Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.2%)
CHAMPIONSHIP I
7 (4.2%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12%)
CHALLENGE
32 (19.3%)
TEAM CHALLENGE
54 (32.5%)
TEAM CHALLENGE w/ ALL ACCESS
28 (16.9%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9%)
Total Members Voted: 166
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 977178 times)
Torin
  • Last login:February 19, 2021, 11:57:56 am
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #1640 on: November 25, 2015, 05:47:07 pm »
WT works fine.  My # when I enter my players card is:  328204
Not sure if that's my cab # or not?
Edit:  Cabinet number is:  30028
boostinallovryou
« Reply #1641 on: November 25, 2015, 05:48:20 pm »
You know what, there might be a common theme here.  Are both of you two that cannot see tournaments running dongle emulators?
Torin
« Reply #1642 on: November 25, 2015, 05:54:30 pm »
I am but I do have a Team Challenge dongle too.  Should I install it and see what happens?  Will that screw up my data or settings?
boostinallovryou
« Reply #1643 on: November 25, 2015, 05:56:36 pm »
If you plug your dongle in it won't have the registration settings from the server.  You need to unregister, uninstall dongle emulator, install dongle, re-register.  This won't mess up any of your WT settings or history.  After you re-register you have a 50/50 shot at seeing tournaments.  If you don't when I get home and manually add an entry in the database with your new cabinet ID you will 100% see tournaments.
boostinallovryou
« Reply #1644 on: November 25, 2015, 05:58:29 pm »
Just to clarify what I mean by unregister is NOT to reinstall the .4 patch.  It means to just go into the service mode and instead of forcing a call, there is an option at the bottom to unregister from server.
Torin
« Reply #1645 on: November 25, 2015, 06:22:13 pm »
Ok, will do and report back.  Thanks!
Torin
« Reply #1646 on: November 25, 2015, 07:14:04 pm »
Ok, unregistered, uninstalled the dongle emulator, plugged in the real dongle and re-registered.  Got back on fine but still no tournaments showing for me.
It looks like my leaderboards and unlocked items are still intact but it shows that I haven't played any courses or got any scores on any of the holes and so I don't have any player stats anymore.
Oh well, they weren't that impressive anyway.  :)
My new cabinet # is:  30036
boostinallovryou
« Reply #1647 on: November 25, 2015, 07:19:42 pm »
Ok, once I get home I will manually add an entry for 30036.  After I do that I will let you know to call in.  You will then have tournaments.
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #1648 on: November 25, 2015, 08:26:00 pm »
That's a big problem for those without an actual dongle that they can't play tournaments? Is there a fix or do they all have to find a dongle somewhere? If so gonna start finding all the dongles that exist here in Australia and buy them as spares!! Ha ha ha. I guess I'm still top of the leaderboard then boost as I'm the only one able to play ha ha ha. It's good to be the King!!  :burgerking: even if by default!! Ha ha
boostinallovryou
« Reply #1649 on: November 25, 2015, 09:16:01 pm »
Ok Torin, call in, you should have tournaments.
Torin
« Reply #1650 on: November 25, 2015, 09:42:08 pm »
Just called in Boost.  Still no tournament.    ???
boostinallovryou
« Reply #1651 on: November 25, 2015, 09:57:27 pm »
What is the date and time say on your pc?
Torin
« Reply #1652 on: November 25, 2015, 10:05:33 pm »
It says 11/25/15 and has the correct time and time zone in the game and on my actual pc.
« Last Edit: November 25, 2015, 10:12:11 pm by Torin »
boostinallovryou
« Reply #1653 on: November 25, 2015, 10:15:41 pm »
In attract mode do you see tournaments enabled in green at bottom left of screen?
Torin
« Reply #1654 on: November 25, 2015, 10:20:18 pm »
Yep, tournaments enabled and cabinet says registered.
boostinallovryou
« Reply #1655 on: November 25, 2015, 10:24:06 pm »
I think it's time to unregister and reinstall from scratch.  Sorry man.
boostinallovryou
« Reply #1656 on: November 25, 2015, 10:24:51 pm »
You have a card reader connected right?
Torin
« Reply #1657 on: November 25, 2015, 10:27:49 pm »
Yes, and it works great for WT.
Well, if I have to reinstall, I'll have to reinstall.  Not that big of a deal.  Thanks for all your help and have a great Thanksgiving.  I'll see you in the tourney!  Hopefully!
Torin
boostinallovryou
« Reply #1658 on: November 25, 2015, 10:28:43 pm »
Guess it's time to reinstall.  I'm out of ideas.
Spitfire
« Reply #1659 on: November 25, 2015, 11:05:09 pm »
Boost it wouldn't be a region thing? Are you playing the tournament boost? And is anyone playing?
boostinallovryou
« Reply #1660 on: November 25, 2015, 11:07:48 pm »
I havent had a minute to fire up my machine and join in yet.  I figured everybody would chomp at the bit to call in and join the tournament.  Has anybody other than spit played?
TimBoch
  • Last login:October 30, 2024, 11:48:46 pm
  • Be the Ball.
« Reply #1661 on: November 25, 2015, 11:16:40 pm »
Well I got my wifi repeater yesterday, $14.99 off eBay, http://www.ebay.com/itm/161858554265?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
And decided to give it a go to try and get online.  The install went just fine, the patch which I installed on a very old CD-RW installed just fine. The cabinet registered fine and I was able to have the Player Card I made for TC AAP converted for use in TC World Tour.  I was able to connect to the server and all has gone well. I can see all the scores by some much better golfers than me as I play the courses, about 7 rounds so far. I force a call and send my scores and see them on the website.  All seems cool and fun. I too am unable to see a tournament however.
Here is my Cabinet ID and Player ID.
Fingers crossed to not have to reinstall.
I can't thank you enough for all your work making it available for us to play online!!
Tim
« Last Edit: November 25, 2015, 11:32:02 pm by TimBoch »
boostinallovryou
« Reply #1662 on: November 25, 2015, 11:23:20 pm »
Now you guys have me going wtf.  I'm gonna go test on my machine.
Spitfire
« Reply #1663 on: November 25, 2015, 11:29:18 pm »
It seems I am playing by myself boost!! The boys on face book don't see it either just me I think?? Ha ha ha
Spitfire
« Reply #1664 on: November 25, 2015, 11:33:44 pm »
Hey Tim what is your nick on the leaderboards?
boostinallovryou
« Reply #1665 on: November 25, 2015, 11:36:04 pm »
I cant see it either, wtf!!  I'm on it!!!
TimBoch
  • Be the Ball.
« Reply #1666 on: November 25, 2015, 11:44:29 pm »
Here is my info.
boostinallovryou
« Reply #1667 on: November 25, 2015, 11:48:22 pm »
Oh man i might know what it is.  Spit was the first one to call in.  I bet i have a bug in my code.  Firing up machine now.
Spitfire
« Reply #1668 on: November 25, 2015, 11:52:32 pm »
I know I don't have that many friends but this is ridiculous!!! :cry: lol
boostinallovryou
« Reply #1669 on: November 26, 2015, 12:09:05 am »
Found the bug, fixed it, uploaded, tested on my machine.  Go for it guys.
boostinallovryou
« Reply #1670 on: November 26, 2015, 12:26:02 am »
I played like garbage, only shot 15 under.  But at least im on a board somewhere with ya spit.
Torin I'm sorry man.  Part of being on the dev team right?
Everybody is quiet now.  Guess that means they can see tournaments now :-)
Spitfire
« Reply #1671 on: November 26, 2015, 02:08:53 am »
Great news boost. It was getting lonely at the top. Home now after work and play some more rounds. Ha ha I love it!!
boostinallovryou
« Reply #1672 on: November 26, 2015, 02:10:14 am »
Let me know if you are able to play more than 5.
Spitfire
« Reply #1673 on: November 26, 2015, 03:17:54 am »
Struggling hard with the conditions boost ha ha ha do they change daily? As exact same as yesterday for me.
gvdvyver
  • Last login:August 03, 2017, 08:35:35 am
« Reply #1674 on: November 26, 2015, 04:43:44 am »
Hi Boost
I called in about 5 hours ago and no tournaments. I will be home in about 8 hours and will try again. I am using a dongle and not the emulator
Note: That I can not see leader boards on WT yet. I remember you said that you have to do performance upgrades on the server for me to see leader boards. I am not sure if that is why I can not see tournaments.
Thank you
Spitfire
« Reply #1675 on: November 26, 2015, 05:06:27 am »
Hey boost I played more than 5 times and still lets me play another round. I thought it may be because I didn't call in after. So I did so and still could play again played five rounds in a row even restarted. Tried all combos and still let me play. 23 under my best score! Also I am asked to play the tournament from the attract screen before anything else comes up? Is that what everyone else's machine is doing?
« Last Edit: November 26, 2015, 05:37:31 am by Spitfire »
TheSherman8or
  • Last login:January 27, 2017, 08:52:01 am
« Reply #1676 on: November 26, 2015, 09:23:00 am »
Hey guys just played the tournament worked great. I have a question maybe someone else had the same issue or can point me in the right direction. Sometimes when I am playing for awhile mostly multiplayer since they take longer I am not able to get a full shot. The ball barely goes anywhere with a full back swing. I was wondering if it is trackball related if after all the abuse it finally went or if the ram can't keep up and I need to upgrade it. If so what is the best ram you guys have found to put in it.
Thanks and Happy Thanksgiving to everyone.
gvdvyver
« Reply #1677 on: November 26, 2015, 09:33:15 am »
Hi Sherman8or
How much Ram do you have in the pc? What size graphics card do you have?
What you can try is to swop the red chips on the trackball and see what happens.
TheSherman8or
« Reply #1678 on: November 26, 2015, 10:30:39 am »
I have 512 mb of ram and nvidia ge force 6600 graphics card.
boostinallovryou
« Reply #1679 on: November 26, 2015, 11:01:27 am »
Please read my post above where i wrote "PLEASE READ FINE PRINT"
