Author Topic: TUT - Making serial plates with Soda Cans  (Read 6919 times)
CoryBee
  • Bopity Boopy
« on: December 13, 2012, 02:57:42 am »
Quick and easy tutorial on making cheap serial plates for your projects
_Supplies List_
Avery #18665 - "Avery 18665 Clear Full Sheet Inkjet Labels"
Any Clear Coat Paint - I am using Rust-oleum Picture
Soda Cans - Preferably not diet because diet soda sucks
Serial Plate Template - Provided by Tighe Lory
Clamps\Iron & Patience
Cutting the can to size (be careful not to cut yourself - gloves maybe)
The Aftermath
Once you get the piece just right you can either iron it (takes forever) while bending it - "not recommended"
I am making a bunch so I decided to go the press route. I have 8 pieces clamped between two scrap pieces of smooth MDF
MDF isn't over it completely in the first two pictures for illustration purposes
Keep the clamps as tight as possible to ensure a perfect flat surface  :cheers:
_All of these techniques have been taken from aluminum paper craft websites_
« Last Edit: December 13, 2012, 08:43:49 pm by CoryBee »
CoryBee
  • Bopity Boopy
Re: TUT - Making serial plates with Soda Cans
« Reply #1 on: December 13, 2012, 02:58:08 am »
Flattened
Cut out the image and apply -carefully, it is fragile and very sticky- to the can
A light coat of the clear coat - Too much and you might make the ink run
« Last Edit: December 13, 2012, 08:40:05 pm by CoryBee »
mcseforsale
  • Creepy Mario Dude
« Reply #2 on: December 13, 2012, 01:35:36 pm »
subscribed...
AJ
CoryBee
  • Bopity Boopy
« Reply #3 on: December 13, 2012, 08:42:46 pm »
Finished product - Just drill small holes to accept the screws in the corners, there are little dots to guide you.
_______
« Last Edit: December 14, 2012, 02:37:56 am by CoryBee »
jammin0
« Reply #4 on: December 14, 2012, 12:17:34 am »
Sweet   :applaud:
Do you go to work? Sleep?  Keep the good stuff coming.
CoryBee
  • Bopity Boopy
« Reply #5 on: December 14, 2012, 01:06:12 am »
Sweet   :applaud:
I am my own boss  >:D
Sometimes I forget to sleep.......
CoryBee
  • Bopity Boopy
« Reply #6 on: December 14, 2012, 02:36:06 am »
What do you guys think?
« Last Edit: December 14, 2012, 02:38:22 am by CoryBee »
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
« Reply #7 on: December 14, 2012, 03:23:45 am »
Looks really good will do something like the for my next cab. >.< already got a few cabs designed in sketchup, just need to figure out which one I want to make. The flash is kind of killing it can't really tell if the aluminum is showing through.
Sent from my Nexus 7 using Tapatalk
CoryBee
  • Bopity Boopy
« Reply #8 on: December 14, 2012, 03:35:26 am »
Yea sorry about the flash. The aluminum shows through pretty well.
GnobarEl
  • Last login:February 21, 2019, 04:58:34 pm
« Reply #9 on: December 14, 2012, 05:21:32 am »
This is great!
I will use it when I buil my arcade cabinet.
Thanks for sharing.
rablack97
« Reply #10 on: December 14, 2012, 08:13:46 am »
Very cool man....
My only thought is I would modify the design to get rid of those sharp sides and edges, unless your wrapping the label around the can.
Slip of the hand around those suckers and your headed to the hospital....
For protection you might even consider, getting you some lamination sheets, sandwiching the plate and running it through a hot laminator.  They even make business card pocket, scale down the design to fit and it will seal the entire plate....no sharp edges....
threedprof
  • Last login:April 21, 2016, 05:57:44 pm
« Reply #11 on: December 14, 2012, 10:43:36 am »
Really awesome idea! Thank you for sharing :)
Arcade projects
CoryBee
  • Bopity Boopy
« Reply #12 on: December 25, 2012, 01:18:55 am »
Extra mini-tron serial plates is a good idea ;D
griffindodd
  • Builds Stuff
« Reply #13 on: December 26, 2012, 05:06:55 pm »
You win 10 Internetz points for this, now I'm off to buy some soda
I drink and I know things.
« Reply #14 on: December 26, 2012, 05:11:20 pm »
 :applaud: :applaud:
mcseforsale
  • Creepy Mario Dude
« Reply #15 on: December 26, 2012, 07:57:15 pm »
Agreed ^^   :applaud: :applaud:
Idea (and template) officially stolen:
It's going on this:
AJ
CoryBee
  • Bopity Boopy
« Reply #16 on: December 26, 2012, 11:21:21 pm »
Hell yea! All I needed was ten internet points to afford my pirate flag  :cheers:
CoryBee
  • Bopity Boopy
« Reply #17 on: December 27, 2012, 01:48:40 am »
I am glad my post has been inspiration enough for others to improve their already awesome MAME machines!
I stole the template from a KLOV member so feel free!
