Author Topic: How to fix this?  (Read 3584 times)
deathterrapin
  • Last login:Yesterday at 07:07:50 am
How to fix this?
« on: November 24, 2012, 07:29:48 am »
I managed to slip with the router when I was doing my t-molding slots, and I've taken a bit out of the edge (see photos attached). Its too deep to just sand it out, but I think it might be too shallow to get filler in nicely.
I'm thinking maybe I should rout out the area down evenly to a couple of mil to give me something to put filler in. Does that sound like a good idea? Has anyone got any other suggestions?
jammin0
Re: How to fix this?
« Reply #1 on: November 24, 2012, 10:26:41 am »
I would sand that down?  How's the other side look?  Clamp them together so that you're more likely to get a straight edge when you're finished.  By no means am I a pro though, that's just what I would do.
deathterrapin
« Reply #2 on: November 24, 2012, 11:12:32 am »
Sorry, when I said  'edge' that was misleading. I meant the gouge is on the face, right at the edge. If i just sand it down then there will be a low spot right up against the t-molding. Which will look like arse.
brad808
« Reply #3 on: November 24, 2012, 11:23:07 am »
I have no idea where you are in your project but can you just swap the sides and make the mistake on the inside? Or do you have other cuts that make 1 left side and 1 right side?
matt4949
« Reply #4 on: November 24, 2012, 11:25:49 am »
bondo and sandpaper easy peasy
deathterrapin
« Reply #5 on: November 24, 2012, 12:08:01 pm »
I can't swap the sides around unfortunately, I've already got bits glued to the inside.
I decided to try filling it without cutting any more out, I'm leaving it to set now and I'll see how its stuck in the morning.
I'm using glue+sawdust as filler as I don't have any proper stuff to hand (and I'm a cheap bastard :D) If it doesn't work I can always cut it out and try with something better.
deathterrapin
« Reply #6 on: November 25, 2012, 08:04:26 am »
Panic over! That worked far better than I expected.
Fursphere
  • Last login:Yesterday at 08:30:46 am
« Reply #7 on: January 20, 2013, 12:38:53 pm »
This.
It'll take time, but once it dries, block sand it out and you'll never know it was there after paint.
« Reply #8 on: January 23, 2013, 09:08:03 am »
That was so small it probably would have been invisible once the thing is assembled and painted anyway.
« Reply #9 on: January 23, 2013, 01:05:16 pm »
Start over, it's the end of the world!
or just use a bit of bondo and sand paper.  At that depth you can probably just go buy a can of spray primer putty (primary mixed with bondo in a rattle can = amazing) and top it with that.
paigeoliver
  • Awesome face!
« Reply #10 on: January 26, 2013, 09:05:44 pm »
Yeah, that is teeny, I am lucky if I can route a whole cab for t-molding without somehow bringing the groove right out of the side of the wood at some point, somehow.
« Reply #11 on: January 27, 2013, 06:41:16 pm »
Paigeoliver:  One Cabinet Under A Groove
