Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1061038 times)
Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #840 on: October 08, 2013, 09:40:32 am »
issue is you need to get pretty hands on if you are trying to gauge it, bearing is the way to go.
Don't make me pull out my Dogbert gif. ;)
Okay, okay. I'll upgrade my bearing.
« Reply #841 on: October 08, 2013, 09:42:38 am »
Yeah, I wrecked a couple of bartops before I figured that out.   :banghead:
Or, you could just exercise more control over the piece you're routing. There's no reason you can't use the table if you're cautious.
 :dunno
That's great in theory, not so much in practice.  With the bearing swap, I can slot cut a whole bartop kit in about 5 minutes.  When I've got 8 bartop kits to slot, pack, and ship, reducing the slot cutting time is huge.
« Reply #842 on: October 08, 2013, 11:41:49 am »
;)  >:D
« Reply #843 on: October 08, 2013, 11:47:54 am »
You're lucky saint won't let me change people's custom text...   ;) >:D
« Reply #844 on: October 08, 2013, 11:49:25 am »
That didn't stop you from changing my other post to "Smiling Bob", now, did it?
« Reply #845 on: October 08, 2013, 11:53:33 am »
 >:D
I used to be able to change people's usernames, but alas, no more...   :'(
« Reply #846 on: October 08, 2013, 11:55:37 am »
Did Saint give you the "With great power comes great responsibility" speech before he took it away?  >:D
« Reply #847 on: October 08, 2013, 11:57:04 am »
Yes, and one of these, I suppose.
 :whap
« Reply #848 on: October 08, 2013, 01:26:07 pm »
Just for you, Rick:
« Reply #849 on: October 08, 2013, 02:04:53 pm »
Yeah? YEAH?! Well... WELL!!! I don't like your vents.
:P
« Reply #850 on: October 08, 2013, 02:10:42 pm »
:P
floriske.nl
« Reply #851 on: October 08, 2013, 02:32:34 pm »
I do, but that is inadequate for limiting depth of cut, especially on curved / angled pieces.
The standard 1/16" slot cutter, out of the box, cuts the slots WAY too deep, like twice as deep as they need to be.
What I ended up doing was purchasing a larger bearing separately, and replacing the stock (smaller) bearing on the cutter.  That way the depth of cut is always mechanically limited by the slot cutter itself.
Because I wanted to route a kit this evening and couldn't get hold of a bearing that quick I ended up cutting an acrylic "press on"  adapter ring for the bearing on my cnc router. That worked!
Also been looking into 12mm laminated particle board instead of blank MDF, but that's pretty expensive over here because it's not commonly used.
The kit I just finished is in mdf that has a white ground coat on it (no idea what it's called in English). At least that's s lot better than the normal blank version.
« Reply #852 on: October 08, 2013, 02:41:47 pm »
But, but, but... I thought you guys invented IKEA?
floriske.nl
« Reply #853 on: October 08, 2013, 02:54:39 pm »
Lol  :laugh2: no no no no no ....... that's in Sweden  :hissy:
15 and 18mm in plain white or (black) woodgrain are quite common, but 12mm plain black isn't. Available in HPL instead of melamine mostly and that's triple the price of the pre coated MDF
Edit: here's a crappy phone pic of the pre grounded mdf (can someone please tell me what it's called in english?  :cheers:) kit before routing the T-molding
Edit 2: Some beter pics
« Last Edit: October 09, 2013, 12:13:36 pm by floriske.nl »
floriske.nl
« Reply #854 on: October 10, 2013, 04:33:52 am »
@HaRuMaN: maybe this is interesting for you (or maybe not  :dunno)
Because I don't like marquees mounted with angled profiles (looks too plump) I came up with the following mounting method for the marquee on kits with T-Molding:
If someone wants a kit without T-Molding I still use the method I also used for Evo XR Cade:
This method can't be used with T-molding because the t-molding slot would run into the top slot for the marquee, cutting of the edge. This could be prevented by mounting the marquee deeper into the cabinet, but think that would look awkward.
« Last Edit: October 10, 2013, 04:36:27 am by floriske.nl »
« Reply #855 on: October 10, 2013, 06:16:58 am »
Because I don't like marquees mounted with angled profiles (looks too plump) I came up with the following mounting method for the marquee on kits with T-Molding. This method can't be used with T-molding because the t-molding slot would run into the top slot for the marquee, cutting of the edge. This could be prevented by mounting the marquee deeper into the cabinet, but think that would look awkward.
Now, hold on just a second. I may not have a lot of 'original' ideas, but I'd like to claim at least this one for my own.
To whit:
Each of my bartop designs have integrated 1/4" slots carved into them to support easy installation of plexi for playfield glass and marquees.
No harm, no foul here though. Even macattack heisted my idea.
« Last Edit: October 10, 2013, 10:01:22 am by Rick »
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #856 on: October 10, 2013, 06:22:43 am »
You missed the monitor bracket shape also ;)
WWW.Xtremepinball.com
« Last Edit: October 10, 2013, 06:26:16 am by macattack »
Pm me for custom cnc needs...
« Reply #857 on: October 10, 2013, 06:27:31 am »
Why, you?!!
:lol
rablack97
« Reply #858 on: October 10, 2013, 08:40:58 am »
Am i missing something but dont you need 2 pieces of plexi for a marque, you have to sandwich the graphic, right.
The t-molding method sounds promising, the only issue i forsee, is t-molding does not like to pulled in and out of its slot.  Eventually with maintenance over time if you have to remove your marquee, that slot won't be as tight.
« Reply #859 on: October 10, 2013, 09:05:37 am »
Exactly why Rick's Plexi Slots (TM) are 1/4".
macattack
« Reply #860 on: October 10, 2013, 09:09:42 am »
Think it depends on how far you spanning and the material thickness that was used, if you only spanning a couple of inches and the material is 1/2" or 3/4" then it usually offers enough support to hold it in place. That said sandwiches are nice ;)
« Reply #861 on: October 10, 2013, 09:30:20 am »
Why, you?!!
:lol
Yeah, well, that's one design flaw I won't be borrowing...   ;)
« Reply #862 on: October 10, 2013, 10:02:27 am »
I don't know what you're talking about.
« Reply #863 on: October 10, 2013, 10:06:34 am »
MDF isn't good in torsion... and you've gone and removed about 50% of the torsion strength it did have...  ;)
(I'm an engineer in my day job)
Re: Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #864 on: October 10, 2013, 10:17:19 am »
MDF isn't good in torsion... and you've gone and removed about 50% of the torsion strength it did have...  ;) (I'm an engineer in my day job)
Well, if I was concerned someone might want to SIT ON my cabs, maybe that might be a concern.
:D
« Reply #865 on: October 10, 2013, 10:20:22 am »
:D
I'm talking about the monitor mount, not the cabinet.  And you'll be hanging a fairly substantial weight on it.  At an angle.
macattack
« Reply #866 on: October 10, 2013, 10:23:21 am »
:D
I agree, but for this application, given the weight it should be fine.
 besides mine are in plywood ;)
Re: Re: Re: Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #867 on: October 10, 2013, 10:24:26 am »
The 27" monitor in my Doom cab is on a similar mount, and weighs significantly more than the 19" monitors I'll be using. I have NO concerns about the mounts.
« Reply #868 on: October 10, 2013, 10:56:58 am »
Oh, plywood has a better torsional strength, for sure, given it's layered structure.
floriske.nl
« Reply #869 on: October 10, 2013, 02:21:18 pm »
To whit:
Feel free to claim as you like  ;) and I hate to spoil your party, but in what matter does this:
look like your slots in the sidepanels?  :dunno
If you are referring to the other picture instead: I'd hate to spoil that party as well since I've used that method on my Evo XR Cade a few months back as well, and it's also commonly used for placing modular wall panels <- that's where my inspiration came from.
But as mentioned: hate to spoil the party so  :cheers:
Why would you need 2 panels? This is only needed if you use a print on normal paper for the marquee, but since there are a lot of signing companies out there which can simply print the artwork mirrored on clearview vinyl and laminate it with white after that so you get a "sticker" that you can adhese on the back of the plexi I see no need for that.
Pulling out the t-molding won't really be nescesary (that often) if you use LED strip for the lighting.
Does noöne have an answer to my question about what the pre-ground coated MDF is called in English.
Also I'm curious what a standard 1/2" plain black laminated particle board panel costs in the US? (e.g. 8x4 or 10x5 ft). Just to compare against the local prices
« Last Edit: October 10, 2013, 02:25:34 pm by floriske.nl »
macattack
« Reply #870 on: October 10, 2013, 02:39:09 pm »
pre primed mdf.
1/2" is around $35 for a 4x8 sheet.
floriske.nl
« Reply #871 on: October 10, 2013, 05:31:02 pm »
$ 35,- for a 4x8 sheet of 1/2" laminated particle board?
Whish we had it at that price would be a lot better than pre primed MDF (Thanks!  :notworthy:) at $ 40 for s 8x4 sheet
« Reply #872 on: October 10, 2013, 05:33:29 pm »
$ 35,- for a 4x8 sheet of 1/2" laminated particle board? Whish we had it at that price would be a lot better than pre primed MDF (Thanks!  :notworthy:) at $ 40 for s 8x4 sheet
I'm with you. It's $52 at our Home Depot for 5/8" melamine sheets, vs. $33 for MDF here in Canada.
« Reply #873 on: October 11, 2013, 07:56:06 pm »
Well, since Haruman isn't here to blow his own horn, here's a link to some "positive press" he's received on Reddit. Well done, my friend.
« Reply #874 on: October 11, 2013, 09:09:25 pm »
Where did I go? O0
Thanks for the find & the link!
« Reply #875 on: October 11, 2013, 09:11:47 pm »
No problem. Some of us dabble in Reddit. Others of us live there.
« Reply #876 on: October 11, 2013, 11:03:28 pm »
Yeah, I'm pretty new to the whole reddit thing.
« Reply #877 on: October 11, 2013, 11:07:02 pm »
Don't worry about it. Next week, I'll show you how it works.
cdf12345
  • Last login:February 13, 2020, 08:36:10 am
« Reply #878 on: October 11, 2013, 11:46:53 pm »
If you made a cabinet out of bacon, they would probably throw money at their screens.
And I say they as in we. Myself included.
« Reply #879 on: October 11, 2013, 11:48:35 pm »
STOP GIVING HIM IDEAS!
