Author Topic: Super thin wood sheets  (Read 11919 times)
SavannahLion
« on: September 04, 2012, 12:18:42 am »
I'm trying to figure out what this stuff is called. Home Depot employees don't have a full brain to share between them.
It's super thin, probably around 1/8" but not thicker than around 1/4" or so. Recently I've seen it on that crummy IKEA furniture as "filler" panels in between the frameworks. The pegboard everyone hangs in their shop is right around in that same ball park, just without the holes. I don't care about veneer or melamine if I can get it cheaper without.
In recent times it's composed of a something between pressed wood and paper fibers. In the "old" days, I've seen it as a type of very thin plywood  (I would love to get the ply rather than the particle), go back even further and I've seen really nice Japanese furniture from the 1940's or 50's with the super thin solid redwood panels (made from fruit crates no less  :dizzy: ).
I can't and don't want a veneer. It needs to at least firm up when I glue and nail the frame to it. I just need to know the name of this stuff so I can buy it.  :angry:
It's going inside my cab. I'm using it to partition part of the cab to prevent a metal pinball from accidentally flying into the elctronics or getting lost inside the cab. It will also double, in part, to guide some wiring back and forth.
« Last Edit: September 04, 2012, 12:21:54 am by SavannahLion »
Re: Super thin wood sheets
« Reply #1 on: September 04, 2012, 01:25:29 am »
Don't they call that stuff "hard board" or some such now?  They (the brainless HD guys) have the stuff in their big box, or at least do in mine, it's over by where they stock the pre-cut MDF sheets, only up high so nobody can ever get to the stuff.  Below is what I pulled off a quick search, it's a full sheet but I'm purt sure they sell smaller
3/16 in. x 48 in. x 96 in. Tempered Hard Board
Model # 832780
Store SKU # 832780
Store SO SKU # 832780
$13.98 /PC-Piece
  • Last login:Today at 01:53:38 am
« Reply #2 on: September 04, 2012, 01:39:50 am »
Confirmed.  It is called Hardboard.
Home Depot has 1/8" x 2' x 4' sheets, or 1/4" x 2' x 4' sheets
If you have a Menard's nearby, their prices are a little better on the smaller sheets.
Sounds like you're doing VISUAL Pinball wrong.   >:D :laugh2:
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #3 on: September 04, 2012, 01:57:14 am »
Typically just 'hardboard' these days, but if that doesn't ring any bells with the staff at the lumber yard, you might try going old-school and ask if they have stock of masonite.
SavannahLion
« Reply #4 on: September 04, 2012, 02:28:09 am »
Hardboard, Masonite. Thanks guys, that's what I was looking for.
 ??? :dunno ??? :dunno
No... really, I don't get it.
« Reply #5 on: September 04, 2012, 02:46:38 am »
Visual Pinball doesn't require a metal pinball inside your cab.   :banghead:
SavannahLion
« Reply #6 on: September 04, 2012, 10:32:08 am »
That's what I thought you were saying. I just.... Yeah......
