Author Topic: Ross' 13 week arcade cab project*COMPLETE*(now has a name"hidden treasures")  (Read 21717 times)
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
Re: Ross' 13 week arcade cab project(now has a name"hidden treasures")
« Reply #40 on: April 30, 2013, 05:19:58 pm »
http://forum.arcadecontrols.com/index.php/topic,104114.0.html ?
thanks for the link mate but i just ordered it from t-molding.com it adjusts shipping after you checkout so came to $7 :)
i re-cut my CP so that the buttons were closer together also cut my plexi and put my artwork on ,i made a frame out of scrap wood laid my plexi in it then my CP on top ,took the drill bit out of my hole saw and went for it came out really good,but I'm going to take some more plexi down to where i got my glass cut (as one edge is a little jagged from me sawing it) and get them to cut 2 pieces out(1 as a spare)
19 days left!!
Mr Wilson
  • it never ends!!!!
« Reply #41 on: May 02, 2013, 03:40:31 pm »
got the marquee mounted and lit :) also wired up the coin door light( it doesn't look that washed out,i just cant get a good pic) also the retainers are going to be painted black,i was going to leave them white to match the t-molding but it just look weird
i still need help on this switch please? i just want to wire in a power button but what wires do i use? i don't want to just cut them and try putting them together just in case i mess something up i know there's 4 going to the old PC switch but that's about it :/
Mr Wilson
  • it never ends!!!!
« Reply #42 on: May 13, 2013, 05:48:41 pm »
been a really busy week,but not on this project only got 5 days left made a bit of progress but gonna make sure this is done by Saturday night ready for my sons birthday on Sunday  ;D
Superfrog
    • My YouTube Channel
« Reply #43 on: May 14, 2013, 01:39:41 am »
Your a great dad  :applaud:
Looking very sharp  :cheers:
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #44 on: May 14, 2013, 09:20:56 am »
I like it but those buttons are super bright.  Not sure if that's because of the pictures or if they are that way overall.  Either way good build!
orion
« Reply #45 on: May 14, 2013, 01:17:41 pm »
Well I have never seen a PC with a power button on a separate card like that. Usually there are separate pins going to the MB, and you can just splice in any momentary switch to that. If those wires connect to the MB, you could take a knife or a screwdriver and try bridging different pins to see which two are the power. Usually its labled though. The other thing you can do is make a switch at the powersupply itself. Most powersupplys you can rig to always power on by shorting the green to one of the black wires. I did this for my 60in1 as I always seem to have PC power supplies laying around. Just make sure the pin outs are correct as some PC manufactures use a different colored wire other than green.
http://m.instructables.com/id/How-to-power-up-an-ATX-Power-Supply-without-a-PC/?ALLSTEPS
Mr Wilson
  • it never ends!!!!
« Reply #46 on: May 15, 2013, 08:01:29 am »
Thanks mate
Mr Wilson
  • it never ends!!!!
« Reply #47 on: May 15, 2013, 08:05:04 am »
Thanks,They are a bit bright I think I'm going to fit a switch to turn them on/off
And when I've got some more time make some custom illuminated buttons that aren't as bright
Mr Wilson
  • it never ends!!!!
Thanks Orion
But I sorted it the other night a bit of guess work I cut the black and white wires connected it to a microswitch and it worked first time! A good bit of luck :)
« Last Edit: May 19, 2013, 04:02:32 pm by Mr Wilson »
Mr Wilson
  • it never ends!!!!
« Reply #49 on: May 19, 2013, 04:16:19 pm »
Just managed to get everything sorted in time,finished at 1 in the morning,a few tweaks left to do but that's expected on any project our son Alex was really excited but i still think he's a bit young but it wont be long before he beats my scores
I'd say its the perfect height for him. He's just tall enough now and wont be too tall for a while  :cheers:
Mr Wilson
  • it never ends!!!!
cheers mate
I'm having a loads of problems with using mala jukebox just want it simple one gamelist of about 70 games move the joystick to the right flips to jukebox list had it working for 5 mins now it doesn't???? it just freezes up on songs and wont start playing??? tried it on my laptop and another PC and have the same problem looked on the mala section but not much help?????
Mr Wilson
  • it never ends!!!!
A quick pic of our son Alex showing his little brother Adam what to do on a game  :)
  • Last login:January 05, 2026, 03:14:20 pm
Very nice job, sir!  :cheers:
Mr Wilson
  • it never ends!!!!
Will be making another scaled down cab soon for our youngest
Will start a build thread in the new year
http://www.koiforum.uk/showthread.php?t=13834
Brouhaha
  • Last login:January 31, 2022, 01:05:15 pm
  • Learning as I go!
Wow! Hadn't seen your build. Very cool!
I'm about to build a mini pacman myself. How high is yours?
Cheers!
Mr Wilson
  • it never ends!!!!
Thanks mate
It's 120cm at the highest point,this way you can get both the sides out of 1 sheet of mdf
Good luck with your build
Mr Wilson
  • it never ends!!!!
If you want the full measurements I'll get them for you,I'd say it's the perfect size,I can still play it comfortably sitting on a stool and I'm 6'2"
Mr Wilson
  • it never ends!!!!
Bringing this thread back from the dead!
Cabs been working fine these last 4 years,until 2 weeks ago
Hard drive failure I think? Well tried everything but got it up and running again then it crashed again,try's everything wasted about 40hrs in total
So now I'm using my laptop
Got everything on there
But got a problem I'm using a mini pac encoder nothing has been changed but when I plug it in button number 5(1p coin) is stuck on??? Even after disconnecting coin door micro switch and hidden credit button micro switch it's still doing it???
Any ideas? Of what else to try
Cheers
morton
Nice lil mini cab! I am a fan of these builds. In regards to one button staying on... are you sure you don't have a short somewhere? Granted its probably a USB thing (which I am clueless about), but in any other cab I would look for a short... That would be my first guess.
