Author Topic: Namco Cabinet Project  (Read 14900 times)
t3design
  • Last login:January 02, 2026, 12:17:49 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Re: Namco Cabinet Project
« Reply #40 on: October 21, 2012, 03:52:53 pm »
Best indication of a DIY household....no switch cover on the wall next to the pin!
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
ViriiGuy
  • Last login:January 08, 2020, 12:30:46 pm
  • Terminus clone build in progress.
« Reply #41 on: October 21, 2012, 04:56:57 pm »
Yes, our electrical is in a slow overhaul. Been working on it bit by bit for 8 months, since we bought the house :)
ViriiGuy
« Reply #42 on: January 08, 2013, 03:52:45 pm »
This project has not progressed a lot since my last update. I had the software all setup and the cabinet was fully functional. I bought some black vinyl from Parts Express, to just make it look clean while I came up with a theme. Once I got that put on, the HDD with all my ROMs on it died. GRRRRR!!! Then the PC started to have issues, which I suspect is what caused the HDD to die. So for now it is on hold, while I build my Virtual Pinball Cab, Optimus-Pin http://www.hyperspin-fe.com/forum/showthread.php?22704-Optimus-Pin-P2k-Build-(39-24-22)
Once I get it finished up, I will start back on the cab. Oh... And the Black vinyl from Parts Express.... Sucks. It is already lifting and peeling.
ViriiGuy
« Reply #43 on: September 12, 2013, 11:31:51 am »
Ok.. Plans have changed :)
This cabinet is just TOO dang big. So I am taking all my stuff back out of it and I will be doing a custom slim cabinet for my LCD.
So I have this one to give away.
Well that did not take long :) The cabinet has found a new home.
« Last Edit: September 12, 2013, 01:50:12 pm by ViriiGuy »
