Author Topic: Micro Tron arcade WIP  (Read 19905 times)
threedprof
  • Last login:April 21, 2016, 05:57:44 pm
« on: November 11, 2012, 06:13:06 pm »
Hey everyone, I'm new to the community but i've already built two full scale arcade machines.  Time to put the shrinking ray to my fave game of all time...Tron!  Inspired by Le Chuck's fantastic work, this thread will follow my progress, however, i don't have a full fledged plan so updates will be very slow.  The goal is to recreate a perfectly scaled...Functional...arcade, as possible.  I started off with a used PSP and got to work on adding the Mame4all emu and FINALLY got Tron to run but, wow!  It's slooooooow and there doesn't appear to be an option to correct the screen orientation  :-\
« Last Edit: November 11, 2012, 06:32:58 pm by threedprof »
Arcade projects
threedprof
Re: Micro Tron arcade WIP
« Reply #1 on: November 11, 2012, 06:19:48 pm »
Here's a rough 3D mockup
After the mockup is complete I'll model the control handle to scale and send it over to Shapeways.com to have it 3D printed  along with any other miscellaneous parts i might need.
i'll post pics when it's complete
Arcade projects
threedprof
« Reply #2 on: November 11, 2012, 06:28:22 pm »
for the sideart I ordered:
http://www.laserinkjetlabels.com/eshop/10Expand.asp?ProductCode=8511-0-CLEAR25
to use as little printer ink as possible.  Tried finding some UV reactive inks but it looks like i'll have to paint that on the sideart sticker myself.  In the meantime i've downloaded as much artwork as I can and will be cleaning up any, if necessary
« Last Edit: November 30, 2012, 05:50:54 pm by threedprof »
Arcade projects
  • Last login:Today at 01:40:55 pm
« Reply #3 on: November 11, 2012, 06:42:19 pm »
Welcome aboard, Threedprof.
How "micro" are you thinking about making this?
Seems like the sticking point will be the triggerstick.  Maybe using a Grayhill -04A base with an upper handle printed by shapeways.
If you can't find the plain 04A base, the keycap version 04A-K01 has a removable cap.
The battop version 04A-B01 is non-removable.
threedprof
« Reply #4 on: November 11, 2012, 07:57:41 pm »
Wow!! You must've read my mind. I was just posting for ideas on controller bases! I've finished modeling the handle and can make it available on shapeways for anyone looking to do the same.  The question now is how to get a tiny trigger into the handle.
Thank you for the welcome and I'm following in Le Chucks footsteps. It'll be 1/6 scale. It's 12" tall.
Thanks again for the callout!
« Last Edit: November 11, 2012, 08:18:37 pm by threedprof »
Arcade projects
« Reply #5 on: November 11, 2012, 08:59:19 pm »
I think the answer is here in Le Chuck's SW Micro build thread.
Radio Shack P/N 275-0008
threedprof
« Reply #6 on: November 11, 2012, 09:38:55 pm »
Awesome! I'll have to get some ordered to check dimensions. May have to alter the stick design to accommodate it.  Right now the joystick is roughly 2" tall.  I'll go out and buy a few of those triggers tomorrow, since they stock them at my local 'Shack and i'll mod the stick accordingly.  Should take more than a half day to get it over to Shapeways for purchasing.  everything in the 3D model is to proportionate so WYSIWYG.
You've been a huge help!
« Last Edit: November 11, 2012, 10:15:49 pm by threedprof »
Arcade projects
« Reply #7 on: November 11, 2012, 11:22:57 pm »
Since there's no way to drill out the middle of the joystick shaft, how do you plan to route the switch wires for the trigger?
Also forgot to mention this method for attaching wires to the joystick without soldering.
threedprof
« Reply #8 on: November 11, 2012, 11:33:10 pm »
the joystick will be hollow and i'll have to figure out a fastening system.  I'll know more once i pick up the switches tomorrow.  I'd like to figure out the screen also.  The PSP Mame4all doesn't seem to be cutting it.  is there another Emu that will allowing for screen rotation?
Arcade projects
« Reply #9 on: November 12, 2012, 12:18:45 am »
To clarify, I meant to state that if you use the grayhill 04a joystick base (green in pic #2) you won't be able to drill through the center to route the wires like the original Tron stick -- center pin = ground.
I also meant to ask how you intended to get the wires from the handle (light blue) to the underside of the CP.
threedprof
« Reply #10 on: November 12, 2012, 12:36:33 am »
ooooooo I see what you mean now.  Thanks for clarifying.  My initial thought is to route it out from the bottom of the joystick and out through the CP opening for the joystick.  I'll likely come across a more elegant solution as the project moves forward.
Arcade projects
« Reply #11 on: November 12, 2012, 09:58:19 am »
Welcome!  Nice to see another tackling the micro problem set.  I've learned something from every one that has been posted.
I think you may run into problems with the PSP and scale because the screen is not a 4:3 and that system doesn't lend itself to TRON very well but don't let that stop you.  Mine is stalled currently because of work, other projects, and then control compatibility.  I'm pretty sold on converting both the TRON and the Gauntlet builds from GP Caanoos to R-Pi builds.  I'll end up corded (acceptable) but should be able to keep the same ratios. Can't wait to see what you do with this and I'm interested in seeing what you've come up with for the handle.
threedprof
« Reply #12 on: November 12, 2012, 12:54:03 pm »
Thanks, Le Chuck!  It's so cool to be surrounded by like-minded individuals.  Hopefully, i'll have plenty of positive info/stuff to add to the community.
Went out and bought those micro switches..these suckers are miniscule!  now with calipers in hand i'm going to get them shoehorned into the joystick.  Should have a 3D result by EOD.
Arcade projects
threedprof
« Reply #13 on: November 12, 2012, 05:59:59 pm »
Arcade projects
« Reply #14 on: November 12, 2012, 07:39:08 pm »
http://www.robotshop.com/adafruit-mini-joystick-sensor.html?utm_source=google&utm_medium=base&utm_campaign=jos
thoughts on this as a potential joystick?
It's analogue not digital.  What is your scale?  Mine is a 1:6 and the one that Scott linked to is what I'm using.  There are larger ones available that still give digital 4 way or 8 way outputs depending on your scale.  I'd go with one of those.  Hacking a PSP means that your direction buttons will probably need to be hacked to the buttons and the spinner will need to be hacked to the analogue control stick.  Fire is hacked to a shoulder button I'd think.
threedprof
« Reply #15 on: November 12, 2012, 08:07:22 pm »
Good to know before I pulled the trigger on it. My build is following yours pretty closely. The height of the cab will be 12" tall
(2) Grayhill micro joysticks have been ordered. Never know which can ill start on next :D
« Last Edit: November 12, 2012, 08:25:41 pm by threedprof »
Arcade projects
« Reply #16 on: November 12, 2012, 08:23:02 pm »
About the only other "joystick" I've seen that might be useful at this scale is this:
Thumbstick from arcadeshop.de
threedprof
« Reply #17 on: November 13, 2012, 06:25:40 am »
Can't...think...anymoooooozzzzzZZzZZzz.  3:30 AM...time to call it a night
« Last Edit: November 13, 2012, 06:51:05 am by threedprof »
Arcade projects
« Reply #18 on: November 13, 2012, 08:21:34 am »
 Looking good. I'd settle on a joystick and get one before having the handles printed. The Greyhill is a single piece handle to sensor plate unit and has a girthier shaft so you'd need to account for it. You may also want to cheat that switch area up a bit more in the housing and look at an exterior channel for the wires since most joys (Greyhill for sure) aren't center thread able. All that said I totally want one of your handles.  :applaud:
threedprof
« Reply #19 on: November 13, 2012, 12:11:36 pm »
Thanks for the input, Le chuck. Ya it's going to take some experimenting when the Greyhill arrives. For now I'm working with the measurements that were in their .PDF. Either way there's more adjustments that I want to do before getting a test piece printed.  I'm also making other scale items like a coin door, shroud, and spinner top. If you can think of other parts let me know be I can get started on the modeling.
« Last Edit: November 13, 2012, 12:23:24 pm by threedprof »
Arcade projects
threedprof
« Reply #20 on: November 13, 2012, 10:39:09 pm »
Oh the agony of waiting for parts to arrive  :hissy:
on to productive things like...Doing a little uprezzing of the side artwork.  Worth the trouble? I think so  :dizzy:
« Last Edit: November 14, 2012, 02:21:35 am by threedprof »
Arcade projects
threedprof
« Reply #21 on: November 14, 2012, 10:13:57 pm »
added more to the MicroCade Tron project.  Fleshing out the dimensions and massaging the sticker sheet to match the proportions...time consuming (Good thing I have a braindead job!).  Even found a better solution to my tron emu problem!  seems iMame, on the iPods, runs tron perfectly! and even better the screen is close to 1:1.  Not only that but i may have even found a solution to the spinner issue, via bluetooth controls  :cheers:  More on that later...for now here's some new pixels for your eyeballs
Arcade projects
« Reply #22 on: November 15, 2012, 09:27:39 am »
Looking forward to seeing this move forward.  Good stuff.   :)
Arturius
  • Last login:February 13, 2016, 08:25:23 am
« Reply #23 on: November 15, 2012, 10:37:30 am »
That looks awesome, will be following this to see how it turns out :)
Getting there, just rather slowly...
threedprof
« Reply #24 on: November 15, 2012, 06:24:41 pm »
Looks like the controller is Hollow and I can drill through it to get the trigger wiring threaded through.  Wasn't tough to take apart and reassemble.
Arcade projects
« Reply #25 on: November 15, 2012, 06:43:12 pm »
I looked at the same deal and decided to route the wiring down the front and not bother threading but if you have a small enough gauge it should work.  I look forward to seeing how it comes out.
threedprof
« Reply #26 on: November 17, 2012, 08:43:38 am »
In thinking about keeping the wires exposed I worry about potential wire breakage from work hardening. I'll have to find a very thin gauge drill bit as I managed to score som 30 ga jacketed wire, from radio shack.
Arcade projects
threedprof
« Reply #27 on: November 18, 2012, 07:16:20 am »
Finished modeling the shroud.  Sending it over to Shapeways.com to get it verified.  The other stainless steel fasteners came in as well as allen wrenches.
WOW! The cost of the shroud is going to run me almost the same price as the real 1:1 shroud...how authentic do i want to be?
« Last Edit: November 18, 2012, 08:20:00 am by threedprof »
Arcade projects
threedprof
« Reply #28 on: November 19, 2012, 06:48:22 am »
And it begins.
Arcade projects
CoryBee
  • Bopity Boopy
« Reply #29 on: November 19, 2012, 07:46:28 am »
threedprof
« Reply #30 on: November 19, 2012, 06:28:41 pm »
finally done with the joystick model and it now being printed by Shapeways.com  They were the most reasonable in price.  I'm going to hold off on printing the shroud since it's so expensive.
Added:
  • Locator pins
  • Capture pins for the SPST radioshack micro trigger switch
  • Anti-Rotation lug pattern for the Grayhill joystick shaft
Might hollow out the top incase someone decides to make a Discs of Tron micro and needs a deflector button
« Last Edit: November 19, 2012, 06:35:07 pm by threedprof »
Arcade projects
Jigenjuke
« Reply #31 on: November 19, 2012, 08:51:44 pm »
Looking great Threedprof!  It looks to me like the shroud wouldn't be so difficult to build.  You could use the same stuff as Bender did.  Model maker's styrene sheets will make this look professional enough.
Jigenjuke
threedprof
« Reply #32 on: November 19, 2012, 09:06:39 pm »
Nice idea on the styrene.  I might consider that.  I'm going to try polycarbonate and shape it with some mild heat, too.  I will definitely lose some finer details either way.
Arcade projects
« Reply #33 on: November 19, 2012, 09:12:33 pm »
I made my shroud out of mdf.  It's just simple geometric shapes so you shouldn't have too much trouble getting it done in whatever material you choose.  One measurement I need is the back window in the shroud, I still need to get that cut if you have it.  I also need the art that goes around the back window and the art of the black light cover if you have those.
How much is the handle running you if you don't mind sharing?
threedprof
« Reply #34 on: November 19, 2012, 09:24:45 pm »
Ya, I agree that it could be carved and done with broader strokes, as it were.  Having scrutinized it pretty closely there's quite a bit of detail between the grill work and gussets.  the back window also consists of some pretty interesting angles (It's not flat across)  I wanted to capture those details as closely as I could.  Printing one copy and maybe making a mold out of it might be the better way.  In fact, i'll just go ahead and order it.
The Joysticks are much more reasonable at $6 and change a piece.
Arcade projects
threedprof
« Reply #35 on: November 20, 2012, 02:20:02 am »
Wow!! Vinyl is totally the way to go instead of paint! This is awesome
Arcade projects
threedprof
« Reply #36 on: November 22, 2012, 07:10:40 am »
Control Panel:
Routed out a pocket for the joystick base to fit in.  A little post router carving was necessary to get a tight fit.  Still thinking of a way to capture the joystick and hold it in place.  Initial thoughts are some kind of strapping, since I want to make the cabinet serviceable.
Arcade projects
threedprof
« Reply #37 on: November 22, 2012, 07:12:52 am »
Parts layout
Arcade projects
threedprof
« Reply #38 on: November 22, 2012, 07:40:09 pm »
Assembly has started. My first regret is using flathead wood screws. Found some allen head replacements and will swap them once they arrive.  If I build more of these I'd like to figure out a better way to engineer the cab for convenient maintenance.
I'm still researching the best way to implement the controls, either a scavenged WiiMote or an radionics Bluetooth interface.  Using the iPod turned out to be a good call, so far due to their speed and compact size (although it feels a bit like cheating!). It'd be awesome if there were a way to dump the entire game into a small microprocessor, now that the tech is available.
« Last Edit: November 23, 2012, 01:40:30 am by threedprof »
Arcade projects
Jigenjuke
« Reply #39 on: November 22, 2012, 08:02:07 pm »
Hey there ThreedProf, if you wanna keep the cost of the unit down and maybe order the shroud anyway, don't go out and buy a wii controller in town.  Order it from DealsExtreme
http://dx.com/c/video-games-699/wii-601/remote-controllers-619
They are pretty cheap, but shipping takes awhile.  If you order it now while you are in the midst of building it would probably make it to you by the time you need it.
Looking good!
Jigenjuke
