Author Topic: T-molding with lip(s) question  (Read 1577 times)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« on: October 09, 2012, 12:46:45 pm »
Is there a specific t-molding that people have experience with that has a lip on one side or both, for the front of a control panel with artwork?  I've seen some at various online stores but my experience is limited to straight up 3/4" t-molding with a slot cutter.
This is the limit of my experience...http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=75&products_id=221
Of course they are sold out - http://www.t-molding.com/store/product.php?productid=16
But assuming they had it in stock, would that fit 3/4" plywood and use the same slot bit as the other link?
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: T-molding with lip(s) question
« Reply #1 on: October 09, 2012, 06:33:53 pm »
I hate to answer a question with a question but are you concerned the artwork is going to peel?  I would tend to think that the lip will make it uncomfortable if you are resting your arm/wrist on the panel.  Some people opt for a smaller thickness for the control panel and add plexi on top to protect the artwork.  The combined thickness works out to 3/4 of an inch.   If your panel is already 3/4 of an inch you can offset the slot for the t-molding and accomplish the same thing...just round the bottom edges.
Frostillicus
  • Arcade Artist
« Reply #2 on: October 09, 2012, 07:18:17 pm »
That is probably a better idea... I didn't think of comfort factor.
  • Last login:Today at 04:12:26 pm
« Reply #3 on: October 09, 2012, 07:51:26 pm »
The other approach is to wrap the art around the edge and cut it at the edge of the t-molding slot allowing the t-molding to hold the edges of the art down like Rikitiki does in his stickied "side art install 101" thread.
paigeoliver
  • Awesome face!
« Reply #4 on: October 09, 2012, 09:13:58 pm »
You are probably going to want to use plexi if you are going with custom printed artwork anyway. I HATE plexi, but I still use it whenever I am not using silk screened artwork.
