Author Topic: Spray paint MDF before or after assembly?  (Read 5083 times)
SnaXen
  • Last login:November 27, 2013, 04:11:44 am
  • I build my arcades from scratch!
« on: February 15, 2013, 08:38:33 am »
Hi.
This is my first post here.
I am in the process of building a bartop cabinet. And now I have started to think about the paintjob.
Going to use spraycan filler, primer and paint.
So I wonder what is the best solution (what do you prefer?) regarding the order of paint?
Should I paint each pannel before I assemble it, or the hole cab after I have assembled it?
Is it best to cut holes before painting, og should I do it after?
Thank you for your replies.
-=SnaXen=-
P.S. If you are interrested I have a builders log, with some pictures,  here http://www.diskusjon.no/index.php?showtopic=1489131   (so sorry, but it's in Norwegian. Google translate?)
shponglefan
Re: Spray paint MDF before or after assembly?
« Reply #1 on: February 15, 2013, 08:43:00 am »
I'd do it last.  If you want a nice finish, you'll want to fill in and sand any screw holes, edges, etc, so everything is smooth.  So you want to do that after assembling.
You *could* do it before, but it wouldn't look as nice.
« Reply #2 on: February 15, 2013, 08:43:25 am »
On fullsize builds I paint after assembly for pieces that won't come off. On micro builds I paint after hole drilling due to space issues.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #3 on: February 15, 2013, 11:01:48 am »
Chuck and Shponglefan are spot on for me as well.  I assemble/glue/drill/putty/sand and then I prime/paint.  I usually like to prime twice, test fit everything together again to a finished cab, and upon validation rip it all down, finish paint two coats and then finish final assembly.
SnaXen
« Reply #4 on: February 16, 2013, 12:23:33 pm »
Thank for your replies.
Good advice.
