Author Topic: MAME - 4-way emulation  (Read 17928 times)
swindmiller
  • Last login:July 31, 2014, 08:23:51 pm
« on: October 12, 2012, 01:38:45 pm »
I am new to all of this but understand the difference between 4-way and 8-way. My tankstick lets me switch between the 2 but is a pain. I just read on their site: Note that newer versions of MAME seem to have a built-in software 4-way emulation automatically used for 4-way games.
Does anyone know what version this came out on and how it works? Do I have to set something in the options?
Thanks,
molton
  • Last login:April 05, 2018, 10:46:57 pm
Re: MAME - 4-way emulation
« Reply #1 on: October 12, 2012, 03:57:33 pm »
Thats just more pretty sounding bullsh*t from the folks at X-arcade, lol that's the first time I ever heard of anybody saying a piece of software seems  to have a feature it in fact does not have.
    • GroovyGameGear.com
« Reply #2 on: October 12, 2012, 04:05:35 pm »
They are probably getting confused by the mapping function available for analog and 49-way sticks.  Won't do a thing for the controls on those panels. :)
the_gamer
  • Last login:September 02, 2020, 03:44:06 pm
« Reply #3 on: October 13, 2012, 11:33:47 am »
I don't think this will ever be implemented. Mame is not about playing the games in the most comfortable way. Being able to play the games is only sideeffect for the developers. It is about emulating the hardware.
paigeoliver
  • Awesome face!
« Reply #4 on: October 13, 2012, 04:04:09 pm »
An emulation driver isn't going to be able to decide at any given moment which direction would be best to send the game when you send it a diagonal. Something like that would have to be in the original software.
That is why Nes Pac-Man and Atari 2600 Pac-Man work with 8-way controls is because they were written with them in mind.
The whole bit about being able to play the games being a side effect and the mame project being about documentation is a retcon. You can still go back and read all of nicola's original usenet posts when he started mame, it was all about playing the games. The whole documentation thing was added in years later.
degenatrons
« Reply #5 on: October 15, 2012, 09:42:47 am »
I've recently implemented virtual 4-way restriction on the KADE encoder (in the devices firmware).  I'm one of the developers on that project and am happy to run through with you how it was done.
To get accurate 4-way restriction in firmware was not as easy as I had first expected.
paigeoliver - i appreciate your reservations on this one.  I will explain how it is done and feel free to comment.
To do it.  I take the current position and work out the most probable indended direction based on the movement.
e.g.
If you have stick in "up" position.
   If joystick move to down/right:  It is most likely that you intended to move down.  The stick has travelled further than the mid-point.
        If joystick move to up/right: It is most likely that you intend to move right because you are already "up" and a direction change was made.
The direction logic changes depending on the current direction.  I check both directions that make up the diagonal and take the first engaged direction i find,  using this logic:
If Up,  check: Down, Left then Right
If Down, check: Up, Left then Right
If Left, check: Right, Up then Down
If Right, check: Left, Up then Down
*Note that the order of 2nd and 3rd checks is not relevant as both directions cannot be engaged simultaneously.
I have this working in my arcade cabinet and it plays really really well on 4-way games.  It gives a significant improvement to my play on Rally-X and Ms Pacman and definitely has a better feel.
Feedback has been good from our beta-testers.
The KADE device will support MAME and various consoles and will be out soon.
A little background information here - http://forum.arcadecontrols.com/index.php/topic,122023.msg1307414.html#msg1307414.  More info soon.
  • Last login:Yesterday at 12:24:02 am
« Reply #6 on: October 15, 2012, 10:26:33 am »
Very cool. You've piqued my interest!
paigeoliver
  • Awesome face!
« Reply #7 on: October 15, 2012, 11:01:57 am »
Certainly that sort of logic is a huge improvement over just tossing an 8-way at the game but it still isn't a real replacement for having the game software handle the diagonals directly. If the game software was handling it then it could be much more refined than just using a basic set of rules (it would certainly be situational).
Of course the other problem is that a lot of 4-way games are difficult to play even with a 4-way stick if they don't have a diamond shaped restriction pattern.
e.g.
swindmiller
« Reply #8 on: October 15, 2012, 12:09:13 pm »
Thanks for all of the replies.
Can I replace the sticks with ones that are easier to switch to 4 way and back? Are there josticks that can switch with the flip of a switch mounted on the outside of the CP?
Thanks,
sharpfork
    • KADE
« Reply #9 on: October 15, 2012, 12:39:18 pm »
Ultimarc has a few:
Mag-Stik - http://www.ultimarc.com/controls.html
servostik - powered http://www.ultimarc.com/servostik.html
GGG has one:
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=195
they have a below CP changing one too:
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=383
There might be others out there.
I agree.
I tested the beta KADE against my JLW's in 4 way mode and I have to say that the emulated 4way on the KADE isn't as good as physically restricted 4 way but is much better than a standard 8 way.  This option is intended for that middle ground and I think it succeeds: improved 4 way gameplay for folks who only have 8 way sticks.
« Reply #10 on: October 15, 2012, 01:22:36 pm »
In all actuality, you still haven't.
Without knowing what is happening in the game, and analyzing it,  or having more information available from the stick itself (i.e. more than 4 pieces of information), there is no way to make a determination of what is the "probable intended" direction with an accuracy level higher than a "coin toss".  As this is pretty much the accuracy one gets by default, the actual net gain is zero.
e.g.
This sounds good in theory, but in practice, it doesn't deliver.  Picture a common situation where the player intends to move directly from the vertical to right, and goes too far, thus hitting the down-right diagonal.  Your assumption with the above logic will be that he intended to move down, which will screw the player up royally.
Again, this really doesn't deliver.  Another common issue with an 8-way stick is "user drift".  In the heat of the action, they may be vertical, but very close to actuating either the right or left switch.  A slight horizontal movement from their current position to either one of the horizontals, thereby making the diagonal, will then throw them to the horizontal cardinal of that diagonal, which is not the "probable intention" of the player when this scenario occurs.
Another issue is "extended roll through".  If the user rolls from the vertical to right, and goes a little too far, the logic above will assume the desire to then go down, when in fact this isn't the case.
One more issue with this type of approach is that when you get it wrong, the following assumption tends to fall apart as well.
The same has been claimed from at least one other individual who basically was doing the same thing, but it proves in use to be not much better, if any at all, from the default condition.  I've experimented with the same algorithms in the past and the result was not a "significant improvement".  There is a bit of a placebo effect when testing something like this, which makes the player more aware of what they are doing when they know they are testing the hardware, and it sometimes results in a somewhat better performance.  However, once this wears off, and the player actually focuses on playing the games, they become less concerned about the controls and run into the same old problems.  The proper way to test the efficacy of something like this is a dual-blind test, with a number of different individuals, and comparing performance.  I think you will find, based on my experience,  that you are simply trading one set of problems for a different, but equal set.  Without physical restriction, or more information available from the control itself, there is no reliable way to determine the player's probable intentions.
« Last Edit: October 15, 2012, 01:24:11 pm by RandyT »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #11 on: October 15, 2012, 01:34:27 pm »
And let's not forget Donkey Kong, which is best with a clover-leaf restrictor. Fortunately for me, I'm not a huge DK fan, so I don't care.
Was thinking the same thing when I read his description.
Finally, for the OP, there are a sizable number of folks who don't mind just using an 8-way (I am not one of them, but they do exist).
Working: Not Enough
Projects: Too Many
Progress: None
LeedsFan
« Reply #12 on: October 15, 2012, 01:56:42 pm »
I think people try too hard with this issue. It's like they are trying to reinvent the wheel. For simple games that used 4-way or 8-way digital sticks the best way is to implement the correct restrictor. Whether it's done manually (as the OP says it can be a pain) or mechanically (like with Ultimarc's Versa stick) is up to you.  I actually built a panel with 2x sticks one in permanent 8-way and the other in 4-way. You just flicked a switch to select the one you wanted to use depending on the game. Not ideal and looks a little clunky, but it does work for those straight forward digital joystick games. I wouldn't go down this route now, I'd use something like the Versa Stik. No matter what software or firmware you're running if you play a classic 4-way game with an 8-way stick it's just not gonna feel right.
degenatrons
« Reply #13 on: October 15, 2012, 02:31:21 pm »
e.g.
This is all good feedback thanks.
This is simulated 4-way restriction so I do have to make assumptions on the intended movement to make this feature possible in software.
I think it works well,  and hopefully not because of placebo effect.  I am quite thorough in my testing and reasoning.
I do agree that there is no substitute for physical restriction.
This will be an optional feature when the KADE encoder is released.  The device is being developed for the community,  so it is important that we get these features right and hence why I am being open about the internal workings of virtual 4-way.
Looking forward to getting feedback from gamers on this one.  I am sure that the results will be more than slight improvement.  I don't want you to write this off just yet.
« Reply #14 on: October 16, 2012, 01:15:33 pm »
And, this is the root of the problem in this scenario.   The very first time you make any assumption, i.e. not a decision based on very high probability, which is impossible given the data set,  you are "flipping a coin".    Sometimes you will get it right, and sometimes you won't.  The times you don't, you simply create problems for the player that may not have existed prior.
The input handling in MAME has to make decisions about how to handle diagonals in games where 4-ways are expected, and it does.  If it didn't, when a diagonal is sent, the player movement simply would not register.  The unfortunate reality when using a 4-switch joystick is that there simply is not enough data present to make reliable assumptions, and whether you just use the default method in the app, or trade that for different set of problems, the end result will be the same.
Players who want to use an 8-way for 4-way games will fare much better with an 8-way stick which uses bladed micros, or leaf switches, which can be adjusted so that the diagonals are more difficult to hit, but can be if they are really intended to be.  This approach isn't perfect either, but a "one-size-fits-all" solution rarely is.
« Last Edit: October 20, 2012, 11:46:10 am by RandyT »
paigeoliver
  • Awesome face!
« Reply #15 on: October 16, 2012, 06:48:09 pm »
If you really want both with the same stick then buy some of Randy's Omni-Stik Prodigy sticks. Your controls are not the place the cheap out on your cabinet.
rablack97
« Reply #16 on: October 16, 2012, 11:49:18 pm »
Good grief the man said "virtual" and "accurate" not "perfected" and "spot on".
We are talking up, down, left, right....
There are tons of other things that affect 4 way gameplay as well, the switch, the throw, the length of the shaft, bat top, ball top, angle of CP, and the list goes on.
Every player is different and the whole reason we do this is for a hobby, customization and the enjoyment of the build.
I'll be damned if I haven't kicked a ms. pacman game a few times cause she went right instead of up, and thats about as 4 way as you can get. So restricted or virtual, bottom line is, if you can get it go up, right, left, or down at least 98% or so of the time, then it's gravy.
Both are good in their own unique way, neither is or ever will be perfect.  Preference usually outweighs perfection anyway....
« Last Edit: October 16, 2012, 11:59:59 pm by rablack97 »
« Reply #17 on: October 17, 2012, 01:11:17 am »
"Virtual" is something which can be achieved with a 49-way or pure analog stick.  There is over 12 times (on the low end) more data being put out by these joysticks to base the decision upon.  If you think "accurate" can be achieved with a non-restricted 8-way, then you should take the time to read and understand what I, and many others on this forum have written on the subject over the last 10 years.  The gist of it, I included in this thread.  This isn't a new idea, and it has never worked.  The math and physics of the situation stand firmly in it's way.
I agree.  The point is, this won't do that for you.  You might be able to train yourself to play within the confines of the algorithm, but if you can do that, then you can train yourself to play within the existing one in MAME.  The whole point is that it's no fun trying to play a 4-way game, while concentrating on precision handling of the control so as not to make errors.  The games are difficult enough without adding that to the equation.
Are you are stating that 4-way restricted joysticks on a 4-way game have similar, but different drawbacks as the type of scheme being discussed?  I think I would like to hear how you believe this to be so.  Also, if there are flaws in the logic I used above to demonstrate the shortcomings of the approach, please be so kind as to share them as well.
« Last Edit: October 17, 2012, 01:15:14 am by RandyT »
molton
« Reply #18 on: October 17, 2012, 07:18:01 am »
I have an idea for software 4-way emulation, software restriction, it doesn't register 2 switches at once, if you went straight to diagonal from the center it would not register a move until you further adjusted for either direction you actually wanted and it would stay in that direction until another single cardinal direction switch is pressed (or all switches released of course), so if you drift back into diagonal it wont affect the direction.  If you were in the up position, it won't register up right or up left, but registers left or right as soon as the up switch is released in an up left or up right scenario. This could be done with a software layer between mame and the control i do believe.  still not true 4-way, but 4-way emulation, maybe.  I think it would work.
« Last Edit: October 17, 2012, 07:27:56 am by molton »
« Reply #19 on: October 17, 2012, 08:32:38 am »
IIRC, this is what is known as "sticky mode".  (note the date of that post)  Some like, some don't.  If it's no longer available as an option in MAME, I believe it can be replicated through the standard input handling logic.
« Last Edit: October 17, 2012, 08:43:04 am by RandyT »
rablack97
« Reply #20 on: October 17, 2012, 04:49:10 pm »
Randy,
I had a whole writeup arguing my point, but the forum timed me out before i could post, and i lost it all.
In short, I agree with your terminology, and your expertise does supercede mine in this area.
I think Degenetron was after a comparable way to play 4/8 way w/o buying an expensive stick and being able to do it with a shifted on the fly method.  It also keeps you from popping the CP hood to twist  screws for the restrictor plate.  To some this is a convenience.
There is no right or wrong here, and to your point 4 way has not been and never will be perfected.  So we will agree to disagree.
« Last Edit: October 17, 2012, 04:53:42 pm by rablack97 »
CheffoJeffo
« Reply #21 on: October 17, 2012, 06:08:03 pm »
I think that the point that is often missed in these discussions is that people who care about 4-way play won't be satisfied with those "comparable" methods in any event.
There will be some who don't mind solutions like digital restriction (e.g. those expensive sticks) and they won't want those "comparable" methods.
The people who would be satisfied with "comparable" solutions to what Degenetron suggests aren't going to be people who care about 4-way functionality in the first place, so there is little point from a market perspective.
Having said that, it does make for a cool little experiment.
Working: Not Enough
Projects: Too Many
Progress: None
rablack97
« Reply #22 on: October 17, 2012, 06:52:07 pm »
Right, which is why I said this stems from personal preference.
The ones who care will splurge on perfection, which Randy has stated isn't perfected yet..
So until somebody perfects ultra 4 way algorithms, i'll settle for the  convenient/comparable way to switch back and forth between 8/4 way.
All i'm saying is it plays really well, but its all hearsay till you try it yourself....I do care if MS. Pac man goes the wrong direction. :)
Cynicaster
« Reply #23 on: October 18, 2012, 01:23:35 pm »
The problem with trying to parse the player’s intentions with Boolean logic is that it only needs to be wrong once to suck.  My suggestion: give up the dream, implement a hardware solution, and enjoy a game of Frogger with something that actually works.
paigeoliver
  • Awesome face!
« Reply #24 on: October 18, 2012, 01:52:55 pm »
Yep, getting it wrong one time will often mean a lost player in many titles. If I was say playing Pac-Man the logic would have to guess my intentions at least 80 or 90 times a board. If it gets it wrong even once then my pattern is ruined, even if I am playing freestyle it can still ruin the screen by sending me right towards the ghosts or making me eat a power pellet before all the ghosts are in position.
« Reply #25 on: October 18, 2012, 03:43:04 pm »
When I need to start repeating my earlier statements, either what I am trying to put across isn't getting through, or it's time for me to give up trying.
4-way "perfection" can be defined in only one way; and that is when the stick follows the intention of the player every time.  Not half the time, not three quarters, not even nine tenths.  A skilled player can compensate for a less than ideal solution, but it will eventually trip up even them, especially in later levels.
What isn't perfected yet?  And where did I state this?  The proposed approach is nowhere near "comparable" to a good 8/4 way stick with changeable physical restriction.  In fact, as I stated before, it's not even necessarily better than what MAME does by default.  A physically restricted 4-way joystick, which cannot physically actuate two switches simultaneously is perfection in this case, and they do exist.  With a little tuning, they also exist in the form which allows switching between 4 and 8 way operation.
rablack97
« Reply #26 on: October 18, 2012, 11:59:58 pm »
OK, the Purists win.....
I've digested and heard everything you've said.......As stated before your expertise supercedes mine in this area.
I'm off to play some Rally X on an unrestricted 8-way joystick with hair trigger switches.....just to make the game more interesting...
 :notworthy: :notworthy: :notworthy:
MTPPC
« Reply #27 on: October 19, 2012, 10:25:28 am »
RandyT said the most important thing when he said that the math and physics of an 8-way precludes the possibility of perfect 4-way play. I don't care if it's 10 times better, if the game throws you off in 1 out of a thousand directional changes, you will never be able to achieve a mastery level of any game. For me, this takes the fun out of the game because the game is hard enough without mechanical hurdles. I learned this when my cheap zippy joystick had a microleaf that didn't register about once out of 200 activations. It completely ruined the game play. Do you want the game to knock you out even when you are playing perfectly?
http://pinballmd.com/
rablack97
« Reply #28 on: October 19, 2012, 11:38:43 am »
 :timebomb: :blowup:
If your trying to achieve mastery then you shouldn't be using a virtual 4 way anyway.  If RandyT says there are perfect 4-way Jstiks, i'm assuming you would cop one of those to give yourself an edge to achieve mastery.  I was talking on the lines of normal everyday gameplay, not top choice mastery.
I never said this method was going to replace anything, it's an option, just like everything else in this hobby.
So i get what everyone is saying, no big deal.......i'm bowing out gracefully :notworthy: :notworthy: :notworthy:
mgb
  • North East, US
« Reply #29 on: October 19, 2012, 12:06:26 pm »
So I think what we all get out of this is that
1)physical 4way restriction is best. (Duh, haven't we all known that) but still to each his own.
2)Randy gets really pissed any time someone else offers any type of product or software that is not GGG.
I think pbj said it best
You guys get frothy over some really trivial stuff
 :lol
rablack97
« Reply #30 on: October 19, 2012, 12:41:50 pm »
 :duckhunt :laugh2: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
That's all i have to say about that!!!!!!
CheffoJeffo
« Reply #31 on: October 19, 2012, 01:05:28 pm »
So much for exiting gracefully ...  ::)
Working: Not Enough
Projects: Too Many
Progress: None
brad808
« Reply #32 on: October 19, 2012, 01:09:55 pm »
I think this is exactly it right here. People that want to play 4 way games need a 4 way joystick. For me, I play some 4 way games but really couldn't care less about how they play because it's close enough for me using an 8 way stick. I've never really noticed a difference to be honest and never had any problems with false directions (maybe thats just because I'm so precise with my joystickin and don't make mistakes :blah:).
  • Last login:Today at 12:51:52 am
« Reply #33 on: October 19, 2012, 01:12:07 pm »
I've been reading some posts this thread with no small amount of dismay/disgust.   :banghead:   :banghead:   :banghead:
To put this thread in gun terms:
Several people at the beginning say that you can't hit a 150 yard target very well with a cheap .22 cal rifle. (very true since most come with iron sights instead of a scope)
Degenatron mentions that you can pick off targets fairly well PLINKING with an inexpensive Ruger 10-22 and a decent scope.
Randy keeps saying that only a .308 rifle with a Leupold 50mm miil-dot scope or better is suitable for real sniper duty. (Randy owns Remington.  Andy owns Winchester.)
Several others agree that for sniper duty the .308 is the way to go.
Several people who have actually shot the Ruger in question make the point that for those of us who aren't snipers and would rather not spend $1400 on the .308, spending only $300 on the Ruger 10-22 FOR PLINKING works fine.   :dunno
At this point, Randy continues to put down the Ruger option and hammer on the need to use the flat-shooting, hard-hitting, bad-guy-stopping .308 round.   :hissy:
A cynical observer might conclude that Remington is nervous about the entry-level Ruger rifle cutting into his market share.   ;D
Randy - In all seriousness, I think your passion for your products is truly commendable and both your products and customer service are top-notch, but not every business fills every part of every niche.
Like the argument about admin buttons, there is more than one answer -- the "correct" one depends on builder/user preferences.
I like having a range of choices.  Yay, capitalism!  We get to choose the best one that we're willing to pay for.
CheffoJeffo
« Reply #34 on: October 19, 2012, 01:26:18 pm »
While RandyT certainly has some zeal that rubs people the wrong way, I don't think he has been off-point.
I remember a similarly-toned thread about the TOKN encoder where people who had actually tried it reported how great it was. RandyT was insistent as to what the underlying issues were and what the people who reported greatness needed to consider. There were a number of posts similar to the "RandyT doesn't like anybody who isn't GGG" posts here. Well, there is a reason that the TOKN isn't around anymore and it wasn't because Randy ran them out of town.
You should all be using Wico 4-ways for classics anyway! Except for Donkey Kong, which needs a Nintendo Strongtanium(tm) 4-Way. And Pac Man, which needs a Midway 4-Way.  ;)
 :oldman
Working: Not Enough
Projects: Too Many
Progress: None
rablack97
« Reply #35 on: October 19, 2012, 01:32:06 pm »
Well now I'm just bowing out LMAO......
It's all in fun for me....I think I bought from like 8 different suppliers when building, including the Andy's and Randy's of the world.
All purchases were based on price point and the actual need of the feature.....
It's like I said before, there is no right or wrong here, its personal prefence....
The next time is feel the need to get into the Guiness Book of World Records for MS. Pacman gameplay....I'll be off to buy the Limited Edition Super 4 Way restricted left hand offset stubbed handled carbon ball handle topped short throw laser cut mame enhanced model....
« Reply #36 on: October 19, 2012, 01:38:11 pm »
Just googled TOKN for fun. Yikes!
LeedsFan
« Reply #37 on: October 19, 2012, 01:55:53 pm »
I'm surprised the thread went in this direction. I'm all for people trying different stuff. I appalud the OP for thinking of something that might suit some people in the community. There's absolutely nothing wrong with that.
For me... personally... it doesn't matter how good the software or firmware is. The Boolean logic could be 100% perfect or whatever.  But if I'm playing Frogger or Donkey Kong I simply DEMAND a physically restricted 4-way joystick. And nothing else will cut it for me.
Some people simply just aren't bothered (and I used to be like this when I first got into emulation). They will casually play with an 8-way and if they get chumpatized in the game they just go "Meh". They just want some Mame action and that's fair enough too
« Reply #38 on: October 19, 2012, 02:00:54 pm »
1)physical 4way restriction is best. (Duh, haven't we all known that)....
Evidently, based on some of the responses, this is not the case.
Actually, it's just posts like this one which do that.  Not once in all of the accurate information I have offered here, have I mentioned a single one of my products, but there is someone else who is pushing a feature of one of theirs, which based on simple math and logic, cannot deliver what is being claimed.  You can witness the disappointment with this type of approach from an actual user right here.  And when questioning the company as how to get the device to deliver the promised performance, they were told (paraphrased) "when playing, don't do something which screws up the algorithm".    The same advice can be given when using the default 4-way handling algorithm already present in the applications.  If one enjoys conforming their playing style to an algorithm, then you can do that without the extra time and expense.
My concerns are for the folks who don't understand how all of this works, and design a setup around the notion that such a thing is possible, when it is not.  It doesn't do the community, or individual's pocketbooks, any favors to lead members down "dead-end" roads, which cause them to need to turn back and start again once they find themselves there.
<apples and oranges gun analogy removed>
And that last statement is the one I am attempting to clarify for folks.  This isn't a "preference" issue, as a few folks here are insisting.  That is, unless your preference is poor 4-way gameplay that is equal to the default poor gameplay that is already present.  Calling this a "preference issue" is tantamount to calling an encoder which has ghosting/blocking problems just as good as one which doesn't.  That poorly designed encoder will still play games, as long as you don't do certain things while playing.  But I think few here would want one.
As I stated earlier, if something like this had any merit whatsoever, you would already see it on my products, Andy's products, and on those of any other encoder producer out there.  Anyone who thinks that we haven't tested this for ourselves is giving in to fantasy.
« Last Edit: October 19, 2012, 02:12:53 pm by RandyT »
« Reply #39 on: October 19, 2012, 02:09:20 pm »
Roger that!
If Degenatron's AVR is a Kia compared to Andy and Randy's Mercedes and Cadillac, would that make the TOKN a Trabant?   :laugh2:
