reply #1330 on: March 11, 2014, 02:05:46 pm »
Sounds good!  I've sent a PM.   :notworthy:  I should probably stop using that emote before Rick finds out.  :cheers:
-- Spencer
« Reply #1331 on: March 11, 2014, 02:11:39 pm »
-- Spencer
Rick secretly does it, too... ;)
fantoboy
  • Last login:May 24, 2017, 02:02:13 pm
  • I'm a mushroom cloud layin' motha fu($@!
« Reply #1332 on: March 18, 2014, 09:48:15 am »
I got the two player model and I'm planning on putting Sanwa sticks in it.  Will they feel ok just mounted underneath?  Or should I get the extended shafts?  The bottom of the CP isn't routed for them.
http://www.amazon.com/dp/B00BFL2SSA/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=14ONEKU9MA8CE&coliid=I154EYNU6UDB1D
« Reply #1333 on: March 19, 2014, 02:22:48 pm »
The CP is 1/2" thick...  you may want to think about the extended shafts
« Reply #1334 on: March 19, 2014, 03:25:08 pm »
The CP is 1/2" thick...  you may want to think about the extended shafts.
It's totally a judgment call, really. I ordered Jiffy Sticks (Sanwa clones) and with regular shafts and using 5/8" MDF, they fit well into my bartop.
I personally wouldn't install longer shafts, but to each his own.
FelixTheJeep
  • Last login:July 24, 2014, 05:43:16 pm
« Reply #1335 on: March 21, 2014, 10:11:16 am »
HaRuMaN, are you still doing cocktail tables?  Thanks!
« Reply #1336 on: March 21, 2014, 10:29:25 am »
yes :)
rablack97
« Reply #1337 on: March 24, 2014, 07:17:00 pm »
That dude is jamming, what video is that from, curious as to what he's dancing too...
« Reply #1338 on: March 24, 2014, 08:09:35 pm »
« Reply #1339 on: March 25, 2014, 07:54:08 pm »
Dude, I'm 41, and even *I* know that's Technoviking.
rablack97
« Reply #1340 on: March 25, 2014, 10:30:33 pm »
For one i'm 40 too, for 2 i'm black, so how the heck is a brotha suppose to know anything about Technoviking :afro:
Just watched vid, dude is jamming......sorry Haruman, carry on with thread greatness  :applaud: :applaud:
« Last Edit: March 25, 2014, 10:36:46 pm by rablack97 »
« Reply #1341 on: March 26, 2014, 12:15:49 am »
Wait, you're black?
rablack97
« Reply #1342 on: March 26, 2014, 01:49:57 am »
As the night itself, and yes black people know how build stuff to sir....
Please tell me your not just now putting 2+2 together.....Well I'll be damned.... :dunno
I think i'm gonna remix that vid with "It takes 2" by rob base......yall aint feelin the john travolta move at the beginning of the groove fest.
« Last Edit: March 26, 2014, 01:53:36 am by rablack97 »
« Reply #1343 on: March 26, 2014, 02:08:10 am »
Throw on some "Joy 'N Pain" afterwards.
« Reply #1344 on: March 27, 2014, 11:28:59 am »
Result of a customer request, Defender:
FelixTheJeep
« Reply #1345 on: March 27, 2014, 05:21:40 pm »
yes :)
Excellent!  I wasn't sure because I didn't see them for sell on your site anymore, but now I see on the front page that the Midway cocktail is being redesigned.  Do you know when the redesign will be ready for shipping and the price?
« Reply #1346 on: March 27, 2014, 05:23:29 pm »
yes :)
It's the next one on my plate.  Should be very soon, price for cherry woodgrain melamine would be ~$220 shipped.  Can also do a cabinet grade baltic birch for around $260 shipped (this one you would need to stain or something to finish).  Both are 1/2" materials.
FelixTheJeep
« Reply #1347 on: March 28, 2014, 11:45:13 am »
yes :)
Great, looking forward to seeing them!
404
« Reply #1348 on: April 01, 2014, 09:38:33 am »
I'm not white and I know who techno-viking is. That was funny stuff back in the day.
« Reply #1349 on: April 01, 2014, 10:06:17 am »
I'm black albino.
« Reply #1350 on: April 02, 2014, 11:54:04 am »
Well, ZapCon is less than 2 weeks away.  I'll be there set up as a vendor.  I've been working feverishly to finish off some bartops for the show.  Looks like I'll have:
MDF Weecade V1 running a DC with VGA box and Mini-SLG
Melamine Weecade V2 running MAME with a prototype howler PCB (courtesy of Wolfware Technologies Inc.) and RGB controls (courtesy of Paradise Arcade)
Melamine vertical kit running a 60-in-1 with a Mini-SLG, with Galaga artwork
Melamine Neo Geo kit running a 1 slot Neo Geo Mobo, RGB to VGA converter, Mini-SLG
Brand new widescreen kit (V2) running Xbox 360 with hacked controllers & all Sanwa controls in a Vewlix - like layout
Cheers to yotsuya for bring his haruman cocktail kit for demo.   :cheers:
Anybody here plan on attending?
« Reply #1351 on: April 02, 2014, 12:34:55 pm »
Oooooooo...oooooo.....me! Me!
  • Last login:January 22, 2026, 12:55:00 pm
« Reply #1352 on: April 02, 2014, 01:47:38 pm »
If you and yots split my plane ticket, I'll go!  >:D
  • Last login:Yesterday at 05:32:57 pm
« Reply #1353 on: April 02, 2014, 01:53:30 pm »
I'm black, 450 lbs, and 5' tall.
 :dunno
« Reply #1354 on: April 02, 2014, 02:16:03 pm »
Oh yeah, 'cause Arizona is ... wait, what? WHO THE HELL HOLDS A CON IN ARIZONA?
:lol
« Reply #1355 on: April 02, 2014, 02:19:37 pm »
:lol
The City of Phoenix is, at last count, the sixth largest city in America. So there.
Conversely, your momma does.
« Reply #1356 on: April 02, 2014, 03:14:06 pm »
I love Arizona...it's the closest I'll ever be to walking on Mars. Such a bazaar and surreal landscape.
As for Phoenix, I caught a Suns game there and it was pretty awesome (a lot of Canadians loved the Suns when Nash played there).
But freeway drivers are absolutely insane. First and last time in my life that I actually felt like a timid driver...and I spent 4 years driving LA rush hour, so I'm no slouch to aggressive driving.
 :dizzy:
404
« Reply #1357 on: April 02, 2014, 03:28:14 pm »
 :dunno
from your facebook page
mann0mann
  • Last login:June 25, 2016, 12:31:54 pm
  • Still looking for the right project...
    • My Hobby Store
« Reply #1358 on: April 03, 2014, 05:14:41 am »
Would really like to see that widescreen v2 in real life....any chance you could post some pictures of that?
I, unlike Rick...don't care if you use your crappy cell phone camera.  ;-)  LOL
I'm kicking around the idea to come.  I can't make CAX which is right in my backyard (I'll be in Lincoln, NE ugh that week) but I'd like to go to one of these cons, plus I'd love to see some of your stuff built up and in the flesh.  Add in the bonus of getting to meet Yotsuya....who wouldn't consider that tempting!  ;-)
« Reply #1359 on: April 03, 2014, 10:17:19 am »
If you come, drinks are on HaRuMaN!  :cheers:
