Author Topic: question about mame arcade  (Read 3964 times)
crtrrss
« on: November 06, 2012, 08:55:30 pm »
Hi! I bought a neo geo cab recently... everything works but im going to build my own control panel and sell all of the parts except the speakers(maybe) and the monitor. Since im making my own cp, i cant use a jamma harness to wire everything and from that, as far as i can tell, i cant use a jpac to connect it all to the computer, so what should i use?
Re: question about mame arcade
« Reply #1 on: November 06, 2012, 08:57:57 pm »
If it has a single slot pcb I'd be interested in buying it off of you.
crtrrss
« Reply #2 on: November 06, 2012, 08:58:32 pm »
its a single and im interested in selling it
« Reply #3 on: November 06, 2012, 08:58:57 pm »
PM coming your way...
crtrrss
« Reply #4 on: November 06, 2012, 09:40:46 pm »
ok but can any1 answer my original question?
crtrrss
« Reply #5 on: November 06, 2012, 10:06:39 pm »
i dont think that nephasth still wants the parts so if u do, im selling! im selling everything as a big lot, so if u just want one part, then just go on ebay and find it.
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« Reply #6 on: November 06, 2012, 10:23:59 pm »
Your question is kind of confusing.
There should be no reason why you couldn't use a j-pac
and jamma harness. In fact, that set up would probably
be optimal for your particular application.
Trample the weak, hurdle the dead
« Reply #7 on: November 06, 2012, 10:27:06 pm »
Wrong.
crtrrss
« Reply #8 on: November 06, 2012, 10:28:19 pm »
what i mean is that i wont have a jamma harness anymore once im done selling everything. could i still use the monitor and speakers without the harness?
  • Online Online
  • Last login:Today at 07:02:00 pm
« Reply #9 on: November 06, 2012, 11:18:49 pm »
Just sell the board and keep everything else. You can use the Jamma harness with a J-PAC. It'll save you a lot of money.
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #10 on: November 06, 2012, 11:22:26 pm »
It is going to be a pain wiring the monitor up without using a JPac which makes it pretty easy.  Jamma harnesses are cheap, so you could just use the harness for the monitor if needed And run everything else other ways.  It doesn't make much sense to sell everything as one lot especially if you are getting rid of the power supplies.  You would more likely make more parting it out.  Your call though.
crtrrss
« Reply #11 on: November 06, 2012, 11:24:08 pm »
is there a way to directly wire an arcade monitor to a video card?
  • Online Online
« Reply #12 on: November 06, 2012, 11:41:00 pm »
+1
Most people only need a part or so.
TGov
« Reply #13 on: November 06, 2012, 11:59:41 pm »
I am sure there is a way to do it but if you don't know exactly what you are doing and accidentally send a 31khz signal from your pc to the monitor it could ruin it.  The jpac prevents that signal from reaching your monitor if you do by accident do that, and it is easy to make that mistake.  It might not ruin anything but I wouldn't take that chance with a working arcade monitor.
matsadona
« Reply #14 on: November 07, 2012, 02:59:29 am »
I second that keeping the jamma harness as the best option. Then you can always swap between a game pcb or MAME computer (with the JPAC) within minutes.
Please note that it usually isn’t 100% jamma standard in NeoGeo games (stereo sound and some other minor deviations), but still I recommend that you keep all wiring. The parts you remove could be sold anyway.
TGov
« Reply #15 on: November 07, 2012, 07:34:23 am »
If it is a single slot MVS then it is fully Jamma compatible, the multi board MVS were a bit different.
crtrrss
« Reply #16 on: November 07, 2012, 05:06:55 pm »
so would it be the best idea to sell off everything and buy a new harness and a jpac when making my new control panel?
crtrrss
« Reply #17 on: November 07, 2012, 06:03:48 pm »
and nephasth doesnt want the parts so any1 who want to buy everything together, PM me
« Reply #18 on: November 07, 2012, 06:10:39 pm »
Still wrong. I'm interested in the PCB (that has yet to be confirmed fully working), but you keep trying to force the other stuff in with the sale. As others have said, your best bet is to sell your parts individually. Nobody is looking for a Neo Geo PCB along with a converted Super High Impact CP...
paigeoliver
  • Awesome face!
« Reply #19 on: November 07, 2012, 09:12:17 pm »
Honestly that panel isn't worth the cost of shipping it (it will cost at least $20-$25 to ship). No one will need the blank panel itself (other than you, you could still use it) and if the controls were still in decent shape then you would likely be reusing them yourself. When I have sold big heavy panels like that in the past the buyers have usually requested I keep the physical panel and just send the controls in order to keep the shipping down.
Your Neo Geo motherboard, whatever cartridge you have and the marquee are the only things of any REAL value that you have there.
You can buy a new Jamma harness for $10, which makes the (likely) hacked up wiring out of yours maybe worth $2. Same thing with your power supply.
crtrrss
« Reply #20 on: November 07, 2012, 10:57:22 pm »
well Nephasth bought the pcb. all other parts are still for sale. also the marquee and the control panel have samurai shodown iii stuff in them.
paigeoliver
  • Awesome face!
« Reply #21 on: November 08, 2012, 11:58:24 am »
Was there a cartridge? Do you still have it?
« Reply #22 on: November 08, 2012, 01:28:05 pm »
No cartridge.
