Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.2%)
CHAMPIONSHIP I
6 (3.6%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12.1%)
CHALLENGE
32 (19.4%)
TEAM CHALLENGE
54 (32.7%)
TEAM CHALLENGE w/ ALL ACCESS
28 (17%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9.1%)
Total Members Voted: 165
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 931645 times)
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #1200 on: September 06, 2015, 08:26:35 am »
Does anyone have the All Access .dng file they would be willing to share?
Hi mate try this PGA GOLF Facebook page I think it might be there?
https://www.facebook.com/groups/444981388985690/
edowen55
  • Last login:August 02, 2016, 09:38:54 pm
« Reply #1201 on: September 06, 2015, 08:55:54 am »
I found the .dmp file there, but have been unable to convert it to a .dng.  Was hoping someone had the .dng ready to go.
I was able to use the TM Challenge .dng from the FB group to eliminate my TM Challenge dongle though.
edowen55
« Reply #1202 on: September 06, 2015, 09:26:53 pm »
Well, it was a good day.  I got TM Challenge to work with the dongle emulator and successfully connected to the server.
Spitfire
« Reply #1203 on: September 06, 2015, 11:06:55 pm »
That's great news mate. Was it hard to do with emulator as it seems some people are having trouble with it. I haven't tried myself as have the dongles but would you be able to post a walkthru for people that are having trouble? Thx Joe
edowen55
« Reply #1204 on: September 07, 2015, 12:06:25 am »
I didn't come up with the process, or create the files.  Lou and others over at the Facebook page paved the way.  I recommend signing up for the Facebook page if you haven't already.  https://www.facebook.com/groups/444981388985690/
Here are the basic instructions for using the dongle emulator for Team Challenge:
1) Have Team Challenge running to the point where it says you don't have a valid dongle  (if you need the files to get you to this point, they're available through the facebook group)
2) Insert a disk or usb drive with the HASPHL2007.exe file and Team Challenge.dng files (available here - https://www.dropbox.com/sh/gqbxb5g1wwl79k5/AAC4k4qpT47DsueU2eTpl6Z2a?dl=0 )
3) Create a new folder on the C: drive and drop those two files into the folder
4) Open the HASPHL2007.exe file
Under “Driver” tab
5) Click “Install Driver” - driver should install
6) Select Automatic
7) Click “Save State”
Under “Emulator” tab
8 ) Click “Start Service”
Under “Dongle” tab
9) Click “Load Dump”
10) A window will open, locate the Team Challenge.dng file, select open
Under “Emulator” tab again
11) Confirm that the license field is populated
That’s it. Restart your game without a real dongle attached and it should work.
If you're running a different version of the game and have the .dng file, the process is the same.  I still haven't figured out how to convert a .dmp file to .dng.  If someone could share that info I'd be grateful.
Spitfire
« Reply #1205 on: September 07, 2015, 08:24:34 am »
Thx mate I will give this a try in case one of my dongles ever die.
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #1206 on: September 08, 2015, 03:00:44 pm »
Are you guys doing this on your own, different hardware, or the computer hardware that came existing with the cab?
Reason I ask is I'd like to upgrade to Team Challenge on a newer machine as a sandbox and not overwrite my existing machine, so I can fail back if I have to.
edowen55
« Reply #1207 on: September 08, 2015, 03:21:11 pm »
I put mine together on a Dell GX620, 6600 graphics card, and a fresh SATA hard drive with a IDE converter.  I'll probably try an SSD soon to see if it speeds up the boot time.
You can just pull out your original hard drive and load Team Challenge to a new hard drive so that you don't mess up your original.
bratwurst
« Reply #1208 on: September 08, 2015, 03:26:45 pm »
Good point, I thought about doing that.  My original machine in there is really loud too - not sure if it is the power supply or the processor fan but it is so loud I can't stand it.  So at the very least I need to get rid of the bad fan and replace it.
I can't do anything with the upgrade either until I can download the ISO from somewhere.  Is anyone still hosting those?  I have sent STP a couple PMs but haven't heard back from him yet.
I have a Challenge dongle, so to upgrade I'm going to have to go the emulation route.
Also looking for some player cards if there are any out there.
edowen55
« Reply #1209 on: September 08, 2015, 03:30:48 pm »
You can get everything you need from the facebook page, ISOs and dongle file.  My instructions above should make it easy for you to set up the emulation.
There are some player cards on ebay right now, 5 for $10 shipped.
bratwurst
« Reply #1210 on: September 08, 2015, 06:42:31 pm »
Cool will see if I can find the cards thanks
I didn't see the ISO on the Facebook page will look again
edowen55
« Reply #1211 on: September 08, 2015, 06:55:02 pm »
The link is in one of the posts.
edowen55
« Reply #1212 on: September 08, 2015, 09:00:50 pm »
Here's a short video I put together to help with loading the emulator.
  • Last login:January 23, 2026, 01:40:05 pm
« Reply #1213 on: September 09, 2015, 12:25:20 pm »
you won't see any difference. you are limited by the speed of the PATA bus not the throughput of the drive. you can increase speeds on PATA by making sure you are using an 80 conductor cable and not a 40 conductor cable.
bratwurst
« Reply #1214 on: September 29, 2015, 11:50:35 pm »
Update on my end, as already reported on facebook group:
bought a gx620 on ebay, 6600 graphics card.  Loaded it up, couldn't get the chipset right after loading the game and therefore sound was not working.  Worked on this forever, not helped by the fact that Dell no longer had the chipset for download, nor the sound drivers, for the desktop I got off the used market.  Tried to get them from Intel's site but I think I installed wrong ones.  Took a chance on some drivers I found on a 3rd party website (dicey) but they were solid and worked like a charm.  Dongle would not emulate though, even though I was certain I was doing the steps right.  I thought there was a chance the original chipset install might be the issue.
Finally decided to just try again from scratch, and this time after the OS recovery I loaded chipset and sound right away, then the game, and bam, emulator worked easy as pie on first try.
Then... I loaded  all access.  Oops... forgot that the server patch won't work with all access.   Now I feel like a total idiot because I am going to have to do the install all over.   :banghead: :banghead: :banghead:
Oh well - at least I know it all works now! And the new machine runs faster, and oh so much quieter!
Quick question - anyone tried to run the game using a new USB Happ trackball instead of the one with the IO card? Now that the dongle can be emulated, if there is a way to use the buttons with a small ipac and a Happ USB trackball I was thinking I could build another machine without needing any of the oem equipment.
edowen55
« Reply #1215 on: September 30, 2015, 07:28:52 am »
Glad you got it all working.
Which dongle file did you use for all access?  Was it a .dng or .dmp?
bratwurst
« Reply #1216 on: September 30, 2015, 12:32:36 pm »
i used the dng that was included in the files i got from the facebook group for TC.  Then when I installed the All access patch, I kept the same dongle file in place and it never prompted me with an error.
edowen55
« Reply #1217 on: September 30, 2015, 02:51:48 pm »
So you've got all access running 100% with the dongle emulator?
Did you add the all access patch after the emulator, as it sounds from your post?
I kept on getting a dongle error when I did the all access patch.  Guess I'll have to try again.
bratwurst
« Reply #1218 on: September 30, 2015, 03:12:47 pm »
Once I had the TC running without AAP, I didn't really try to play anything.  I saw it booted up and controls were working, passed the dongle emulator, etc.
It asked me to register I think, and I skipped it.
My kid played a game, but I didn't.
After that, I installed the AAP patch via the disk.  As it was rebooting, I was expecting a dongle error, since the patch had been applied.  But nothing came up, and I was able to play with all 27 courses.
I'm going to wipe the whole thing and restart again as soon as I get a chance.  Might be a few days though before I get a chance.  That is, if the server is still available for check in.  Is Boost's server still up and running?
edowen55
« Reply #1219 on: September 30, 2015, 03:59:22 pm »
Great, thanks for the info.
Yes, the server is working great.  I play on it almost every day. No tournaments currently running though.
Biglou27
  • Last login:March 21, 2024, 07:37:59 pm
« Reply #1220 on: October 01, 2015, 05:11:30 pm »
UT oh did boost take down the server  :-[ can't ping the address anymore. It's a sad day at my house today have to play old school
Beach Duck
  • Last login:November 29, 2015, 03:08:25 pm
« Reply #1221 on: October 02, 2015, 12:47:57 am »
My dad recently purchased a Challenge cabinet in great condition. After wondering how to unlock the courses and different modes, I found my way here.
Just wanted to thank everyone in this thread for their contributions. The amount of knowledge gained and shared is quite special, I think.
I've decided to attempt to clone the Challenge drive onto a spare HDD and use the Team Challenge discs, Boost's ISO and emulator to see if I can get that running.
bratwurst
« Reply #1222 on: October 03, 2015, 08:12:48 am »
Server still offline? If it is back I will reload and try this weekend.
edowen55
« Reply #1223 on: October 03, 2015, 03:12:26 pm »
I just got back from vacation to find that, indeed, the server is down.
bratwurst
« Reply #1224 on: October 03, 2015, 03:41:47 pm »
I am concerned that without some announcement from our friend that maybe there's a c&d letter at play.
bratwurst
« Reply #1225 on: October 03, 2015, 03:53:07 pm »
Also, I'm in the market for a replacement marquee - the one I have looks to be somewhat off in color.
Spitfire
« Reply #1226 on: October 05, 2015, 05:58:18 am »
I also have been on holiday to just see this news. If the server is really down this is a disaster. Boost where are you mate why have you forsaken us!!!!  :hissy: :cry:
bratwurst
« Reply #1227 on: October 05, 2015, 01:39:13 pm »
I think someone had direct contact (outside the forum) with Boost.  Maybe a followup to make sure he is ok is in order?
Spitfire
« Reply #1228 on: October 06, 2015, 05:08:33 am »
Yes STP has emailed him direct but no reply. He thinks he maybe on a remote job site with no contact. That's what he said happened last time.   Urghhh wish he would return soon!!
Spitfire
« Reply #1229 on: October 09, 2015, 07:49:23 am »
 :cry: finally got round to testing the server for myself and yes no luck at connecting. This is a very sad time indeed!!! Where r u Boost please return and put us out of our misery!!  :hissy: :timebomb:
Spitfire
« Reply #1230 on: October 10, 2015, 07:53:19 am »
Just when I thought all hope was gone the Server is back up and running and that great man Boost is alive and well just flat out with a young family and another on the way. Server problems were due to power failure and battery backup failure but he has sorted things out and I am playing world tour in Melbourne Australia as we speak at 11pm ha ha. This has made me one very happy man and thx to that Genius Boost  :notworthy: This will make life much easier for us while we wait for him to find time and weave his magic again hopefully some time soon. Can't wait to post leaderboards and play some competitive golf against you all.  :applaud: Thanks Boost!!
« Last Edit: October 10, 2015, 07:24:58 pm by Spitfire »
bratwurst
« Reply #1231 on: October 10, 2015, 10:13:45 am »
Great news! I will try to reload without all access tonight and connect.
Biglou27
« Reply #1232 on: October 14, 2015, 02:48:28 pm »
 :-\ server is down again
bratwurst
« Reply #1233 on: October 14, 2015, 02:58:34 pm »
I haven't had the chance to reload my cab yet. I'm curious, when server goes down does world tour keep working for a small amount of time and then stop working? Like a week expiration or something?
Biglou27
« Reply #1234 on: October 14, 2015, 03:21:28 pm »
Scratch that I just needed to re-register the cabinet but yeah it needs a update every 3 days
Spitfire
« Reply #1235 on: October 15, 2015, 06:48:44 am »
Stop scaring me Biglou!!! couldn't take it being down again love playing World Tour. Hopefully Boost finds some time soon and gets those leaderboards up and then Tournament play happening. He has also assured me that it's not if it will get down its when. Just need to find the time as he has a new baby due real soon.  What were we ever thinking having kids!! Ha ha ha such time consumers!!
eyeless
  • Last login:July 22, 2018, 08:11:32 pm
« Reply #1236 on: October 16, 2015, 11:03:49 am »
what 6600 card are you using ? one like this :
http://www.ebay.com/itm/NVIDIA-GeForce-6600-256-VRAM-PM-G5-2-3GHZ-Video-Graphics-Card-/331677474538?hash=item4d39849eea:g:OvIAAOSwYHxWGAdb
boostinallovryou
« Reply #1237 on: October 20, 2015, 11:21:14 am »
Hey everyone, sorry for the seriously long amount of radio silence on my end.  No C&D letter or anything like that.  Just a case of wife, child, child on the way, work, house issues, taking up all of my free minutes.  It's pretty obvious that when I'm at home there is 0 chance of me working on the server.  So I'm going to take my development setup to work today and set it up in my office.  Now I can go to work early, stay late, and the Mrs won't climb all over me hahahahah.
The server went down because I had a power outage and it was so long it drained the battery backup.  Spitfire let me know and I got it back up.  Is it working ok for everybody or is it down again?  I just took a peek at the machine and it is running, but I didn't log into it.  Just let me know if you guys are not able to ping it.  I'll try pinging when i get to work today.  Thanks everybody for being patient.
Spitfire
« Reply #1238 on: October 20, 2015, 06:45:24 pm »
Great to have you back again Boost.  :notworthy: Very happy you are finding a way around the fun police of the wife and kids ha ha. The server seems to be running as it should again mate played it the other day and connected 100% percent and played world tour as normal. I will try it again today and report back. Can't wait to see what your next update will bring for us all. Exciting times thanks heaps for all your hard work so far!!  :burgerking:
boostinallovryou
« Reply #1239 on: October 20, 2015, 07:14:25 pm »
Fun police........SO TRUE hahahahahah.  I am keeping the forum up all day while i'm at work so I can post more.  That way even when i'm in my little hole writing code people still know i'm here.  I have my dev machine setup here at work now.  Going to dedicate at least one hour a day M-F to the server :-)
