Author Topic: Question Regarding Acrylic for CP/marquee/bezel cover  (Read 1621 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: February 16, 2013, 06:08:14 pm »
I'm not really sure which to choose for the control panel cover, bezel/marquee cover:
Lexan or Plexi
My question is:
- Is one better than the other? (if cost doesn't matter which would you choose?/why)
I know that plexi is harder and brittle, but ive heard that lexan is extremely durable and even bullet resistant, but is it scratch resistant? (does it scratch really easily)
Thanks.
Edit: the only thing is, the lexan sheet is 1/16" and the plexi is 1/4" thick.
I'm also using 3/4" mdf.
Edit2: I just foundhttp://www.tapplastics.com
So I can get 1/4" lexan as well.
« Last Edit: February 16, 2013, 07:39:42 pm by Yourname942 »
Yourname942
Re: Question Regarding Acrylic for CP/marquee/bezel cover
« Reply #1 on: February 16, 2013, 06:51:39 pm »
anyone know which one would be the better choice to buy?
DEIVIONCRX
  • Last login:October 23, 2014, 05:18:29 pm
  • District 1
« Reply #2 on: February 16, 2013, 08:39:36 pm »
All of it scratches pretty easy unless it has a scratch resistant coating.  But anything your going to find at Home Depot/Lowes etc isn't going to have that.  The scratch coatings are usually found on Lexan windows for cars or buildings.
Lexan(Polycarbonate) is stronger so if i was going to use it id use it for the control panel where people will be banging around.  But I'm using Acrylic on all of mine.
"Simplify, then add lightness." - Colin Chapman
Louis Tully
« Reply #3 on: February 16, 2013, 08:39:47 pm »
« Last Edit: February 12, 2015, 03:19:53 pm by Louis Tully »
