February 16, 2026, 06:16:35 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Main Forum
Will this light strip be big enough for my marquee?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Will this light strip be big enough for my marquee? (Read 1115 times)
chucklepie
Trade Count:
0
Full Member
Offline
Last login:September 09, 2013, 08:56:54 am
I want to build my own arcade controls!
on:
September 26, 2012, 09:31:07 am »
Hello,
My marquee is 660mm by 150mm.
I've bought a 14w Fluorescent 60cm T5 Striplight. It's a tight squeeze and I'm wondering whether it's overkill.
Do you think a a 8w 34cm would do? I'm more thinking would the edge of the marquee be dim?
thanks.
Logged
Trade Count:
+3
Full Member
Offline
Last login:February 14, 2026, 11:45:41 am
I break stuff...then fix it...sometimes
Re: Will this light strip be big enough for my marquee?
Reply #1 on:
September 26, 2012, 11:45:19 am »
most marquees use an "F15T8" fluorescent light. it's about 43 centimetres.
it's 15 watts and pretty bright. I guess my question would be... is your marquee DARK or does it have a fair amount of bright or white colour in it?
if it's dark I would suggest the brighter bulb...otherwise you may hardly notice it's lit up since most of the light is going to blocked.
if it's light or fairly brightly coloured a lower wattage may do just fine.
I would still try to get one al long as the opening will fit. You don't want a "hot spot" of light in the middle of the marquee and have the edges dark.
with flourecent fixtures try to find something with the stadard "medium Bi-pin" also known as a "G13" connections... the bulbs are a lot more common than the small size commonly found with Chinese imported fixtures. and the bulbs are about 1/4 the price of them too.
Logged
chucklepie
Trade Count:
0
Full Member
Offline
Reply #2 on:
September 26, 2012, 12:55:36 pm »
Cheers, I'll stick with the longer one then. As for the marquee, I haven't decided on the design yet, but I've found a place that's cheap enough and do prints on 'backlit' paper.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
