Author Topic: bug report  (Read 2271 times)
Sorex
  • Last login:August 19, 2015, 10:46:59 am
bug report
« on: November 11, 2012, 01:01:00 pm »
Hello,
I'm currently trying out Mala as front-end, all looks fine.
But when playing around with lists I bumped onto a bug  which crashes Mala :angry:
Here's how to force the crash:
right click
go to options
go to game lists
press new
enter something like "Cards/Board/Mahjong"
press ok and it will crash
it seems that it tries to use the "/" slash in the filename. that should be replace with a space, underscore or anything else that is usefull to avoid the crash.
Edit:
Maybe another bug...
When I select to only show the "parent" it still shows all these xxx (US) xxx (JAPAN) versions instead of only listing the default working set.
odd thing is that the counter dropped from 77xx to 6984 tho, so I'm not sure what got filtered out.
not really an issue when moving item to other lists when they are nicely grouped but some appear in the list under "A*"
but with a completely different name, to name one "ASO - Armoured Scrum Object" I've seen it passing by before but with a different title.
« Last Edit: November 11, 2012, 02:02:14 pm by Sorex »
