Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.2%)
CHAMPIONSHIP I
7 (4.2%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12%)
CHALLENGE
32 (19.3%)
TEAM CHALLENGE
54 (32.5%)
TEAM CHALLENGE w/ ALL ACCESS
28 (16.9%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9%)
Total Members Voted: 166
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 956910 times)
0 Members and 10 Guests are viewing this topic.
TheSherman8or
  • Last login:January 27, 2017, 08:52:01 am
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #960 on: January 18, 2015, 05:28:23 pm »
Hey guys haven't checked this in awhile awesome of how far you have come with this. I have a problem I went to turn on my Team Challenge last night and the computer turns on but the monitor says "no signal" faintly. I hooked my other computer to the monitor and it works. I checked all the connections everything looks good. Do you think my video card went?
yukonblaze
  • Last login:February 16, 2023, 11:32:48 am
« Reply #961 on: January 18, 2015, 05:39:53 pm »
The computer hoked up to arcade monitor worked?
Computer monitor hooked up to.pga work?
Does video card have fan thats working?
Have replaced a couple of video cards in mine with same symptoms, am away from house but if you read through post you can find what card to replace with. Geforce 4800 maybe.
Jason
TheSherman8or
« Reply #962 on: January 18, 2015, 05:46:00 pm »
Yeah the computer I hooked up to the arcade monitor worked. I hooked the pga computer to a regular monitor too and got a blank screen. The fan on the video card is working.
TheSherman8or
« Reply #963 on: January 18, 2015, 06:00:13 pm »
Another thing I am noticing now too is the cd drive is blinking but won't open and there is no sound when its running and you hit buttons.
yukonblaze
« Reply #964 on: January 18, 2015, 06:20:15 pm »
Had same issue before, check power supply, check hdd, check memory. If you are computer savvy you may need to break it down and rebuild to find bad component. I also had to replace cpu once.
Jason
TheSherman8or
« Reply #965 on: January 18, 2015, 06:26:43 pm »
Thanks I figured it wouldn't be an easy fix lol.
yukonblaze
« Reply #966 on: January 18, 2015, 07:47:33 pm »
You could have a set of bad caps on motherboard. These are known to go bad and cause these same problems. You are going to have to pull your computer outta cab. That's the only way to tell.
Sorry
Jason
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #967 on: January 19, 2015, 12:11:45 am »
Hey Boost eagerly waiting for an update from our wizard? Or have ea or global silenced you urrgghhhh. Hope all is well mate?
Spitfire
« Reply #968 on: January 19, 2015, 12:20:19 am »
Hey Sherm Are you getting any beeps on power up? If so that tells you ur problem. 3 quick beeps and ur video card is toast and needs changing. I would first reseat ram and try. Then I would change the CMOS battery and try. Then I would replace ram and try. Then hard drive ha ha. Firstly let me know if any beeps? Thx joe
Spitfire
« Reply #969 on: January 19, 2015, 02:44:53 am »
Anybody like my new watch? Ha ha
Won on Kapula course Hawaii
« Last Edit: January 19, 2015, 09:51:59 pm by Spitfire »
Spitfire
« Reply #970 on: January 19, 2015, 03:09:37 am »
When it rains it pours! Ha ha not sure which watch is better??
Won on bay hill course I think or is it coghill.
« Last Edit: January 19, 2015, 09:53:03 pm by Spitfire »
yukonblaze
« Reply #971 on: January 19, 2015, 07:53:57 am »
Spitfire
What courses unlocked those
Jason
yukonblaze
« Reply #972 on: January 19, 2015, 08:18:26 am »
delete
TheSherman8or
« Reply #973 on: January 19, 2015, 08:07:00 pm »
Yeah no beeps on start up. Basically I turn the computer on and sounds like it starts up all fans turn on but that's it no video no sound. How much does it usually run to replace the computer? Or go the Dell way? Just wondering some options instead of shooting in the dark of what is wrong.
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #974 on: January 19, 2015, 08:11:41 pm »
I've had this happen to me before as well and after reseating the CMOS battery (the little round watch looking battery on the mother board) or replacing that battery I've fixed that problem before.  Worth a shot in my opinion.
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
yukonblaze
« Reply #975 on: January 19, 2015, 08:17:35 pm »
Pull the video card and see if it beeps, pull memory see if it beeps.  I know global vr charges arm and leg. Dell on ebay I think $50 range. If you get no beeps mean it isn't even getting to cpu embedded software bios.  Did you check to see if any capacitors are bulging or leaking? Unplug hdd when ya boot and see if you get beeps.
Jason
« Last Edit: January 19, 2015, 09:48:59 pm by yukonblaze »
TheSherman8or
« Reply #976 on: January 19, 2015, 09:41:27 pm »
Awesome thanks for all the feedback I'll post Wednesday night with my results from the different test. I hope I get it up and running I wanna get in on some tourney action.
Spitfire
« Reply #977 on: January 19, 2015, 09:50:43 pm »
Yep if no beeps than either battery dead or motherboard urghhh.
96p993
  • Last login:April 09, 2022, 01:26:37 pm
« Reply #978 on: January 20, 2015, 09:16:07 pm »
STP, Ive tried to get ahold of you several times to get some cabinet sticker work done but havent heard back. I sent you my dropbox invite and you accepted but havent heard anything
stpcore
« Reply #979 on: January 20, 2015, 09:33:34 pm »
Wow, sorry. Not sure how I am missing you. I think you have my direct email? I can print for you tomorrow. Let's connect in the morning so I can ship tomorrow as well. Email me your details (measurements) tonight and I will follow up with you after I drop my kids off at school.
stpcore
« Reply #980 on: January 21, 2015, 11:27:08 am »
Sent you a PM as well.
Biglou27
  • Last login:March 21, 2024, 07:37:59 pm
« Reply #981 on: January 21, 2015, 10:52:24 pm »
Hello everyone do we have a Facebook page ? And thank you boost for the tournament play can't wait till its all running , if we don't have a Facebook page it would probably be fun to post our screen shots , thank you again
Spitfire
« Reply #982 on: January 22, 2015, 02:14:56 am »
Don't know of any Facebook page mate?? Happy for you to start one though.
Spitfire
« Reply #983 on: January 22, 2015, 05:10:44 am »
Sorry guys, been busy with the family and fixing some house issues.  Haven't had time to play.  Hopefully near the weekend things will free up.
Missing our fearless leader  :notworthy: I hope all is ok your end boost. We hope to hear again from you soon.
TheSherman8or
« Reply #984 on: January 22, 2015, 07:11:00 pm »
Alright so I got my game fixed come to find out the small cable going to the motherboard was not down completely lol I feel foolish :-) Thanks for all the help though. Now its time to get my machine tournament ready.
Spitfire
« Reply #985 on: January 23, 2015, 09:54:31 am »
Glad to hear mate. Hope boost can re surface and we get the leaderboards running soon
« Last Edit: January 24, 2015, 05:05:41 pm by Spitfire »
yukonblaze
« Reply #986 on: January 23, 2015, 11:08:04 am »
Glad to hear computer is working now.  I have a computer to get working this week for a Need for Speed.
Jason
braggtd
  • Last login:January 26, 2015, 12:39:08 am
« Reply #987 on: January 24, 2015, 10:36:44 pm »
Hey guys, I am a long time lurker but new to the board.  I have a question regarding Team Challenge.  I was having some artifacts issues and booting issues that I discovered were the video card (I believe TI-4200).  I purchased a GeForce 6600 which has removed the artifact issues as expected.  The issue is with the new card is the menu resolution is messed up.  It looks like it is at 640 x 380 or something.  Does anyone know how I can change the resolution?  The actual play graphics are now flawless...I highly recommend this card as an upgrade.  Thanks!
« Last Edit: January 24, 2015, 10:38:21 pm by braggtd »
Spitfire
« Reply #988 on: January 24, 2015, 11:46:57 pm »
That's strange mate. The resolution should change itself on ur monitor when plugged into the VGA input on your screen. You shouldn't need to change the res in the pc settings? I have had this happen after a graphics card change but after a reboot it seems to fix itself?
« Last Edit: January 25, 2015, 12:16:42 am by Spitfire »
yukonblaze
« Reply #989 on: January 25, 2015, 08:26:04 am »
Same thing happened when I changed a card but resolved second time I booted. Is your monitor tri res? You can always hook up keyboard to computer and go into f desktop to change.
Jason
darryldale
  • Last login:March 07, 2016, 12:54:14 pm
« Reply #990 on: January 25, 2015, 10:30:52 am »
OK quick question.
I've been reading all the messages about getting the machine hooked up online and don't know if my machine that I recently picked up is a good candidate. Here is what I have:
PGA Tour Championship Edition III machine
The marquee also indicates "World Tour Challenge"
It would appear that all the courses / players are unlocked on my machine (about 20 of each?)
I have a "World Tour Challenge" menu item on the machine that is not currently selectable.
There is a card slot on the front of the machine that appears to be functional.
Is this machine a good candidate for getting working online?
Darryl
yukonblaze
« Reply #991 on: January 25, 2015, 01:40:58 pm »
Pics of your title screen, select screen. You may have all access team challenge. Look at global vr website for there manuals to determine what you have. Is good candidate as can reinstall team challenge.
Jason
dahupshee
  • Last login:March 05, 2015, 07:54:05 pm
« Reply #992 on: January 25, 2015, 04:45:06 pm »
Boost, realize you've been busy but just wanted to give you a head's up that I tried to contact the server today to upload some of my player's data and got a 4110 error. Said something about it was unable to deserialize or something. When I checked the log about connecting it said partial failure.
Spitfire
« Reply #993 on: January 25, 2015, 08:44:17 pm »
OK quick question.
Darryl
It sounds like you have a Team Challenge all access machine. At this point in time only the normal team challenge version works as the all access pass removes your ability to register your machine. Install normal team challenge version run Boosts patcher connect machine to internet register ur machine and your done.
« Last Edit: January 25, 2015, 08:45:50 pm by Spitfire »
braggtd
« Reply #994 on: January 26, 2015, 12:39:08 am »
Thanks spitfire and yukonblaze.  A reboot fixed the resolution issue.  The 6600 is a great upgrade for anyone considering changing their video card.  I purchased it for $18 shipped from Ebay.
Biglou27
« Reply #995 on: January 26, 2015, 06:10:13 pm »
Hey Everyone,
I have made a Facebook page for us to share our screenshots and to help assist this Owners Thread Thank you, would love to have who ever would like join
https://www.facebook.com/pages/PGA-Tour-Golf-by-Global-VR-EA-Sports-Owners-Page/703496909767804
TheSherman8or
« Reply #996 on: January 26, 2015, 09:23:46 pm »
On my register|connect page I only have the option to restore cabinet registration. I already had world tour and tournaments unlocked from the patcher. I hit restore cabinet registration to Re-enable online features and it goes to 5% jumps to 100% and says successful. I checked the connection history and it says failed. Anybody know how I can get it to unregister so I can re-register or connect to server?
Spitfire
« Reply #997 on: January 27, 2015, 01:26:56 am »
Hey Sherm has this machine ever been online n tournament enabled before. What version of golf is it? It has to be the normal version of team challenge as that's all Boost has working so far. All access pass or challenge machines will not work.
TheSherman8or
« Reply #998 on: January 27, 2015, 06:53:24 am »
Its team challenge and yeah I had everything working by following boosts instructions a couple days ago. I re-installed the software to  try and see if that would fix my gameface debugger error. I figured out that upgrading to SP3 fixed the error but when I went to force call the re-enable online was the only option I had in connect/register section and now it keeps failing and I also ran the patcher again.
yukonblaze
« Reply #999 on: January 27, 2015, 01:05:50 pm »
Sherman
I have found that when there is an error, just reinstall the game again.  Updates can cause bigger issues on the game.
*Question for Everyone
Who here is using an everlast computer in their PGA vs origianl computer.  The reason I ask is I have spare of each and just trying to decide which to keep.  I have upgraded the cpu in each to the same specs but just wasnt sure if it made a difference.
Jason
