Author Topic: Ootake from Mala anyone?  (Read 4664 times)
« on: January 27, 2013, 03:34:55 pm »
Anyone launching Ootake from Mala?  rCadegaming has me hooked on some PC engine games and I don't want to have to reinvent the wheel if I don't have to.  If anyone is using this emulator with Mala I'm interested in knowing how your mounting CD roms, or getting around that hurdle.
Re: Ootake from Mala anyone?
« Reply #1 on: January 27, 2013, 04:03:10 pm »
Mala will run whatever you point it at pretty easily.  I run Frets on Fire and a lot of SCUMMVM games as well as other regular windows games from the FE w/out issue.
chopperthedog
  • Online Online
  • Last login:Today at 08:14:56 am
« Reply #2 on: January 27, 2013, 04:14:21 pm »
In the past I used Alcohol120% to create virtual cd/dvd drives and mounted images to their own drives.
good day.
« Reply #3 on: January 27, 2013, 07:14:06 pm »
yes but how do I mount a different disc each time a game is selected?  Can Mala do this with a pre-command or must this be done by bat file?
chopperthedog
  • Online Online
« Reply #4 on: January 27, 2013, 07:30:22 pm »
I'm not educated to the specifics of the emu you're using. But I used Alc120% on an old cab that I put the EA collection (Baseball, NHL, Madden, Nascar and Woods. also had 3 pc games) on and created new emulators/single screen layouts for each game. So I basically had 8 virtual rom drives that had the specific disc images mounted to them and had a shift key to scroll through the so called emu's in mala to launch those cd/dvd games. Never looked into trying to make it into just one list.
good day.
« Reply #5 on: January 28, 2013, 11:06:18 pm »
I found some code that will accomplish mount and un-mount stuff for the CD's, but let's shelve that for a minute.
I'm having issues with the basic Hu-Card games.  If I launch one in Mala, only the music plays, screen is black regardless of adjustments to video settings.
So I figure, it's some syntax in the command line.
So I'm working in the command like to launch Ootake, and I can't get it to launch straight to the game.  I can get it to launch Ootake's GUI green screen, where you can select to either launch a Hu-Card or CD ROM.  But when I try to add a ROM argument to the launch command it gives me a "Can't launch %rom%" then "MainBoard Init Error"
I can't find anything online regarding launching Hu-Cards, all of the issues documented seem to be regarding the CD-ROMS and I need to walk before I run.  Any ideas?  It's gotta be something that makes the choice on that GUI.
« Reply #6 on: January 29, 2013, 12:25:34 am »
set the emulator to default settings and it fixed the issue with the screen, though I'm still battling some lag at higher resolution.  Oh well at least it's working now.
« Reply #7 on: January 31, 2013, 10:10:07 pm »
Changed setting to direct draw and I'm good, now on to PC engine CD Rom games...
I have sucessfully been able to mount and unmount CD images via DAEMON Tools and the Command line using the following syntax:
DTlite -mount dt, 0, <path>
and
DTlite -umount_all
So I figure I can use Pre Command and Post Command functionality in MALA to accomplish this.  However I'm having trouble getting it to work.
How can I make the <path> in the pre command dependant on the game selection within Mala?
Can any of you batch wizards help me with this?
« Reply #8 on: January 31, 2013, 11:24:04 pm »
Okay so I've managed to use the %path% and %rom% tags to get the command prompt accomplish what I'm doing outside of Mala but I'm still getting
Failed to execute program: "DTLite -mount dt, 0, "C:\Emulation\Programs\Ootake\cd image\Gate_of_Thunder_(NTSC-J)_[HCD2025].CUE"". Error Code 2
« Reply #9 on: February 01, 2013, 07:35:07 pm »
Getting closer  note Dameon tools executable is in the Ootake folder, I know this isn't clean but work with me.
cmd.exe /C "C:\Emulation\Programs\Ootake\DTLite -mount dt, 0, "%path%\%rom%.%ext%""
The only reason I'm thinking this isn't working is because it doesn't like quotes within quotes.
Syntax help anyone?
« Reply #10 on: February 01, 2013, 08:00:17 pm »
added a /S!  now it's working
cmd.exe /S /C "C:\Emulation\Programs\Ootake\DTLite -mount dt, 0, "%path%\%rom%.%ext%""
There is still something wonky in the emulator though I have to remap to the virtual drive even though that drive is already set to as the default, still playing with it.
« Last Edit: February 01, 2013, 08:04:29 pm by harveybirdman »
« Reply #11 on: February 02, 2013, 01:00:58 am »
Okay homestretch, so Mala is launching Ootake very quickly after it executes my pre-command to mount the CUE file for the selected game, and therefore I have to tell Ootake to check for a CD using it's GUI instead of it just knowing one is there.
Can someone help me with a solution?
« Last Edit: February 02, 2013, 01:04:25 am by harveybirdman »
« Reply #12 on: February 02, 2013, 01:10:26 am »
Freaking SWEET  :afro:
I figured it out!
Since the pre and post commands mount the image, I can just use Ootake's /cd command!
Sweet!
Time to go steal some games from the interwebz!
